Not able to boot in
grub
boot
iso
installation
#1
Hey everyone.
So i downloaded Manjaro booted up using a live USB and installed with auto partition (entire disk) and even manually partitioned it all. But still once i click on restart it just wont boot up.
There is an error - Operating system not found.
What should i do because i have tried the installation process using 2 iso’s (GNOME and KDE enviorments) multiple times and still am stuck here.
I have already enabled UEFI booting option and legacy is enabled as well.
Now please please help me up so that i can start learning and working on Manjaro.
#2
from your live iso could you please provide us with the output of the terminal command inxi -Fxzc0
#3
Here is the output or should i send screenshots instead ?
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System: Host: manjaro Kernel: 4.9.50-1-MANJARO x86_64 bits: 64 gcc: 7.2.0 Console: tty 2
Distro: Manjaro Linux
Machine: Device: laptop System: Hewlett-Packard product: HP ProBook 4530s v: A0000C02 serial:
Mobo: Hewlett-Packard model: 167C v: KBC Version 22.1F serial:
BIOS: Hewlett-Packard v: 68SRR Ver. F.0A date: 07/18/2011
Battery BAT0: charge: 42.9 Wh 100.0% condition: 42.9/42.9 Wh (100%)
model: Hewlett-Packard Primary status: Full
CPU: Dual core Intel Core i3-2330M (-HT-MCP-) arch: Sandy Bridge rev.7 cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8784
clock speeds: max: 2200 MHz 1: 799 MHz 2: 799 MHz 3: 839 MHz 4: 800 MHz
Graphics: Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller bus-ID: 00:02.0
Card-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] bus-ID: 01:00.0
Display Server: X.org 1.19.3 drivers: ati,radeon,intel (unloaded: modesetting)
tty size: 168x37 Advanced Data: N/A for root
Audio: Card Intel 6 Series/C200 Series Family High Definition Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.9.50-1-MANJARO
Network: Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k bus-ID: 25:00.0
IF: wlo1 state: up mac:
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 26:00.0
IF: enp38s0 state: down mac:
Drives: HDD Total Size: 504.1GB (3.0% used)
ID-1: USB /dev/sda model: DataTraveler_2.0 size: 4.0GB
ID-2: /dev/sdb model: Hitachi_HTS54755 size: 500.1GB
Partition: ID-1: / size: 4.4G used: 526M (12%) fs: overlay dev: N/A
ID-2: swap-1 size: 9.12GB used: 0.00GB (0%) fs: swap dev: /dev/sdb2
Sensors: System Temperatures: cpu: 57.0C mobo: 56.0C gpu: 56.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 189 Uptime: 6:14 Memory: 1280.0/5906.0MB Init: systemd Gcc sys: 7.2.0
Client: Shell (sudo) inxi: 2.3.38
#5
  1. make sure secure boot is disabled in the BIOS
  2. open gparted (from live iso) and on the disk that you want to install manjaro on go to DEVICE --> create partion table --> GPT (WARNING:this will delete everything on your entire drive)
  3. from the live iso open a terminal and type calamares then the installer should appear go through the entire process and when you are done before shutting down the live session post the entire output of that terminal in the forum (if you can use the hide details on the forum do it)
#6
[manjaro@manjaro ~]$ sudo calamares
Output
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root’
09:23:16 [1]: Calamares version: 3.1.4
Translation: Calamares: Using system locale: "en_US"
09:23:16 [1]: Default font =====
Pixel size: -1
Point size: 9
Point sizeF: 9
Font family: "Sans Serif"
Metric height: 15
09:23:16 [1]: Font height: 15
09:23:16 [1]: Available languages: (“ar”, “ast”, “bg”, “ca”, “cs_CZ”, “da”, “de”, “el”, “en”, “en_GB”, “es_MX”, “es”, “eu”, “fr”, “he”, “hr”, “hu”, “id”, “is”, “it_IT”, “ja”, “lt”, “nl”, “pl”, “pt_BR”, “pt_PT”, “ro”, “ru”, “sk”, “sv”, “th”, “tr_TR”, “zh_CN”, “zh_TW”)
09:23:16 [1]: CalamaresApplication thread: 0x564f30c63d30
09:23:16 [1]: Using log file: "/root/.cache/Calamares/Calamares/Calamares.log"
09:23:16 [1]: Using Calamares settings file at "/etc/calamares/settings.conf"
09:23:16 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
09:23:16 [1]: WARNING: the selected branding component does not ship translations.
