Not able to set 4k@120Hz when using receiver, works when connecting directly to display (AMD graphics)
I have an issue where I have Manjaro KDE (Wayland) connected to a Sony Reciever (TA-AN1000) that in turn is connected to a LG C4 display and I cannot use 120Hz as refresh rate as it is capped to 60Hz.
This is a dual boot system and it works fine in Windows 10.
If I connect directly to the C4, 120Hz is available.
The reciever and cables are capable of 120Hz and as mentioned it works in Windows10.
I suspect that the EDID might get screwed up with the reciever connected.
I have been searching around a bit and did not see much that I can do with kscreen-doctor, i did see some X11 posts to add extra modes using xrandr, but that should not be relevant using Wayland?
Any pointers on how to fix this?
inxi -G         ✔
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
    XT/7600M XT/7600S/7700S / PRO W7600] driver: amdgpu v: kernel
  Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
    resolution: 1920x1080
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
    renderer: AMD Radeon RX 7600 (radeonsi navi33 LLVM 18.1.8 DRM 3.59
    6.12.1-4-MANJARO)
  API: Vulkan v: 1.3.295 drivers: radv surfaces: xcb,xlib,wayland
With reciever:
ddcutil detect
Discarding cached sleep adjustment data for bus /dev/i2c-1. EDID has changed.
Invalid display
   I2C bus:  /dev/i2c-1
   DRM connector:           card1-HDMI-A-1
   EDID synopsis:
      Mfg id:               SNY - Sony
      Model:                LG TV SSCR2
      Product code:         1940  (0x0794)
      Manufacture year:     2022,  Week: 44
   DDC communication failed. (getvcp of feature x10 returned Error_Info[EIO in ddc_write_read_with_retry, causes: EIO])
kscreen-doctor -o
Output: 1 HDMI-A-1
        enabled
        connected
        priority 1
        HDMI
        Modes:  1:3840x2160@60*  2:3840x2160@60!  3:4096x2160@60  4:4096x2160@60  5:4096x2160@24  6:4096x2160@24  7:3840x2160@60  8:3840x2160@60  9:3840x2160@50  10:3840x2160@30  11:3840x2160@30  12:3840x2160@25  13:3840x2160@24  14:3840x2160@24  15:1920x1200@60  16:1920x1080@120  17:1920x1080@120  18:1920x1080@100  19:1920x1080@60  20:1920x1080@60  21:1920x1080@50  22:1920x1080@30  23:1920x1080@30  24:1920x1080@24  25:1920x1080@24  26:1600x1200@60  27:1680x1050@60  28:1280x1024@60  29:1440x900@60  30:1280x800@60  31:1280x720@60  32:1280x720@60  33:1280x720@50  34:1024x768@60  35:800x600@60  36:720x576@50  37:720x480@60  38:720x480@60  39:640x480@60  40:640x480@60  41:1600x1200@60  42:1280x1024@60  43:1024x768@60  44:2560x1600@60  45:1920x1200@60  46:1280x800@60  47:3840x2160@60  48:3200x1800@60  49:2880x1620@60  50:2560x1440@60  51:1920x1080@60  52:1600x900@60  53:1368x768@60  54:1280x720@60
        Geometry: 0,0 1920x1080
        Scale: 2
        Rotation: 1
        Overscan: 0
        Vrr: incapable
        RgbRange: unknown
        HDR: enabled
                SDR brightness: 200 nits
                SDR gamut wideness: 0%
                Peak brightness: unknown
                Max average brightness: unknown
                Min brightness: 0 nits
        Wide Color Gamut: enabled
        ICC profile: none
        Color profile source: sRGB
        Brightness control: supported, set to 100%
Directly to display:
 ddcutil detect
Invalid display
   I2C bus:  /dev/i2c-1
   EDID synopsis:
      Mfg id:               GSM - Goldstar Company Ltd (LG)
      Model:                LG TV SSCR2
      Product code:         33485  (0x82cd)
      Manufacture year:     2024,  Week: 1
kscreen-doctor -o         ✔
Output: 1 HDMI-A-1
        enabled
        connected
        priority 1
        HDMI
        Modes:  1:3840x2160@60!  2:4096x2160@120  3:4096x2160@120  4:4096x2160@100  5:4096x2160@60  6:4096x2160@60  7:4096x2160@50  8:4096x2160@30  9:4096x2160@30  10:4096x2160@25  11:4096x2160@24  12:4096x2160@24  13:3840x2160@120*  14:3840x2160@120  15:3840x2160@100  16:3840x2160@60  17:3840x2160@60  18:3840x2160@50  19:3840x2160@30  20:3840x2160@30  21:3840x2160@25  22:3840x2160@24  23:3840x2160@24  24:2560x1440@120  25:1920x1200@60  26:1920x1080@120  27:1920x1080@120  28:1920x1080@100  29:1920x1080@60  30:1920x1080@60  31:1920x1080@60  32:1920x1080@50  33:1920x1080@30  34:1920x1080@30  35:1920x1080@25  36:1920x1080@24  37:1920x1080@24  38:1600x1200@60  39:1680x1050@60  40:1280x1024@60  41:1440x900@60  42:1280x800@60  43:1152x864@60  44:1280x720@60  45:1280x720@60  46:1280x720@50  47:1024x768@60  48:800x600@60  49:720x576@50  50:720x480@60  51:720x480@60  52:720x480@60  53:720x480@60  54:640x480@60  55:640x480@60  56:720x400@70  57:1600x1200@60  58:1280x1024@60  59:1024x768@60  60:2560x1600@60  61:1920x1200@60  62:1280x800@60  63:3840x2160@60  64:3200x1800@60  65:2880x1620@60  66:2560x1440@60  67:1920x1080@60  68:1600x900@60  69:1368x768@60  70:1280x720@60
        Scale: 2
        Rotation: 1
        Overscan: 0
        Vrr: incapable
        RgbRange: unknown
        HDR: enabled
        ICC profile: none
