Nouveau 0000:01:00.0: fifo: SCHED_ERROR 20
may 15 13:52:24 XPS9500 kernel: nouveau 0000:01:00.0: fifo: SCHED_ERROR 20
may 15 13:52:24 XPS9500 systemd-journald[292]: Missed 10 kernel messages
I have a thousands of this messeges on my journalctl list, I don’t now how to fix this problem. I can’t find nouveau in repo and ystem update does not solve the problem.
  Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=f4997b85-74a0-4cd3-9def-83f1ee9ff7a5 rw quiet splash apparmor=1
    security=apparmor resume=UUID=649395ec-ec4f-435c-81b7-3aafcdef2865
    udev.log_priority=3
  Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Dell product: XPS 15 9500 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0RHXRG v: A03 serial: <filter> part-nu: 097D
    uuid: 4c4c4544-0034-4e10-8033-b7c04f444233 UEFI: Dell v: 1.22.0
    date: 03/16/2023
  ID-1: BAT0 charge: 27.7 Wh (43.7%) condition: 63.4/84.3 Wh (75.2%)
    volts: 11.1 min: 11.4 model: BYD DELL M59JH0B type: Li-poly serial: <filter>
    status: discharging
  System RAM: total: 32 GiB available: 30.98 GiB used: 5.36 GiB (17.3%)
    igpu: 64 MiB
  Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB speed:
    spec: 3200 MT/s actual: 2933 MT/s volts: curr: 1.2 width (bits): data: 64
    total: 64 manufacturer: 80CE00000000 part-no: M471A2K43DB1-CWE
    serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous size: 16 GiB speed:
    serial: <filter>
  Slot: 0 type: PCIe lanes: 16 status: in use length: long volts: 3.3
    bus-ID: 00:1c.0 children: 1: 02:00.0 class-ID: 0604 type: bridge children:
    1: 03:00.0 class-ID: 0604 type: bridge children: 1: 04:00.0 class-ID: 0880
    type: peripheral 2: 03:01.0 class-ID: 0604 type: bridge 3: 03:02.0
    class-ID: 0604 type: bridge children: 1: 38:00.0 class-ID: 0c03
    type: serialbus 4: 03:04.0 class-ID: 0604 type: bridge
  Slot: 1 type: PCIe gen: 1 lanes: 1 status: available length: long
    volts: 3.3 bus-ID: 00:1c.1
  Slot: 2 type: PCIe gen: 2 lanes: 1 status: available length: long
    volts: 3.3 bus-ID: 00:1c.2
  Slot: 3 type: PCIe gen: 3 lanes: 1 status: available length: long
    volts: 3.3 bus-ID: 00:1c.3
  Slot: 4 type: PCIe gen: 4 lanes: 1 status: available length: long
    volts: 3.3 bus-ID: 00:1c.4
  Slot: 5 type: PCIe gen: 5 lanes: 1 status: available length: long
    volts: 3.3 bus-ID: 00:1c.5
  Slot: 6 type: PCIe gen: 6 lanes: 1 status: in use length: long volts: 3.3
    bus-ID: 00:1c.6 children: 1: 6c:00.0 class-ID: ff00 type: unassigned
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 high: 801 min/max: 800/5000 base/boost: 2772/2600
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 801 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
    rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0302
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3 chip-ID: 0bda:5510
  Display: server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
    display-ID: :1 note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: Sharp 0x14d0 built: 2020 res: 3840x2400 dpi: 290
    gamma: 1.2 chroma: red: x: 0.663 y: 0.325 green: x: 0.208 y: 0.722 blue:
    x: 0.141 y: 0.051 white: x: 0.310 y: 0.329 size: 336x210mm (13.23x8.27")
    diag: 396mm (15.6") ratio: 16:10 modes: 3840x2400
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 30.25 GiB unified: yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: n/a (root, process) with:
  Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
    Wi-Fi 6 Killer AX1650s 160MHz 2x2 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:06f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 122.81 GiB (12.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2300 NVMe 1024GB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 23000020 temp: 40.9 C
    scheme: GPT
  ID-1: / raw-size: 944.77 GiB size: 928.86 GiB (98.32%)
    used: 122.81 GiB (13.2%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: f4997b85-74a0-4cd3-9def-83f1ee9ff7a5
    used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 2A6B-ED26
    dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 649395ec-ec4f-435c-81b7-3aafcdef2865
  Device-1: 1-10:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:533c class-ID: ff00
  Device-2: 1-11:3 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bda:5510 class-ID: fe01 serial: <filter>
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  System Temperatures: cpu: 48.0 C pch: 44.0 C mobo: 36.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1374 libs: 384 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://mirror.init7.net/manjaro/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 357
  1: cpu: 47.9% command: pamac-manager pid: 5337 mem: 871.9 MiB (2.7%)
  2: cpu: 11.9% command: nautilus pid: 5333 mem: 210.6 MiB (0.6%)
  3: cpu: 10.9% command: chrome pid: 4231 mem: 236.7 MiB (0.7%)
  4: cpu: 10.0% command: gnome-characters started-by: gjs-console pid: 5331
    mem: 204.8 MiB (0.6%)
  5: cpu: 10.0% command: gnome-clocks pid: 5335 mem: 201.4 MiB (0.6%)
  Memory top: 5 of 357
  1: mem: 871.9 MiB (2.7%) command: pamac-manager pid: 5337 cpu: 47.9%
  2: mem: 383.3 MiB (1.2%) command: chrome pid: 2920 cpu: 9.2%
  3: mem: 297.3 MiB (0.9%) command: gnome-shell pid: 1541 cpu: 4.9%
  4: mem: 260.9 MiB (0.8%) command: chrome pid: 3324 cpu: 2.6%
  5: mem: 259.4 MiB (0.8%) command: chrome pid: 4673 cpu: 2.2%
  Processes: 357 Power: uptime: 26m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 12.38 GiB services: gsd-power, power-profiles-daemon,
    upowerd Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: gnome-terminal inxi: 3.3.34
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
sudo inxi --verbosity=8 --filter --width
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