09:23:16 [1]: Loaded branding component "manjaro"
09:23:16 [1]: STARTUP: initQmlPath, initSettings, initBranding done
09:23:16 [1]: STARTUP: initModuleManager: module init started
09:23:16 [1]: STARTUP: initModuleManager: all modules init done
09:23:16 [1]: STARTUP: initJobQueue done
09:23:16 [1]: Available size QSize(1366, 723)
09:23:16 [1]: Proposed window size: 1024 540
09:23:16 [1]: STARTUP: CalamaresWindow created; loadModules started
09:23:16 [1]: Initial locale "en_US"
09:23:16 [1]: Welcome string false “Manjaro Linux 17.0 “Gellivara”“
09:23:16 [1]: ViewModule “welcome@welcome” loading complete.
09:23:16 [1]: WARNING: guessLocaleConfiguration can’t guess from an empty list.
09:23:16 [1]: ViewModule “locale@locale” loading complete.
09:23:17 [1]: ViewModule “keyboard@keyboard” loading complete.
09:23:17 [1]: ViewModule “partition@partition” loading complete.
09:23:17 [1]: ViewModule “users@users” loading complete.
09:23:17 [1]: ViewModule “summary@summary” loading complete.
09:23:17 [1]: Module “partition@partition” already loaded.
09:23:17 [1]: QML import paths: (”/usr/share/calamares/qml”, “/usr/bin”, “qrc:/qt-project.org/imports”, “/usr/lib/qt/qml”)
09:23:17 [1]: Module “locale@locale” already loaded.
09:23:17 [1]: Module “keyboard@keyboard” already loaded.
09:23:17 [1]: Module “users@users” already loaded.
09:23:17 [1]: FinishedPage()
09:23:17 [1]: ViewModule “finished@finished” loading complete.
09:23:17 [1]: STARTUP: loadModules for all modules done
09:23:17 [1]: STARTUP: Window now visible and ProgressTreeView populated
09:23:17 [1]: Need at least storage bytes: 8482560409
09:23:17 [1]: Need at least ram bytes: 1073741824
09:23:17 [1]: A battery exists, checking for mains power.
09:23:17 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot: true true true true true
09:23:18 [1]: xkbmap selection changed to: “us” - ""
09:23:18 [0]: blkid: unknown file system type “iso9660” on "/dev/sda1"
09:23:18 [1]: Removing unsuitable devices: 2 candidates.
09:23:18 [1]: … Removing device with iso9660 filesystem (probably a CD) on it "/dev/sda"
09:23:19 [1]: LIST OF DETECTED DEVICES:
09:23:19 [1]: node capacity name prettyName
09:23:19 [1]: “/dev/sdb” 500105249280 “ATA Hitachi HTS54755” "ATA Hitachi HTS54755 – 465.76 GiB (/dev/sdb)"
09:23:19 [1]: … 1 devices detected.
09:23:19 [1]: WARNING: guessLocaleConfiguration can’t guess from an empty list.
09:23:19 [1]: "Osprober lines, clean:\n"
09:23:19 [1]: Updating partitioning state widgets.
09:23:19 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
09:23:19 [1]: Required storage B: 9019431321 "(8GB)"
09:23:19 [1]: Storage capacity B: 500107827712 “(465GB)” for “” length: 976773101
09:23:19 [1]: Partition “” authorized for replace install.
09:23:19 [1]: Updating partitioning preview widgets.
14:23:21 [1]: WARNING: guessLocaleConfiguration can’t guess from an empty list.
09:23:21 [1]: WARNING: guessLocaleConfiguration can’t guess from an empty list.
18:53:30 [1]: Got locale language "en_IN"
18:53:30 [1]: … extracted country “India” :: (“en”, “IN”)
18:53:30 [1]: … looking for locale part "IN"
18:53:30 [1]: … matched "in"
18:53:31 [1]: xkbmap selection changed to: “in” - ""
18:53:33 [1]: xkbmap selection changed to: “in” - "eng"
18:53:39 [1]: CreatePartitionTableJob::createTable trying to make table for device "/dev/sdb"
18:53:39 [1]: Suggested swap size: 8.8 GiB
18:53:39 [1]: # Queue:
18:53:39 [1]: ## Device: "ATA Hitachi HTS54755"
18:53:39 [1]: - "Create new msdos partition table on /dev/sdb."
