New Manjaro install on a laptop I haven’t run Linux on previously. I was under the impression Manjaro would switch to the discrete GPU when load demands, however I don’t believe this is occurring. I’m not familiar with how this is managed in Manjaro (I’ve not run LInux on a dual GPU machine before) but I do seem to be able to force an application to use the dGPU by appending “DRI_PRIME=1” when launching an application. I was under the impression this shouldn’t be required though and the system would switch on demand. Can anyone point me to more info or provide an explanation on how to troubleshoot this?
Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=c644b20e-9513-464b-a581-ea9771b369b5 rw rootflags=subvol=@
quiet splash zswap.enabled=1
resume=UUID=fa33a5cf-fd27-4ff1-95a1-2f401aec0d69 udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Convertible System: Dell product: XPS 15 9575 v: N/A
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
uuid: <superuser required> UEFI: Dell v: 1.28.0 date: 07/11/2023
ID-1: BAT0 charge: 47.3 Wh (100%) condition: 47.3/75 Wh (63.1%) volts: 12.52
min: 11.4 model: BYD DELL TMFYT8C type: Li-poly serial: <filter> charging:
status: full type: trickle avail: adaptive,custom,fast,standard,trickle
cycles: N/A
System RAM: total: 16 GiB available: 15.34 GiB used: 5.46 GiB (35.6%)
Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
part-no: HMAA51S6AMR6N-UH serial: N/A
Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 49618
sgx smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
temp: 47.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 3840x2160
hz: 60 scale: 190% (1.9) to: 2021x1137 dpi: 284 gamma: 1.2 chroma: red:
x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 3840x2160
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 14.98 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
v: 25.2.1-arch1.4 device-ID: 1002:694e surfaces: N/A device: 1
type: integrated-gpu name: Intel HD Graphics 630 (KBL GT2)
driver: mesa intel v: 25.2.1-arch1.4 device-ID: 8086:591b surfaces: N/A
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
class-ID: 0280 temp: 44.0 C
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0489:e0a2
class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 920.39 GiB used: 22.03 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 920.39 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: GPT
ID-1: / raw-size: 500.85 GiB size: 500.85 GiB (100.00%)
used: 22.03 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: Manjaro
uuid: c644b20e-9513-464b-a581-ea9771b369b5
ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
used: 632 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 106B-CBDA
ID-3: /home raw-size: 500.85 GiB size: 500.85 GiB (100.00%)
ID-4: /var/cache raw-size: 500.85 GiB size: 500.85 GiB (100.00%)
ID-5: /var/log raw-size: 500.85 GiB size: 500.85 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.11 GiB used: 268 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: SWAP
uuid: fa33a5cf-fd27-4ff1-95a1-2f401aec0d69
ID-1: /dev/sda4 maj-min: 8:4 size: 401.47 GiB fs: exfat label: USB_Shared
uuid: EBBF-310F
Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
serial: <filter>
Device-2: 1-6:3 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e0a2 class-ID: e001
Device-3: 1-10:4 info: Shenzhen Goodix Fingerprint Reader
type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
Device-1: 2-1:2 info: SanDisk 3.2Gen1 type: mass storage driver: uas
interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:55ab class-ID: 0806
serial: <filter>
System Temperatures: cpu: 55.0 C pch: 53.0 C mobo: 45.0 C sodimm: 44.0 C
gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): cpu: 2477
Packages: pm: pacman pkgs: 1319 libs: 354 tools: pamac pm: flatpak pkgs: 0
1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 340
1: cpu: 22.5% command: firefox pid: 29960 mem: 910.4 MiB (5.7%)
2: cpu: 6.9% command: firefox pid: 32713 mem: 464.9 MiB (2.9%)
3: cpu: 3.7% command: kwin_wayland pid: 1789 mem: 588.2 MiB (3.7%)
4: cpu: 2.2% command: firefox pid: 30175 mem: 315.2 MiB (2.0%)
5: cpu: 1.8% command: firefox pid: 30347 mem: 444.9 MiB (2.8%)
Memory top: 5 of 340
1: mem: 910.4 MiB (5.7%) command: firefox pid: 29960 cpu: 22.5%
2: mem: 588.2 MiB (3.7%) command: kwin_wayland pid: 1789 cpu: 3.7%
3: mem: 464.9 MiB (2.9%) command: firefox pid: 32713 cpu: 6.9%
4: mem: 455.0 MiB (2.8%) command: plasmashell pid: 2029 cpu: 0.2%
5: mem: 444.9 MiB (2.8%) command: firefox pid: 30347 cpu: 1.8%
Processes: 340 Power: uptime: 4h 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,upowerd
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
