Yes I know this topic gets posted on basically a daily basis, but I swear its different this time! Hopefully.
I have already chrooted into my machine from usb and installed a kernel, but grub is not recognizing it? I actually have other kernels installed 519, 518 and it did not recognize those either, the only options available in advanced settings are 515 and 517, but if I try to boot from either of those it gives the error
error: file ‘/boot/vmlinux-(kernel)’ not found
error: you need to load the kernel first.
any suggestions?
this is on my desktop with nvdia graphics
(4/5) Refreshing PackageKit…
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(5/5) Updating Grub-Bootmenu
/etc/default/grub: line 5: splash: command not found
so I installed linux515 and that let my machine boot, but I want to be able to use a more recent kernel than 515, so the problem is not yet fixed because I still cant use any new kernels, and the output of that command was
Currently running: 5.15.60-1-MANJARO (linux515)
linux515
the gui tool still displays 519 and 519rt as being installed
I also ran that command right after I booted and the list was different, it had 515 519 519rt listed as installed, then I ran the uninstall command for 519 and it threw the same errors.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash acpi=force apm=power_off”
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
in /etc/default/grub
you can open it via your text editor, im using kate so the command is: kate /etc/default/grub - you replace kate with the name of the text editor you are using;
or you can navigate there via your file manager
