Hi, this is my first post, so I hope making this right.
I’m new in the linux community, I made the change frome Windows 2 days ago. I’m trying Manjaro, and all works perfectly fine, except I can’t make any gamepad to work on my laptop.
Any advise is welcome, I’m pretty noob, thank you!
Welcome to the forum!
Such as?
Please post the output of lsusb
while the gamepad(s) are connected so we can see their hardware ID’s.
Tip: When pasting terminal output on Discourse forums, one can either…
Highlight it and use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
text
Use HTML:
<pre><code>
text
</pre></code>
This is the output:
Bus 002 Device 003: ID 0955:7002 NVIDIA Corp. NVIDIA stereo controller
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 064e:8127 Suyin Corp. Laptop_Integrated_Webcam_FHD
Bus 001 Device 004: ID 187c:0520 Alienware Corporation M17x
Bus 001 Device 003: ID 413c:8197 Dell Computer Corp. BCM20702A0 Bluetooth Module
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 25a7:fa61 Areson Technology Corp Elecom Co., Ltd MR-K013 Multicard Reader
Bus 003 Device 003: ID 24c6:581a ThrustMaster, Inc. XB1 Classic Controller
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am trying the gamepad, and Manjaro detects it and it works in Big Picture mode in Steam, seems that it doesn’t work with games through Proton (tried with Dark Souls 3 and doesn’t work, but Steam even gives me that “Controller Configuration” prompt while starting the game)
So what can I do?
Thank you for the help
You use Steam? With Steam is the easiest way to config a gamepad. Just run the big picture mode the gamepad configuration and done
I just configured it in big picture mode as you said, but it stills doesn’t work. Any other things that I could do?
Finaly I reinstalled Manjaro, seems to work now (I have to test it with gamemode enabled, but with steam and Proton Experimental worked out of the box). I’ll tell you how it’s going, thank you for your help
Fully working with gamemode
