Hello,
i have tried to install ROTB:
cd ~/apps/;git clone https://github.com/DEgITx/rats-search.git;cd rats*
pamac install npm
npm install
npm audit
npm audit fix
commands remaining to be ran:
npm run buildweb
npm run server
firefox http://localhost:8095
but the first set of commands found 14 vulnerabilities and failed to fix/get dependency.
full commands output here please
so i am wondering what are correct commands to fix this?
Upstream uses Node.js v14 to build while we have 15 in the repos. You can use NVM to use v14 to build it.
The best way would be modifying the rats-search-git
PKGBUILD and use NVM per Node.js package guidelines.
Lolix
3
There are LTS versions of nodejs in the repo, v14 is nodejs-lts-fermium Arch Linux - nodejs-lts-fermium 14.16.0-2 (x86_64)
mailto:developer-of-rats@somewhere.com
pamac install nodejs-lts-fermium
Removing nodejs (15.14.0-1)… [1/1]
Installing nodejs-lts-fermium (14.16.0-1)… [1/1]
Transaction successfully finished
but npm install;npm audit fix
still has issues
Lolix
6
Before I wasn’t at home to try it, meanwhile some opened an issue on github npm install found 14 vulnerabilities and failed to fix/get dependency · Issue #142 · DEgITx/rats-search · GitHub
I have tried to run it without running audit/audit fix and it fails badly anyway
Yochanan
Closed
8