18:53:39 [1]: - "Create new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4."
18:53:39 [1]: - "Create new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap."
18:53:39 [1]: Updating partitioning preview widgets.
18:53:49 [1]: PCM::setBootLoaderInstallPath "/dev/sdb"
18:54:07 [0]: QLayout: Attempting to add QLayout “” to QWidget “”, which already has a layout
18:54:07 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
18:54:07 [1]: Creating FillGlobalStorageJob with bootLoader path “/dev/sdb"
18:54:07 [1]: PartitionCodeModule has been asked for jobs. About to return: “Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sdb\nCreate new msdos partition table on /dev/sdb.\nCreate new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4.\nCreate new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap.\nSet partition information"
18:54:07 [1]: Gathering UUIDs for partitions that exist now.
18:54:07 [1]: QHash((””, “”))
18:54:07 [1]: Writing to GlobalStorage[“partitions”]
18:54:07 [1]: “” mtpoint: “/” fs: QVariant(QString, “ext4”) ( QVariant(QString, “ext4”) ) ""
18:54:07 [1]: “” mtpoint: “” fs: QVariant(QString, “linuxswap”) ( QVariant(QString, “linuxswap”) ) ““
18:54:07 [1]: “” mtpoint: “” fs: QVariant(QString, “linuxswap”) ( QVariant(QString, “linuxswap”) ) ""
18:54:07 [1]: Summary widget is larger than viewport, enlarge by 36 to QSize(826, 529)
18:54:46 [1]: Updating partitioning preview widgets.
18:54:47 [1]: Updating partitioning preview widgets.
18:54:48 [1]: PCM::setBootLoaderInstallPath "/dev/sdb"
18:54:48 [1]: CreatePartitionTableJob::createTable trying to make table for device "/dev/sdb"
18:54:48 [1]: Suggested swap size: 8.8 GiB
18:54:48 [1]: # Queue:
18:54:48 [1]: ## Device: "ATA Hitachi HTS54755"
18:54:48 [1]: - "Create new msdos partition table on /dev/sdb."
18:54:48 [1]: - "Create new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4."
18:54:48 [1]: - "Create new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap."
18:54:50 [1]: Clicked row 0
18:54:59 [1]: PCM::setBootLoaderInstallPath "/dev/sdb"
18:54:59 [0]: QLayout: Attempting to add QLayout “” to QWidget “”, which already has a layout
18:54:59 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
18:54:59 [1]: Creating FillGlobalStorageJob with bootLoader path “/dev/sdb"
18:54:59 [1]: PartitionCodeModule has been asked for jobs. About to return: “Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sdb\nCreate new msdos partition table on /dev/sdb.\nCreate new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4.\nCreate new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap.\nSet partition information"
18:54:59 [1]: Gathering UUIDs for partitions that exist now.
18:54:59 [1]: QHash((””, “”))
18:54:59 [1]: Writing to GlobalStorage[“partitions”]
18:54:59 [1]: “” mtpoint: “/” fs: QVariant(QString, “ext4”) ( QVariant(QString, “ext4”) ) ""
18:54:59 [1]: “” mtpoint: “” fs: QVariant(QString, “linuxswap”) ( QVariant(QString, “linuxswap”) ) ““
18:54:59 [1]: “” mtpoint: “” fs: QVariant(QString, “linuxswap”) ( QVariant(QString, “linuxswap”) ) ""
18:55:04 [1]: Creating FillGlobalStorageJob with bootLoader path "/dev/sdb"
18:55:04 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sdb\nCreate new msdos partition table on /dev/sdb.\nCreate new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4.\nCreate new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap.\nSet partition information"
18:55:04 [0]: Starting job "Clear all temporary mounts."
18:55:04 [1]: Opened mtab. Lines:
18:55:04 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
18:55:04 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
18:55:04 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=3002344k,nr_inodes=750586,mode=755 0 0"
18:55:04 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
18:55:04 [1]: "/dev/sda1 /run/miso/bootmnt iso9660 ro,relatime 0 0"
18:55:04 [1]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
18:55:04 [1]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=4535776k,mode=755 0 0"
18:55:04 [1]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
18:55:04 [1]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
18:55:04 [1]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
18:55:04 [1]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
18:55:04 [1]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work 0 0"
18:55:04 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
18:55:04 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
18:55:04 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
18:55:04 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
18:55:04 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
18:55:04 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
18:55:04 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
18:55:04 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
18:55:04 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
18:55:04 [1]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
18:55:04 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
18:55:04 [1]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
18:55:04 [1]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
18:55:04 [1]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=604768k,mode=700,uid=1000,gid=1000 0 0"
18:55:04 [1]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
18:55:04 [1]: “gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
18:55:04 [1]: ClearTempMountsJob finished. Here’s what was done:
18:55:04 [0]: Starting job “Clear mounts for partitioning operations on /dev/sdb"
18:55:04 [1]: ClearMountsJob finished. Here’s what was done:
18:55:04 [0]: Starting job "Create new msdos partition table on /dev/sdb."
