No one noticed this above? ![]()
So, should I just enable ehci-hcd?
EDIT. I cannot modprobe that. I mean, I copy the command, but it still says inactive.
sudo modprobe ehci-hcd ✔
[sudo] contraseña para juegos:
~ hwinfo --usb-ctrl ✔
19: PCI 1a.0: 0c03 USB Controller (EHCI)
[Created at pci.386]
Unique ID: pwJ7.qHlUcQHlAr4
SysFS ID: /devices/pci0000:00/0000:00:1a.0
SysFS BusID: 0000:00:1a.0
Hardware Class: usb controller
Model: "Intel 7 Series/C216 Chipset Family USB Enhanced Host Controller #2"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x1e2d "7 Series/C216 Chipset Family USB Enhanced Host Controller #2"
SubVendor: pci 0x1849 "ASRock Incorporation"
SubDevice: pci 0x1e2d "Motherboard"
Revision: 0x04
Driver: "ehci-pci"
Memory Range: 0xf7118000-0xf71183ff (rw,non-prefetchable)
IRQ: 16 (1363565 events)
Module Alias: "pci:v00008086d00001E2Dsv00001849sd00001E2Dbc0Csc03i20"
Driver Info #0:
Driver Status: ehci-hcd is not active
Driver Activation Cmd: "modprobe ehci-hcd"
Config Status: cfg=new, avail=yes, need=no, active=unknown
20: PCI 1d.0: 0c03 USB Controller (EHCI)
Unique ID: 1GTX.c31EYdaVLv8
SysFS ID: /devices/pci0000:00/0000:00:1d.0
SysFS BusID: 0000:00:1d.0
Model: "Intel 7 Series/C216 Chipset Family USB Enhanced Host Controller #1"
Device: pci 0x1e26 "7 Series/C216 Chipset Family USB Enhanced Host Controller #1"
SubDevice: pci 0x1e26 "Motherboard"
Revision: 0x04
Driver: "ehci-pci"
Memory Range: 0xf7117000-0xf71173ff (rw,non-prefetchable)
IRQ: 23 (31769 events)
Module Alias: "pci:v00008086d00001E26sv00001849sd00001E26bc0Csc03i20"
Driver Info #0:
22: PCI 14.0: 0c03 USB Controller (XHCI)
Unique ID: MZfG.CQgI4bIwhU3
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Model: "Intel 7 Series/C210 Series Chipset Family USB xHCI Host Controller"
Device: pci 0x1e31 "7 Series/C210 Series Chipset Family USB xHCI Host Controller"
SubDevice: pci 0x1e31 "Motherboard"
Revision: 0x04
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0xf7100000-0xf710ffff (rw,non-prefetchable)
IRQ: 26 (72 events)
Module Alias: "pci:v00008086d00001E31sv00001849sd00001E31bc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
I have a file in /etc/modules-load.d called usb3.conf
In this file, it contains:
xhci_pci
xhci_pci_renesas
Maybe adding here something?
Go into your BIOS, look for the section containing USB settings. Make sure xhci is enabled in BIOS. I could be more precise if I downloaded your specific mainboard manual, but frankly, I can’t be bothered.
Sleep is beckoning. Cheers.
I added the line to grub.
But I could not find IOMMU in Bios. The Bios says VT-d is not supported.
In BIOS, USB setup, there’s the following:
USB 2.0 --- Enabled
USB 3.0 --- Enabled
Legacy USB 2.0 --- Enabled
Legacy USB 3.0 --- Enabled
Description of Legacy USB 3.0 mentions XHCI.
All are enabled. That is usually the desired state. Now, activate ehci-hcd as @Yochanan previously highlighted:
Then check that your USB ports are working (a reboot will likely be required). That is all.
I did it. They are still not working. Moreso, after typing sudo modprobe ehci-hcd, it still doesn’t show as active when checking with hwinfo --usb-ctrl.
Rebooting does nothing.
I’ve tried a few devices in the usb3.0 ports. PS gamepad does not come to live, neither does Bt antenna, nor WiFi antenna. My smartphone at least can get some charge in the rear usb ports, but not in the front. When charging the smartphone in the front 3.0 port, it flickers, as if it was trying to detect it constantly.
It also does not show ehci_pci in /proc/modules.
Why is ehci-hcd not being loaded to active modules?
