Hi guys
Among my computers is also an older notebook, which is a hybrid system equipped with a Geforce 910M graphics chip from Nvidia, in addition to a simple Intel HD graphics chip. When I run Linux Mint or another Ubuntu derivative on this device as a test, the installation of the proprietary Nvidia driver 470.xx with Prime is suggested accordingly, which also works without a hitch. Under Manjaro, however, only the 390 driver is suggested in the Settings Manager, at most with the already extremely outdated Bumblebee as an option, something else is not available and here it probably makes more sense to stay with nouveau. Why is that, although the Geforce 910M GPU belongs to the Kepler microarchitecture, which is still supported by the 470 series driver, especially since this driver is still in the official Manjaro repositories. It would be nice if this could be changed.
The specs:
inxi --admin --verbosity=7 --filter --width
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=996d8916-5622-4ead-a8d7-ae628fb42df7 rw rootflags=subvol=@ quiet
cryptdevice=UUID=4c193ae8-0243-4b9d-8321-d9cf87cb4e31:luks-4c193ae8-0243-4b9d-8321-d9cf87cb4e31
root=/dev/mapper/luks-4c193ae8-0243-4b9d-8321-d9cf87cb4e31 splash
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Aspire ES1-731G v: V1.22
serial: <superuser required>
Mobo: Acer model: Tashigi_BA v: V1.22 serial: <superuser required>
UEFI: Insyde v: 1.22 date: 07/07/2016
ID-1: BAT1 charge: 3.1 Wh (100.0%) condition: 3.1/25.1 Wh (12.5%) volts: 7.5
min: 11.4 model: LGC AC14B18J type: Li-ion serial: <filter> status: charging
RAM: total: 7.66 GiB used: 2.69 GiB (35.1%)
Info: model: Intel Pentium N3710 bits: 64 type: MCP arch: Airmont level: v2
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 4
microcode: 0x411
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 569 high: 838 min/max: 480/2560 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 838 2: 480 3: 480 4: 480
bogomips: 12805
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good
sep smep ss sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi
vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics vendor: Acer Incorporated ALI driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: NVIDIA GK208BM [GeForce 910M] vendor: Acer Incorporated ALI
driver: nouveau v: kernel non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s lanes: 2
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 10de:129a
class-ID: 0302 temp: 39.0 C
Device-3: Realtek Acer 640 Γ 480 laptop camera type: USB driver: uvcvideo
bus-ID: 1-3:4 chip-ID: 0bda:57b3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus,nouveau gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: AU Optronics 0x119e built: 2011 res: 1600x900
hz: 60 dpi: 106 gamma: 1.2 size: 382x214mm (15.04x8.43") diag: 438mm (17.2")
ratio: 16:9 modes: 1600x900
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 2
link-max: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:0e0f
class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-3: TP-Link Archer T4U ver.3 type: USB driver: rtl88x2bu
bus-ID: 1-1:2 chip-ID: 2357:0115 class-ID: 0000 serial: <filter>
IF: wlp0s20u1 state: up mac: <filter>
Device-1: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-2:8 chip-ID: 04ca:3014 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Device-1: luks-4c193ae8-0243-4b9d-8321-d9cf87cb4e31 maj-min: 254:0
type: LUKS dm: dm-0 size: 931.21 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 931.22 GiB
Local Storage: total: 931.51 GiB used: 65.29 GiB (7.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 043 scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8A6SH rev: GA11
dev-links: cdrom
ID-1: / raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
used: 65.28 GiB (7.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4c193ae8-0243-4b9d-8321-d9cf87cb4e31 label: N/A
uuid: 996d8916-5622-4ead-a8d7-ae628fb42df7
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 7288-D855
ID-3: /home raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-4: /swap raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-5: /var/cache raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-6: /var/log raw-size: 931.21 GiB size: 931.21 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-1:2 info: TP-Link Archer T4U ver.3 type: Network
driver: rtl88x2bu interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
Device-2: 1-2:8 info: Lite-On Qualcomm Atheros Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-3: 1-3:4 info: Realtek Acer 640 Γ 480 laptop camera type: Video
Hub-2: 1-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5.3:6 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-5.4:7 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nouveau temp: 39.0 C
Processes: 229 Uptime: 4h 15m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1125 libs: 344 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
