Notification popup consistently defaults to appear offscreen
So, I noticed maybe two updates ago that the notification popup will randomly default to display mostly offscreen in the upper left corner with only the very bottom most sliver of the notification visible. I have repeatedly changed the notification to display in the bottom right corner/display near notification icon in settings > notifications > popups, but no matter how often I do this, it will randomly revert to displaying offscreen. I have a single monitor setup, if that matters at all.
Any help in resolving this so that the notification popup will no longer appear offscreen would be greatly appreciated.
Probably you have another notification daemon installed and interferes with knotifications settings.
I definitely haven’t installed any other notifier though… Would you know how I could hunt down this mysterious notification daemon, assuming it exists?
Rip further help, I guess…