18:55:04 [1]: CreatePartitionTableJob::createTable trying to make table for device "/dev/sdb"
18:55:04 [1]: Creating new partition table of type “msdos” , uncommitted yet:
true
18:55:04 [1]: lsblk:
"NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT\nloop0 7:0 0 6.4M 1 loop /run/miso/sfs/livefs\nloop1 7:1 0 239M 1 loop /run/miso/sfs/mhwdfs\nloop2 7:2 0 1.2G 1 loop /run/miso/sfs/desktopfs\nloop3 7:3 0 399.4M 1 loop /run/miso/sfs/rootfs\nsda 8:0 1 3.8G 0 disk \n\xE2\x94\x9C\xE2\x94\x80sda1 8:1 1 1.9G 0 part /run/miso/bootmnt\n\xE2\x94\x94\xE2\x94\x80sda2 8:2 1 4M 0 part \nsdb 8:16 0 465.8G 0 disk \nsr0 11:0 1 1024M 0 rom \nsr1 11:1 1 18.1M 0 rom \n"
18:55:04 [1]: mount:
"proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)\nsys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)\ndev on /dev type devtmpfs (rw,nosuid,relatime,size=3002344k,nr_inodes=750586,mode=755)\nrun on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755)\n/dev/sda1 on /run/miso/bootmnt type iso9660 (ro,relatime)\ncowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755)\noverlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=4535776k,mode=755)\n/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime)\n/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime)\n/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime)\n/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime)\noverlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work)\nsecurityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)\ntmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)\ndevpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)\ntmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)\ncgroup on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relatime)\ncgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,name=systemd)\npstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)\ncgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)\ncgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)\ncgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)\ncgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)\ncgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)\ncgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)\ncgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)\ncgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)\ncgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)\nsystemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)\nmqueue on /dev/mqueue type mqueue (rw,relatime)\ndebugfs on /sys/kernel/debug type debugfs (rw,relatime)\ntmpfs on /tmp type tmpfs (rw,nosuid,nodev)\nhugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)\nconfigfs on /sys/kernel/config type configfs (rw,relatime)\ntmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755)\ntmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=604768k,mode=700,uid=1000,gid=1000)\nfusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)\ngvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)\n"
18:55:05 [0]: Starting job "Create new 467925MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system ext4.“
18:55:33 [0]: Starting job “Create new 9011MB partition on /dev/sdb (ATA Hitachi HTS54755) with file system linuxswap.“
18:55:37 [0]: Starting job “Set partition information"
18:55:37 [1]: Gathering UUIDs for partitions that exist now.
18:55:37 [1]: QHash((”/dev/sdb1”, “3b5f76e8-db4d-4bd6-9c1f-7a2def97d64e”)(”/dev/sdb2”, “9d8dbe6f-3614-47ac-a1f4-b76008b0e3a7”))
18:55:37 [1]: Writing to GlobalStorage[“partitions”]
18:55:37 [1]: “/dev/sdb1” mtpoint: “/” fs: QVariant(QString, “ext4”) ( QVariant(QString, “ext4”) ) "3b5f76e8-db4d-4bd6-9c1f-7a2def97d64e"
18:55:37 [1]: “/dev/sdb2” mtpoint: “” fs: QVariant(QString, “linuxswap”) ( QVariant(QString, “linuxswap”) ) "9d8dbe6f-3614-47ac-a1f4-b76008b0e3a7"
18:55:37 [1]: FillGlobalStorageJob writing bootLoader path: QVariant(QVariantMap, QMap((“installPath”, QVariant(QString, “/dev/sdb”))))
18:55:37 [0]: Starting job "mount"
18:55:38 [1]: Job file "/usr/lib/calamares/modules/mount/main.py"
18:55:38 [1]: Job “mount” (doc) -> "Define mountpoints."
