using:
Release: 21.2.6
Codename: Qonos
if suspend is triggered then usually the system is not started again properly. It shows some log messages (see attached image). Then I have to power off the notebook by long press of power button.
Any idea if this is just somehow configuration issue? I have not touch system defaults related to power settings till today when I disabled automatic suspend …
System info:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=9ad1f80d-e269-49dc-9909-5b8ef33d6e41 rw quiet
cryptdevice=UUID=f77bd185-1f06-44b7-aa33-9e151a4d14fa:luks-f77bd185-1f06-44b7-aa33-9e151a4d14fa
root=/dev/mapper/luks-f77bd185-1f06-44b7-aa33-9e151a4d14fa splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-8f4a7753-e7c3-4772-8e99-794c1fe1bfcc
udev.log_priority=3
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: Latitude 5401 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0D2RTT v: A00 serial: <filter> UEFI: Dell v: 1.19.1
date: 03/30/2022
ID-1: BAT0 charge: 68.0 Wh (100.0%) condition: 68.0/68.0 Wh (100.0%)
volts: 17.3 min: 15.2 model: SMP DELL 1VY7F8B type: Li-poly serial: <filter>
status: full
RAM: total: 31.14 GiB used: 8.99 GiB (28.9%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM A type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: 80AD000080AD part-no: HMA82GS6JJR8N-VK
serial: <filter>
Device-2: DIMM B type: DDR4 detail: synchronous size: 16 GiB
total: 64 manufacturer: 01980000830B part-no: 9905663-030.A00G
serial: <filter>
Info: model: Intel Core i7-9850H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 986 high: 2639 min/max: 800/4600 base/boost: 4100/4600
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 827 2: 2639 3: 854 4: 800 5: 825 6: 800
7: 800 8: 800 9: 800 10: 889 11: 900 12: 900 bogomips: 62431
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Type: srbds mitigation: TSX disabled
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Dell driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 10de:1d10
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-11:5 chip-ID: 0bda:565c class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x07bb built: 2018 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.0.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bb class-ID: 0200
IF: eno2 state: down mac: <filter>
IF-ID-1: tap0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: link
IF-ID-2: vboxnet0 state: up speed: 10 Mbps duplex: full mac: <filter>
IF-ID-3: vboxnet1 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0aaa class-ID: e001
Device-1: luks-8f4a7753-e7c3-4772-8e99-794c1fe1bfcc maj-min: 254:1
type: LUKS dm: dm-1 size: 34.18 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 34.18 GiB
Device-2: luks-f77bd185-1f06-44b7-aa33-9e151a4d14fa maj-min: 254:0
type: LUKS dm: dm-0 size: 537.11 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 537.11 GiB
Local Storage: total: 931.51 GiB used: 145.49 GiB (15.6%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 34.9 C scheme: GPT
ID-1: / raw-size: 537.11 GiB size: 527.61 GiB (98.23%)
used: 145.44 GiB (27.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-f77bd185-1f06-44b7-aa33-9e151a4d14fa
label: Kejda uuid: 9ad1f80d-e269-49dc-9909-5b8ef33d6e41
used: 46 MiB (15.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: BOOT uuid: 0B0D-59DB
ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-8f4a7753-e7c3-4772-8e99-794c1fe1bfcc label: Swap
uuid: 4dccf771-0b78-4d95-8f9c-fa7862c0f8a3
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p5 maj-min: 259:5 size: 359.91 GiB fs: ntfs label: N/A
uuid: EE3C584B3C5810C7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-10:3 info: Broadcom 58200 type: N/A driver: N/A interfaces: 1
rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 0a5c:5843 class-ID: fe00
serial: <filter>
Device-2: 1-11:5 info: Realtek Integrated_Webcam_HD type: Video
Device-3: 1-14:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C pch: 61.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 426 Uptime: 4h 37m wakeups: 62 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1485
lib: 451 flatpak: 0 Shell: Bash (sudo) v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.15