Maybe this helps.
sudo dmesg | grep -i usb 1 ✘
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=ac2436c3-b1a8-4a26-813f-cfa4913cea81 rw quiet splash udev.log_priority=3 usbcore.autosuspend=-1
[ 0.042322] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64 root=UUID=ac2436c3-b1a8-4a26-813f-cfa4913cea81 rw quiet splash udev.log_priority=3 usbcore.autosuspend=-1
[ 0.198762] ACPI: bus type USB registered
[ 0.198762] usbcore: registered new interface driver usbfs
[ 0.198762] usbcore: registered new interface driver hub
[ 0.198762] usbcore: registered new device driver usb
[ 0.238695] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x7d0 took 21901 usecs
[ 0.262038] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x7d0 took 22779 usecs
[ 0.366694] usbcore: registered new interface driver usbserial_generic
[ 0.366701] usbserial: USB Serial support registered for generic
[ 0.367032] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.381952] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.382040] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.382044] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.382046] usb usb1: Product: EHCI Host Controller
[ 0.382047] usb usb1: Manufacturer: Linux 6.6.8-2-MANJARO ehci_hcd
[ 0.382049] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.382219] hub 1-0:1.0: USB hub found
[ 0.382460] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.401928] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.402001] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.402005] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.402008] usb usb2: Product: EHCI Host Controller
[ 0.402010] usb usb2: Manufacturer: Linux 6.6.8-2-MANJARO ehci_hcd
[ 0.402012] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.402200] hub 2-0:1.0: USB hub found
[ 0.631944] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.651943] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 0.778945] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.778949] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.779211] hub 1-1:1.0: USB hub found
[ 0.798946] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 0.798950] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.799253] hub 2-1:1.0: USB hub found
[ 1.058595] usb 1-1.5: new full-speed USB device number 3 using ehci-pci
[ 1.079387] usb 2-1.5: new low-speed USB device number 3 using ehci-pci
[ 1.092003] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.177202] usb 1-1.5: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 1.177208] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 1.177209] usb 1-1.5: Product: CSR8510 A10
[ 1.200358] usb 2-1.5: New USB device found, idVendor=046d, idProduct=c31b, bcdDevice=60.00
[ 1.200363] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.200364] usb 2-1.5: Product: Logitech USB Keyboard
[ 1.200366] usb 2-1.5: Manufacturer: Logitech
[ 1.221475] input: Logitech Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:046D:C31B.0001/input/input2
[ 1.250687] usb 1-1.6: new high-speed USB device number 4 using ehci-pci
[ 1.277350] usb 2-1.6: new low-speed USB device number 4 using ehci-pci
[ 1.277566] hid-generic 0003:046D:C31B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech Logitech USB Keyboard] on usb-0000:00:1d.0-1.5/input0
[ 1.285610] input: Logitech Logitech USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:046D:C31B.0002/input/input3
[ 1.340786] input: Logitech Logitech USB Keyboard System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:046D:C31B.0002/input/input4
[ 1.340864] hid-generic 0003:046D:C31B.0002: input,hidraw1: USB HID v1.11 Device [Logitech Logitech USB Keyboard] on usb-0000:00:1d.0-1.5/input1
[ 1.340905] usbcore: registered new interface driver usbhid
[ 1.340907] usbhid: USB HID core driver
[ 1.348461] usb 1-1.6: New USB device found, idVendor=0bda, idProduct=0811, bcdDevice= 2.00
[ 1.348466] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.348467] usb 1-1.6: Product: 802.11ac WLAN Adapter
[ 1.348469] usb 1-1.6: Manufacturer: Realtek
[ 1.348470] usb 1-1.6: SerialNumber: 00e04c000001
[ 1.378363] usb 2-1.6: New USB device found, idVendor=046d, idProduct=c077, bcdDevice=72.00
[ 1.378368] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.378369] usb 2-1.6: Product: USB Optical Mouse
[ 1.378371] usb 2-1.6: Manufacturer: Logitech
[ 1.380679] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.6/2-1.6:1.0/0003:046D:C077.0003/input/input5
[ 1.380752] hid-generic 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.6/input0
[ 19.153592] xhci_hcd 0000:00:14.0: USB bus 3 deregistered
[ 23.625344] usbcore: registered new interface driver btusb
[ 23.773165] usbcore: registered new interface driver rtl8821au
[ 23.923745] usbcore: registered new interface driver rtl88XXau
[ 175.475298] usb 1-1.6: USB disconnect, device number 4
[ 215.617319] usb 1-1.6: new high-speed USB device number 5 using ehci-pci
[ 215.715133] usb 1-1.6: New USB device found, idVendor=0bda, idProduct=0811, bcdDevice= 2.00
[ 215.715141] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 215.715144] usb 1-1.6: Product: 802.11ac WLAN Adapter
[ 215.715146] usb 1-1.6: Manufacturer: Realtek
[ 215.715148] usb 1-1.6: SerialNumber: 00e04c000001
A good question, however my only answer has to be
I think it was previously established that you don’t have a renesas chipset/controller/other in your system. It might pay to comment or remove the xhci_pci_renesas line from:
/etc/modules-load.d/usb3.conf
and again try sudo modprobe ehci-hcd, followed by a reboot.