18:55:38 [0]: Starting job "unpackfs"
18:55:38 [1]: Job file "/usr/lib/calamares/modules/unpackfs/main.py"
18:55:38 [1]: Job “unpackfs” (doc) -> "Unsquash filesystem."
mount: /tmp/tmpv163enev/rootfs: WARNING: device write-protected, mounted read-only.
mount: /tmp/tmpv163enev/desktopfs: WARNING: device write-protected, mounted read-only.
19:03:07 [0]: Starting job "networkcfg"
19:03:07 [1]: Job file "/usr/lib/calamares/modules/networkcfg/main.py"
19:03:07 [1]: Job “networkcfg” (doc) -> “Setup network configuration"
19:03:07 [0]: Starting job “machineid"
19:03:07 [1]: Standard paths (”/home/manjaro”, “/usr/bin”, “/usr/share/locale”)
19:03:07 [1]: Checking “en_IN” in "/home/manjaro"
19:03:07 [1]: Checking “en_IN” in "/usr/bin"
19:03:07 [1]: Checking “en_IN” in "/usr/share/locale"
19:03:07 [1]: Checking “en” in “/home/manjaro"
19:03:07 [1]: Checking “en” in “/usr/bin"
19:03:07 [1]: Checking “en” in “/usr/share/locale"
19:03:07 [1]: Job file “/usr/lib/calamares/modules/machineid/main.py"
19:03:07 [1]: Job “machineid” (doc) -> “Generate machine-id using dbus and systemd.“
19:03:07 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemd-machine-id-setup”)
19:03:15 [0]: Finished. Exit code: 0
19:03:15 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “ln”, “-s”, “/etc/machine-id”, “/var/lib/dbus/machine-id”)
19:03:16 [0]: Finished. Exit code: 0
19:03:16 [0]: Starting job “fstab"
19:03:16 [1]: Job file “/usr/lib/calamares/modules/fstab/main.py"
19:03:16 [1]: Job “fstab” (doc) -> “Configures fstab.“
19:03:18 [0]: Starting job “Set timezone to Asia/Kolkata"
19:03:18 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “rm”, “-f”, “/etc/localtime”)
19:03:18 [0]: Finished. Exit code: 0
19:03:18 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “ln”, “-s”, “/usr/share/zoneinfo/Asia/Kolkata”, “/etc/localtime”)
19:03:18 [0]: Starting job “Set keyboard model to pc105, layout to in-eng"
19:03:18 [1]: Executing SetKeyboardLayoutJob
19:03:18 [1]: Trying to use X11 layout “in” as the virtual console layout
19:03:18 [1]: Written KEYMAP= “in” to vconsole.conf
19:03:18 [1]: Written XkbLayout “in” ; XkbModel “pc105” ; XkbVariant “eng” to X.org file “/tmp/calamares-root-r2lu8js9/etc/X11/xorg.conf.d/00-keyboard.conf"
19:03:18 [1]: Written XKBMODEL “pc105” ; XKBLAYOUT “in” ; XKBVARIANT “eng” to /etc/default/keyboard file “/tmp/calamares-root-r2lu8js9/etc/default/keyboard"
19:03:18 [0]: Starting job “localecfg"
19:03:18 [1]: Job file “/usr/lib/calamares/modules/localecfg/main.py"
19:03:18 [1]: Job “localecfg” (doc) -> “Create locale"
19:03:18 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “locale-gen”)
19:03:23 [0]: Finished. Exit code: 0
locale.gen done
19:03:23 [0]: Starting job “luksopenswaphookcfg"
19:03:23 [1]: Job file “/usr/lib/calamares/modules/luksopenswaphookcfg/main.py"
19:03:23 [1]: Job “luksopenswaphookcfg” (doc) -> “This module sets up the openswap hook for a resumable encrypted swap.“
19:03:23 [0]: Starting job “luksbootkeyfile"
19:03:23 [1]: Job file “/usr/lib/calamares/modules/luksbootkeyfile/main.py"
19:03:23 [1]: Job “luksbootkeyfile” (doc) -> “This module sets up a file crypto_keyfile.bin on the rootfs, assuming the"
19:03:23 [0]: Starting job “initcpiocfg"
19:03:23 [1]: Job file “/usr/lib/calamares/modules/initcpiocfg/main.py"
19:03:23 [1]: Job “initcpiocfg” (doc) -> “Calls routine with given parameters to modify ‘/etc/mkinitcpio.conf’.“
19:03:23 [0]: Starting job “initcpio"
19:03:23 [1]: Job file “/usr/lib/calamares/modules/initcpio/main.py"
19:03:23 [1]: Job “initcpio” (doc) -> “Calls routine to create kernel initramfs image.“
19:03:23 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mkinitcpio”, “-p”, “linux49”)
19:03:45 [0]: Finished. Exit code: 0
