i was playing around plasma themes and global themes and then i noticed my notifications options became so dark that it is nearly impossible to see whats written like the do no disturb and that cross icon
can i make that text white or gray? its hard to see
If you are certain the theme you have chosen (some dark theme) is correct, you should make sure to reboot, to make everything load fresh.
reboot done but still no difference
Try another theme? Maybe the colors chosen by your theme are not well adjusted.
