Hi guys, I’am new in manjaro… arriving from ubuntu, and it’s derivatives such as xubuntu, lubuntu, kubuntu for 15 years and finaly 5 years with linux mint, …and attracted by rolling updates of ARCH strategy and AUR, I give a try to manjaro.
It looks well, and AUR is really full of new software. Anyway, I am struggling so many troubles with manjaro…
somewhere from troubles:
- right after installation, where I was loosing panel (fixed by update),
- than pain to install virtualbox under kernel58, finaly decided to use kernel54 which is LTS
- freezing FortiClient on connecting.
- and finally with broken kernel58 mostly probably by trying to tweak with vbox, but more or less I found always a solution there or there…
Except for this one strange case of locking me out from my opened session.
After period defined for auto locking of screen… Sometimes (not all the times) happens, that there is no login screen, so I’am not able to re-enter into my previous session. I see my lock screen picture, and mouse pointer can move, but no way to bring login field to enter my password.
I found …let say emergency workaround to bring command line by CTL+ALT+F7 and than by typing “startx” I am able to open “probably” new/next instance of my desktop env., but no apps is open there.
Seems that all my previously opened apps are running in the background and I can see them in “task manager” but have no way to bring them back to my freshly started DE. I found some similar topics in this forum, but it was related to graphic drivers mostly for nvidia or AMD. Not my case with internal intel graphic.
So if somebody has some idea, I’ll be glad to try…
I’ve tried other kernels as well, but like it is occasional, I am not able to surely say, it is related to kernel54 or others…
For detail see my inxi here.
inxi --admin --verbosity=7 --filter --no-host
System: Kernel: 5.4.77-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=d37b62f9-df05-4ceb-a809-6c5041ae61c7 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Latitude E7440 v: 00 serial: <filter> Chassis: type: 9 serial: <filter>
Mobo: Dell model: 07F3F4 v: A00 serial: <filter> UEFI: Dell v: A28 date: 06/13/2019
Battery: ID-1: BAT0 charge: 30.3 Wh condition: 30.3/47.1 Wh (64%) volts: 8.5/7.6 model: LGC-LGC6.2 DELL 0D47W44
type: Li-poly serial: <filter> status: Full
Memory: RAM: total: 7.68 GiB used: 2.71 GiB (35.2%)
CPU: Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 L2 cache: 4096 KiB bogomips: 21559
Speed: 2694 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2694 2: 2694 3: 2694 4: 2694
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Device-2: Sunplus Innovation Laptop Integrated Webcam HD type: USB driver: uvcvideo bus ID: 2-4:2
chip ID: 1bcf:2985
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel display ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1182x380mm (46.5x15.0") s-diag: 1242mm (48.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: DP1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.2.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.4.77-1-MANJARO
Network: Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: 3.2.6-k port: f080 bus ID: 00:19.0
chip ID: 8086:155a
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: f040 bus ID: 02:00.0 chip ID: 8086:08b1
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 719.07 GiB used: 327.89 GiB (45.6%)
ID-1: /dev/mmcblk0 model: SU16G size: 14.84 GiB block size: physical: 512 B logical: 512 B serial: <filter>
scheme: MBR
SMART Message: Unknown smartctl error. Unable to get data.
ID-2: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdb vendor: Samsung model: SSD PM851 mSATA 256GB size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8D0Q scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 187.50 GiB size: 184.06 GiB (98.16%) used: 41.42 GiB (22.5%) fs: ext4 dev: /dev/sdb6 label: N/A
uuid: d37b62f9-df05-4ceb-a809-6c5041ae61c7
ID-2: /boot/efi raw size: 100.0 MiB size: 96.0 MiB (96.00%) used: 25.1 MiB (26.1%) fs: vfat dev: /dev/sdb2
label: N/A uuid: 568A-6088
ID-3: /run/timeshift/backup raw size: 411.59 GiB size: 404.13 GiB (98.19%) used: 286.45 GiB (70.9%) fs: ext4
dev: /dev/sda5 label: N/A uuid: 045da513-1be4-46c5-992a-d9070cc24798
Swap: Kernel: swappiness: 40 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 10.00 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
Unmounted: ID-1: /dev/mmcblk0p1 size: 14.83 GiB fs: vfat label: N/A uuid: 8765-4321
ID-2: /dev/sda1 size: 529.0 MiB fs: ntfs label: Recovery uuid: 5A8AB41B8AB3F19D
ID-3: /dev/sda2 size: 99.0 MiB fs: vfat label: N/A uuid: 6EB4-C3F1
ID-4: /dev/sda3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-5: /dev/sda4 size: 48.20 GiB fs: ntfs label: N/A uuid: EA7CCCC27CCC8B31
ID-6: /dev/sdb1 size: 529.0 MiB fs: ntfs label: Recovery uuid: 907C8A117C89F270
ID-7: /dev/sdb3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-8: /dev/sdb4 size: 50.34 GiB fs: ntfs label: N/A uuid: 32588B1F588AE149
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8000
Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:07dc
Device-2: 1-1.5:4 info: Broadcom BCM5880 Secure Applications Processor type: Smart Card driver: N/A interfaces: 2
rev: 1.1 speed: 12 Mb/s chip ID: 0a5c:5800 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 2-4:2 info: Sunplus Innovation Laptop Integrated Webcam HD type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s chip ID: 1bcf:2985
Device-2: 2-6:3 info: Logitech Cordless Mouse Receiver type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 1.5 Mb/s chip ID: 046d:c50e
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 78.0 C mobo: 52.0 C sodimm: 36.0 C
Fan Speeds (RPM): cpu: 5609
Info: Processes: 219 Uptime: 15m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1474 lib: 394 flatpak: 0
Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.08