19:03:45 [0]: Starting job “Create user lalit"
19:03:45 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “useradd”, “-m”, “-s”, “/bin/bash”, “-U”, “-c”, “Lalit”, “lalit”)
19:04:00 [0]: Finished. Exit code: 0
19:04:00 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “usermod”, “-aG”, “video,power,storage,optical,network,lp,scanner,wheel,sys”, “lalit”)
19:04:00 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “chown”, “-R”, “lalit:lalit”, “/home/lalit”)
19:04:00 [0]: Starting job “Set password for user lalit"
19:04:00 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “usermod”, “-p”, “$6$pMblEr5SDjNI/Vaz$Q2ACXObkPZBqmOo9vU/E7y5vzQI/L3P6P4.MSQGQHbBlpfxu5VJECiBXtCY3xne00a/mhL3z9KEoykwPzspnI/”, “lalit”)
19:04:01 [0]: Finished. Exit code: 0
19:04:01 [0]: Starting job “Set password for user root"
19:04:01 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “usermod”, “-p”, “$6$S8Dmb292OUbAa01N$BMnHRT6hHQn/NXeNBmNxKe1hJDujslDKzFrJFgIDdU7UVLHkupTKl2uIFv/EygZJj5HSV2V3SyrDKpMI9SZEs0”, “root”)
19:04:01 [0]: Starting job “Set hostname Destroyer"
19:04:01 [0]: Starting job “displaymanager"
19:04:01 [1]: Job file “/usr/lib/calamares/modules/displaymanager/main.py"
19:04:01 [1]: Job “displaymanager” (doc) -> “Configure display managers.“
19:04:01 [1]: [PYTHON JOB]: “slim selected but not installed"
19:04:01 [1]: [PYTHON JOB]: “lightdm selected but not installed"
19:04:01 [1]: [PYTHON JOB]: “gdm selected but not installed"
19:04:01 [1]: [PYTHON JOB]: “mdm selected but not installed"
19:04:01 [1]: [PYTHON JOB]: “lxdm selected but not installed"
19:04:01 [1]: [PYTHON JOB]: “Unsetting autologin.“
19:04:01 [0]: Starting job “mhwdcfg"
19:04:01 [1]: Job file “/usr/lib/calamares/modules/mhwdcfg/main.py"
19:04:01 [1]: Job “mhwdcfg” (doc) -> “Configure the hardware"
19:04:01 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mhwd”, “-a”, “pci”, “free”, “0200”, “–pmconfig”, “/opt/pacman-mhwd.conf”)
19:04:36 [0]: Finished. Exit code: 0
19:04:36 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mhwd”, “-a”, “pci”, “free”, “0280”, “–pmconfig”, “/opt/pacman-mhwd.conf”)
19:04:37 [0]: Finished. Exit code: 0
19:04:37 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mhwd”, “-a”, “pci”, “free”, “0300”, “–pmconfig”, “/opt/pacman-mhwd.conf”)
19:04:39 [0]: Finished. Exit code: 0
19:04:39 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mhwd”, “-a”, “pci”, “free”, “0302”, “–pmconfig”, “/opt/pacman-mhwd.conf”)
19:04:40 [0]: Finished. Exit code: 0
19:04:40 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “mhwd”, “-a”, “pci”, “free”, “0380”, “–pmconfig”, “/opt/pacman-mhwd.conf”)
19:04:41 [0]: Finished. Exit code: 0
19:04:41 [0]: Starting job “hwclock"
19:04:41 [1]: Job file “/usr/lib/calamares/modules/hwclock/main.py"
19:04:41 [1]: Job “hwclock” (doc) -> “Set hardware clock.“
19:04:42 [0]: Starting job “services"
19:04:42 [1]: Job file “/usr/lib/calamares/modules/services/main.py"
19:04:42 [1]: Job “services” (doc) -> “Setup systemd services"
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “avahi-daemon.service”)
19:04:42 [0]: Finished. Exit code: 0
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “bluetooth.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “cronie.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “ModemManager.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “NetworkManager.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “org.cups.cupsd.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “tlp.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “tlp-sleep.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “sddm.service”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “enable”, “graphical.target”)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “systemctl”, “disable”, “pacman-init.service”)