ehci is still refusing to load.
I am wondering, there’s xhci-hcd module which says it is active, but in the module.d/usb3.config file, only xhci-pci is showing.
This is lsmod output:
lsmod | grep xhci 127 ✘
xhci_pci 28672 0
xhci_pci_renesas 24576 1 xhci_pci
See? xhci_hdc is not there.
again, use a live-iso and check if usb is working with it or if there is a general malfunction. anything else is playing jeopardy.
Ok, this is weird.
My live-usb intiates correctly in the rear usb3.0 but not from the front usb3.0. Rear port is integrated in the motherboard, while front port is connected to the motherboard by a cable, I should check it.
Rear usb3.0 is now able to read a pendrive, but only if I leave it connected before rebooting. Gamepad is detected in the rear if it is connected before rebooting too. However, Wifi antenna is never detected in the 3.0 port.
In other words, only a few devices are detected, but never on the go.
This is now poking in the fog:
lsusb -t ✔
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/10p, 480M
|__ Port 005: Dev 002, If 0, Class=Vendor Specific Class, Driver=ati_remote, 1.5M
|__ Port 006: Dev 003, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 001: Dev 004, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 001: Dev 004, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 001: Dev 004, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 001: Dev 004, If 3, Class=Audio, Driver=snd-usb-audio, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
|__ Port 003: Dev 002, If 0, Class=Mass Storage, Driver=uas, 5000M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 002: Dev 002, If 0, Class=Hub, Driver=hub/4p, 12M
|__ Port 001: Dev 004, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 001: Dev 004, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 002: Dev 006, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 006, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 008, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 008, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 008, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 009, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 009, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 003, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 002: Dev 005, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 005, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 002: Dev 005, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 007, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 004: Dev 007, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 5000M
or eventually lsusb -v ![]()
With “a” instead of “x” it gives a bit more info
sudo inxi -Fazc0 --usb
Device-1: 1-5:2 info: X10 Wireless Transceiver (ACPI-compliant)
type: <vendor specific> driver: ati_remote interfaces: 1 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 2mA
chip-ID: 0bc7:0006 class-ID: 0000
Hub-2: 1-6:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1:4 info: Logitech C922 Pro Stream Webcam type: video,audio
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 2-3:2 info: Seagate RSS LLC Expansion HDD type: mass storage
driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 896mA chip-ID: 0bc2:2037 class-ID: 0806
serial: <filter>
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-2:2 info: Manufacturer hub ports: 4 rev: 2.0
chip-ID: 0a05:7211 class-ID: 0900
Device-1: 3-2.1:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: bluetooth driver: btusb interfaces: 2 rev: 1.1
chip-ID: 0a12:0001 class-ID: e001
Device-2: 3-2.2:6 info: MosArt Wireless Keyboard/Mouse
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 062a:4101 class-ID: 0301
Device-3: 3-2.3:8 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-4: 3-2.4:9 info: Xenta 2.4G Receiver type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1d57:fa23 class-ID: 0301
Hub-6: 3-3:3 info: Transcend Information microSD/SD/CF UHS-II Card Reader
[RDF8 RDF9] ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 8564:4000 class-ID: 0900
Device-1: 3-3.2:5 info: Logitech Unifying Receiver
Device-2: 3-3.4:7 info: Areson Corp Elecom MR-K013 Multicard Reader
chip-ID: 25a7:fa61 class-ID: 0301
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
(I do have renesas firmware installed, but do not know if it was neccesary (and don´t care)) ![]()
lsusb -t ✔
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 006: Dev 003, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 006: Dev 003, If 1, Class=Wireless, Driver=btusb, 12M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 005: Dev 003, If 0, Class=Vendor Specific Class, Driver=xpad, 12M
|__ Port 006: Dev 004, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 006: Dev 004, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 001: Dev 002, If 0, Class=Vendor Specific Class, Driver=rtl8821au, 480M
|__ Port 002: Dev 003, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
lsusb -v ✔
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 6.06
iManufacturer 3 Linux 6.6.8-2-MANJARO ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 0000:00:1a.0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 [unknown]
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x8087 Intel Corp.
