It goes without saying: be safe. Make sure that you are not accidentally destroying irreplaceable data when formatting a new filesystem.
I hate to sound repetitive, but remember to first remove the package exfat-utils
and then install the package exfatprogs
before you format and mount. Otherwise, it will mount the exFAT filesystem via fuseblk
instead of the kernelās native exfat
driver .
Thankfully, the latest versions of KDE Partition Manager automatically detect whether your system has exfat-utils
or exfatprogs
available.
I prefer to use the noatime
mount option for my exFAT partitions (well, for any partition, really.)
Well i was going to that today earlier but iāve seen way too many reports about exFAT causing file corruptionā¦ i got cold feet and moved back to ntfs downloading directly to ntfs partition using ntfs3 can be mitigated by first downloading somewhere then movingā¦ which is really inconvenient but better than data loss, im going to format some thumb drives with exFAT first, lets see how that goesā¦
Native exFAT in the mainline kernel? Or when using the fuseblk method?
For some reason Manjaro still ships without exfatprogs
in favor of exfat-utils
. Remember, Samsung developed and maintained exfatprogs/exFAT for Linux to use on their vast array of mobile devices running Linux. If I had to pick, Iād trust them more than Paragon.
I would be just as tentative (perhaps even more so) about invaluable data being stored on an NTFS filesystem with Linux.
my reaction if you had led with that info i wouldāve done that already
unfortunately its a little late now but iāll do that for my gaming partition since i dont have any sensitive data there.
that is true but iāve been using ntfs on linux for the past decade and never once had any data loss issues.
i have totally agree with what omano said here. i regularly torrent download (via qbitorrent) to a NTFS partition mounted with ntfs3
. the only time i ean into major issues was when i had powerloss which ended up corrupting MFT tables of NTFS which required chkdsk to correct.
So im using exfat now with exfatprogs
as mentioned by @winnie above, just tested with steam/proton and it worked just fine.
This is what iāve done in my fstab file: (credits)
the extra setup bellow is useful if you are using another partition for your SteamLibrary instead of your default ~/.steam/root/steamapps/ one, because you need it to be mounted before you can bind it (you also need permissions)
#ext4 gamedisk
UUID=b8d0aac6-26b1-4ca0-bc5c-19d5a3821ea5 /mnt/gamedisk ext4 defaults,noatime 0 2
#exfat-gamedisk
UUID=63CF-FE64 /mnt/gamedisk-exfat exfat noatime,nosuid,nodev,nofail,x-gvfs-show,uid=ian,gid=ian,rw,user,exec,umask=000 0 0
#exfat steam prefix and shadercache binds
/mnt/gamedisk/SteamLibrary/steamapps/compatdata/ /mnt/gamedisk-exfat/SteamLibrary/steamapps/compatdata none defaults,bind 0 0
/mnt/gamedisk/SteamLibrary/steamapps/shadercache/ /mnt/gamedisk-exfat/SteamLibrary/steamapps/shadercache none defaults,bind 0 0
For your info exfat-utils has been removed in the root packages and replaced with exfatprogs so newer ISOās will be OK.
