With the changes to nvidia
the “linux59-nvidia” driver is not working
am I missing something or is one of the files in need of an update?
I have “nvidia-utils” and “mhwd-nvidia” installed but none of it seems to work.
The above provides nvidia-455xx-455.45.01-1
Tried linx54 but still no joy.
pobrn
1 December 2020 11:33
2
It doesn’t load? What’s the output of sudo modprobe nvidia
? Is the correct mhwd configuration applied?
pobrn:
modprobe nvidia
modprobe: ERROR: could not insert ‘nvidia’: No such device
pobrn
1 December 2020 11:38
4
That’s interesting and I don’t think it should happen. What’s the output of mhwd -li
and modinfo nvidia
pobrn:
modinfo
?1 ~ $ mhwd -li [1]
Warning: No installed PCI configs!
?1 ~ $ modinfo nvidia [1]
filename: /lib/modules/5.9.11-3-MANJARO/extramodules/nvidia.ko.gz
alias: char-major-195-*
version: 455.45.01
supported: external
license: NVIDIA
srcversion: 9596FDF4ECB68196404E921
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends:
retpoline: Y
vermagic: 5.9.11-3-MANJARO SMP preempt mod_unload modversions
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: nv_cap_enable_devfs:Enable (1) or disable (0) nv-caps devfs support. Default: 1 (int)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_EnableBacklightHandler:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_AssignGpus:charp
pobrn
1 December 2020 12:04
6
That could be a problem. Please use mhwd
to install the drivers, or if you want a graphical interface, use Manjaro Settings Manager > Hardware Configuration.
If you don’t have an intel GPU or you don’t want to use it: sudo mhwd -i pci video-nvidia-455xx
if you have an intel GPU and you want to use it: sudo mhwd -i pci video-hybrid-intel-nvidia-455xx-prime
Or you can run sudo mhwd -a pci nonfree 0300
to let it automatically pick a configuration.
I had to install all the files “sudo mhwd -a pci nonfree 0300” wanted first. The one problem is “lib32-nvidia-utils” cals “nvidia-455xx” which no longer exits. Found the file in th AUR and downloaded, built and installed. Guess this file needs an update?
Then “sudo mhwd -a pci nonfree 0300” works happily skipping the previously installed files and doing its stuff. So it works now.
himan
2 December 2020 03:30
8
hi robin.
same error. and i found all the “455xx” seems no longer exits too in the AUR !
i can not get the “nvidia-455xx-utils”, which “lib32-nvidia-utils” needed from any channel.
so which package you use? please help me.
pobrn:
video-nvidia-455xx
It’s now just video-nvidia
as there’s now a unified driver.
It already was today.
❯ pacman -Qs nvidia
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-utils 455.45.01-3
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.4-1
local/libxnvctrl 455.45.01-1
NVIDIA NV-CONTROL X extension
local/linux54-nvidia 455.45.01-2 (linux54-extramodules)
NVIDIA drivers for linux.
local/linux59-nvidia 455.45.01-2 (linux59-extramodules)
local/mhwd-nvidia 455.45.01-2
MHWD module-ids for nvidia 455.45.01
local/mhwd-nvidia-390xx 390.132-1
MHWD module-ids for nvidia 390.132
local/nvidia-utils 455.45.01-2
himan
2 December 2020 05:58
10
Thank you, Yochanan
it’s worked now .
a sync issue? i guess
system
Closed
17 December 2020 05:58
11