idProduct 0x0024 Integrated Rate Matching Hub
bcdDevice 0.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 224 Wireless
bDeviceSubClass 1 Radio Frequency
bDeviceProtocol 1 Bluetooth
bMaxPacketSize0 64
idVendor 0x0a12 Cambridge Silicon Radio, Ltd
idProduct 0x0001 Bluetooth Dongle (HCI mode)
bcdDevice 88.91
iManufacturer 0
iProduct 2 CSR8510 A10
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x00b1
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 1 Bluetooth
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 1
Transfer Type Isochronous
Synch Type None
Usage Type Data
wMaxPacketSize 0x0000 1x 0 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0009 1x 9 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0011 1x 17 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0019 1x 25 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0021 1x 33 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
wMaxPacketSize 0x0031 1x 49 bytes
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 1
Synch Type None
Usage Type Data
bInterval 1
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 6.06
iSerial 1 0000:00:1d.0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 0.00
iManufacturer 0
iProduct 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Bus 002 Device 003: ID 146b:0603 BigBen Interactive PC Compact Controller
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 255 Vendor Specific Class
bDeviceSubClass 255 Vendor Specific Subclass
bDeviceProtocol 255 Vendor Specific Protocol
bMaxPacketSize0 64
idVendor 0x146b BigBen Interactive
idProduct 0x0603 PC Compact Controller
bcdDevice 1.00
iManufacturer 1 Bigben Interactive
iProduct 2 PC Compact Controller
iSerial 3 60B00422
bLength 9
bDescriptorType 2
wTotalLength 0x0031
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 93 [unknown]
iInterface 0
** UNRECOGNIZED: 11 21 00 01 01 25 81 14 00 00 00 00 13 02 08 03 03
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 4
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 8
Bus 002 Device 004: ID 046d:c31b Logitech, Inc. Compact Keyboard K300
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x046d Logitech, Inc.
idProduct 0xc31b Compact Keyboard K300
bcdDevice 60.00
iManufacturer 1 Logitech
iProduct 2 Logitech USB Keyboard
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x003b
bNumInterfaces 2
iConfiguration 4
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 98mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 69
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 56
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 6.06
iManufacturer 3 Linux 6.6.8-2-MANJARO xhci-hcd
iProduct 2 xHCI Host Controller
iSerial 1 0000:00:14.0
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Bus 003 Device 002: ID 0bda:0811 Realtek Semiconductor Corp. Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless Dual-Band Adapter 2.4/5Ghz]
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0bda Realtek Semiconductor Corp.
idProduct 0x0811 Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless Dual-Band Adapter 2.4/5Ghz]
bcdDevice 2.00
iManufacturer 1 Realtek
iProduct 2 802.11ac WLAN Adapter
iSerial 3 00e04c000001
bLength 9
bDescriptorType 2
wTotalLength 0x003c
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 6
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Bus 003 Device 003: ID 046d:c077 Logitech, Inc. Mouse
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceProtocol 0
bMaxPacketSize0 8
idProduct 0xc077 Mouse
bcdDevice 72.00
iProduct 2 USB Optical Mouse
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 46
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceProtocol 3
bMaxPacketSize0 9
idProduct 0x0003 3.0 root hub
bcdDevice 6.06
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
sudo inxi -Fazc0 --usb ✔
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
udev.log_priority=3 iommu=soft
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASRock model: B75M-DGS serial: N/A
UEFI: American Megatrends v: P1.50 date: 03/14/2018
Info: model: Intel Core i3-3220 socket: BGA1155 bits: 64 type: MT MCP
arch: Ivy Bridge gen: core 3 level: v2 built: 2012-15 process: Intel 22nm
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1672 high: 1901 min/max: 1600/3300 base/boost: 3300/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 1.1 V
ext-clock: 100 MHz cores: 1: 1596 2: 1901 3: 1596 4: 1595 bogomips: 26348
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Micro-Star MSI
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c81 class-ID: 0300
Display: server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 89 s-size: 411x263mm (16.18x10.35")
s-diag: 488mm (19.21")
Monitor-1: Unknown-1 mapped: HDMI-0 res: 1440x900 hz: 60 dpi: 90
size: 408x255mm (16.06x10.04") modes: 1024x768
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1050 driver: nvidia v: 545.29.06
device-ID: 10de:1c81 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASRock 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless
Dual-Band 2.4/5Ghz] driver: rtl8821au type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:0811 class-ID: 0000
serial: <filter>
IF: wlp0s20u1 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.6:3
Local Storage: total: 558.92 GiB used: 370.42 GiB (66.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 0000 scheme: GPT
SMART: yes state: enabled health: UNKNOWN!
