Notebook go into sleep mode
dmesg
[ 6975.323885] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 6975.324386] sd 0:0:0:0: [sda] Stopping disk
[ 6980.707804] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 6980.709442] ata1.00: configured for UDMA/133
[ 6980.709593] sd 0:0:0:0: [sda] Starting disk
[ 6995.794721] [UFW BLOCK]
[ 7017.707207] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 7017.707669] sd 0:0:0:0: [sda] Stopping disk
[ 7018.859430] sd 0:0:0:0: [sda] Starting disk
[ 7082.439740] audit: type=1111 audit(1635258577.889:312): pid=590 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="wlp2s0" ifindex=3 pid=1084 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7082.811472] audit: type=1130 audit(1635258578.263:313): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7082.875965] wlp2s0: deauthenticating from 50:d4:f7:ea:93:78 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7093.009436] audit: type=1131 audit(1635258588.459:314): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7127.340719] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 7127.341365] sd 0:0:0:0: [sda] Stopping disk
[ 7127.948074] sd 0:0:0:0: [sda] Starting disk
[ 7179.200567] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 7179.201123] sd 0:0:0:0: [sda] Stopping disk
[ 7184.867954] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 7184.870136] ata1.00: configured for UDMA/133
[ 7184.870307] sd 0:0:0:0: [sda] Starting disk
[ 7192.630850] audit: type=1101 audit(1635258688.083:315): pid=10955 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting g
its make after go from sleep mode “i pluged notebook into charger and turn sleep mode its make always after go from sleep mode”
Version: 21.1.6 (Pahvo)
Codename: Pahvo
laptop: LENOVO ideapad 110
