Hello, long time Mint user switching to Manjaro.
I grabbed the Cinnamon distribution.
I used mhwd
to install the nvidia drivers
$ sudo mhwd -a pci nonfree 0300
> Using config 'video-nvidia-390xx' for device: 0000:26:00.0 (0300:10de:1b82) Display controller nVidia Corporation GP104 [GeForce GTX 1070 Ti]
> Installing video-nvidia-390xx...
Which was successful, but once I rebooted, I still get the warning notification saying: Your system is currently running without video hardware acceleration.
And true enough, running a game shows poor performance.
I have looked around but didn’t see anything about this on the forumns. I am a little concered that it chose to install 390xx while according to nvidia, a GeForce GTX 1070 Ti should be on 455.45.01
I would prefer the newer driver, but I can’t seem to get it to install.
$ sudo pacman -S nvidia
warning: linux59-nvidia-390xx-390.138-2 is up to date -- reinstalling
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=7753964c-880c-4c69-a5b5-e043f829a51d rw quiet apparmor=1
Desktop: Cinnamon 4.8.3 tk: GTK 3.24.24 dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
UEFI [Legacy]: American Megatrends v: P1.30 date: 07/04/2018
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
bogomips: 81484
Speed: 1377 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1377 2: 1380 3: 1508 4: 1535 5: 1373 6: 1373 7: 1491 8: 1414 9: 1377
10: 1378 11: 1378 12: 1381
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ASUSTeK driver: nvidia
v: 390.138 alternate: nouveau,nvidia_drm bus ID: 26:00.0 chip ID: 10de:1b82
Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.8x15.0")
s-diag: 987mm (38.8")
Monitor-1: DP-0 res: 3440x1440 hz: 60 dpi: 110 size: 797x334mm (31.4x13.1")
diag: 864mm (34")
OpenGL: renderer: llvmpipe (LLVM 11.0.0 256 bits) v: 4.5 Mesa 20.3.1
compat-v: 3.1 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 26:00.1 chip ID: 10de:10f0
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 28:00.3 chip ID: 1022:1457
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 25:00.0
chip ID: 10ec:8168
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 3-4.2:5 chip ID: 0bda:8153 serial: <filter>
IF: enp39s0f3u4u2 state: down mac: <filter>
Local Storage: total: 1.36 TiB used: 14.57 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200NP
size: 447.13 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: SVN139B temp: 29.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 4B6Q
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: USB Flash
size: 15 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 0.00
ID-1: / raw size: 447.13 GiB size: 439.11 GiB (98.21%)
used: 14.57 GiB (3.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 47.5 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 349 Uptime: 2m wakeups: 1 Memory: 15.63 GiB
used: 2.52 GiB (16.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1311 lib: 424 flatpak: 0 Shell: Bash
v: 5.1.0 running in: gnome-terminal inxi: 3.2.01
