Your example is flawed. Try playing a guitar without learning how to play.
What I’m trying to say is that btrfs isn’t a normal filesystem, you need to learn how to use it properly.
It’s an endless discussion. You don’t need to be a doctor to use your own body, how many doctors are need to cover the entire body functionality? Are you specialist on all brain synopsis in order to be able to ready this post? it’s simple works and you trust.
I don’t need to play guitar, and can turn on the radio and listen others playing guitar. We can rely on people.
I appreciate your point of view but i see life more simple.
cya
You’re using inane examples to try to avoid the point. If you want simple, then use a normal filesystem.
As intended. Non-updated systems are not supported. Update your system and if you then still have problems, you can start a new thread, and then we can talk again. But this thread is going nowhere.
Also… ![]()
Manjaro is NOT suitable for everyone No, it’s not. And we — as the helpful community members of this forum — regularly have to explain this to the newcomers. Or at least, if we get the chance, because it is not exactly unheard of that a vocal newbie throws it out there themselves in a fit of frustration — if not arrogance or entitlement, because there’s a lot of that going round as well. So why is Manjaro not a distribution for everyone? 1. Manjaro is a rolling-release distribution This mea…
To install kernel version in this way the terminal forces me to update my system
With good reason
Never sync new packages without doing a full system sync.
Partially sync - that is syncing a new package independently - is unsupported - that will never change.
But you are free to do as you please - you are the system admin - if you run into issues you know why - and you know that you do not ask for help when it occurs.
Example - you want to install linux610 without syncing your system.
sudo pacman -S linux610
If you are relying on kernel headers for DKMS - the be sure to include linux610-headers in the above command.
One important factor - one you have seen many times
Do not ask for help with a poorly maintained system