19:04:42 [0]: Starting job “grubcfg"
19:04:42 [1]: Job file “/usr/lib/calamares/modules/grubcfg/main.py"
19:04:42 [1]: Job “grubcfg” (doc) -> “Calls routine with given parameters to modify ‘/etc/default/grub’.“
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “sh”, “-c”, “which dracut”)
19:04:42 [0]: Finished. Exit code: 1
19:04:42 [0]: Target cmd (“sh”, “-c”, “which dracut”)
19:04:42 [0]: Target out “which: no dracut in (/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)“
19:04:42 [0]: Starting job “bootloader"
19:04:42 [1]: Job file “/usr/lib/calamares/modules/bootloader/main.py"
19:04:42 [1]: Job “bootloader” (doc) -> “Starts procedure and passes ‘fw_type’ to other routine.“
Bootloader: grub (bios)
19:04:42 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “grub-install”, “–target=i386-pc”, “–recheck”, “–force”, “/dev/sdb”)
19:05:33 [0]: Finished. Exit code: 0
19:05:33 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “grub-mkconfig”, “-o”, “/boot/grub/grub.cfg”)
19:05:56 [0]: Finished. Exit code: 0
19:05:56 [0]: Starting job “postcfg"
19:05:56 [1]: Job file “/usr/lib/calamares/modules/postcfg/main.py"
19:05:56 [1]: Job “postcfg” (doc) -> “Misc postinstall configurations"
19:05:56 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “pacman-key”, “–init”)
19:05:57 [0]: Finished. Exit code: 0
19:05:57 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “pacman-key”, “–populate”, “archlinux”, “manjaro”)
19:06:00 [0]: Finished. Exit code: 0
19:06:00 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “pacman-mirrors”, “-g”, “–geoip”)
19:10:51 [0]: Finished. Exit code: 0
19:10:51 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “killall”, “-9”, “gpg-agent”)
19:10:51 [0]: Running “chroot” (”/tmp/calamares-root-r2lu8js9”, “update-grub”)
19:11:10 [0]: Finished. Exit code: 0
19:11:10 [0]: Starting job "umount"
19:11:10 [1]: Job file "/usr/lib/calamares/modules/umount/main.py"
19:11:10 [1]: Job “umount” (doc) -> "Unmounts given mountpoints in decreasing order."
umount: /tmp/calamares-root-r2lu8js9/sys (sys) unmounted
umount: /tmp/calamares-root-r2lu8js9/run/udev (run) unmounted
umount: /tmp/calamares-root-r2lu8js9/run (tmpfs) unmounted
umount: /tmp/calamares-root-r2lu8js9/proc (proc) unmounted
umount: /tmp/calamares-root-r2lu8js9/dev (dev) unmounted
umount: /tmp/calamares-root-r2lu8js9 (/dev/sdb1) unmounted
19:11:11 [1]: FinishedPage::setUpRestart()
19:11:11 [1]: Could not get dbus interface for notifications. QDBusError(“org.freedesktop.DBus.Error.Disconnected”, “Not connected to D-Bus server”)
19:12:02 [0]: QBasicTimer::start: QBasicTimer can only be used with threads started with QThread
#7
Still the same :confused:
#8
Have you tried wiping clean your hard disk?
#9
Already did multiple times.
That didn’t helped at all.
#10
Did you install grub on any of your disks?
#11
I didn’t installed anything manually
I just did the installation from the installer and selected the bootloader location to the hard drive
(/dev/sdb in my case)
#12
Try booting up with the install usb plugged in.
If that boots the installed OS, let us know, we’ll fix it.
If that does not boot up, look up the installation wiki again and see if there’s something you missed, like…
disable secure boot
burning iso (rfus with dd, not unetbootin)
uefi mount points
partitioning
installing bootloader
more…
#13
What should i do now ?
I was able to install it somehow
But now this. What should i do now
#14
I have no idea. Can somebody else help OP on this kvm thingy? Thanks.
#15
Leave it.
I posted a separate post for this. And people told me that this is harmless.
So i don’t have to worry.
Thank you :slight_smile:
#16