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Force LS SSD
family: Driven SSDs size: 111.79 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 1.5 Gb/s tech: SSD serial: <filter>
fw-rev: 02.8 scheme: GPT
SMART: yes state: disabled
ID-1: / raw-size: 102.69 GiB size: 100.52 GiB (97.89%)
used: 21.9 GiB (21.8%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 296 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: partition size: 8.8 GiB used: 73.2 MiB (0.8%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.6:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.5:3 info: BigBen Interactive PC Compact Controller
type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
chip-ID: 146b:0603 class-ID: ff00 serial: <filter>
Device-2: 2-1.6:4 info: Logitech Compact Keyboard K300 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 046d:c31b class-ID: 0300
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB
Wireless Dual-Band 2.4/5Ghz] type: Network driver: rtl8821au interfaces: 1
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
chip-ID: 0bda:0811 class-ID: 0000 serial: <filter>
Device-2: 3-2:3 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 27 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Processes: 223 Uptime: 5h 15m wakeups: 0 Memory: total: 16 GiB
available: 15.57 GiB used: 3.27 GiB (21.0%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1263 libs: 418 tools: pamac pm: flatpak pkgs: 0
Shell: Sudo (sudo) v: 1.9.15p4 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Hope there’s something that brings light.
Is this the non-functioning hub ?
I seem to have have the same one, and it works.
my snipped from sudo lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 9 Hub
bDeviceProtocol 3
bMaxPacketSize0 9
bcdDevice 6.01
iManufacturer 3 Linux 6.1.69-1-MANJARO xhci-hcd
iSerial 1 0000:28:00.3
bLength 9
bDescriptorType 2
wTotalLength 0x001f
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
bMaxBurst 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x000f
bNumDeviceCaps 1
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x02
Latency Tolerance Messages (LTM) Supported
wSpeedsSupported 0x0008
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 1
Lowest fully-functional device speed is Full Speed (12Mbps)
bU1DevExitLat 0 micro seconds
bU2DevExitLat 0 micro seconds
Hub Descriptor:
bLength 12
bDescriptorType 42
nNbrPorts 4
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
bHubDecLat 0.0 micro seconds
wHubDelay 0 nano seconds
DeviceRemovable 0x00
Hub Port Status:
Port 1: 0000.02a0 5Gbps power Rx.Detect
Port 2: 0000.02a0 5Gbps power Rx.Detect
Port 3: 0000.02a0 5Gbps power Rx.Detect
Port 4: 0000.02a0 5Gbps power Rx.Detect
Device Status: 0x0001
Self Powered
- Please try to install renesas firmware (even if it may not help)
- Recreate your initrds (mkinitcpio -P)
- Reboot
Thank you.
While rebooting, I’d like to show something from lspci -nnk:
00:14.0 USB controller [0c03]: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller [8086:1e31] (rev 04)
Subsystem: ASRock Incorporation Motherboard [1849:1e31]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
I didn’t know the difference of xhci_hcd and xhci_pci, but apparently both are needed. xhci_hcd is built in kernel, the other is added as a module.
Well there is upd72020x-fw in the AUR.
I dont know about the above discussion, whether the module should already exist or not, etc…
But it is listed on the archwiki
https://wiki.archlinux.org/title/Mkinitcpio#Possibly_missing_firmware_for_module_XXXX
check for a valid connection of the cables and a firmware-update of the bios first. fingers crossed that a possible wrong connection to the front-usb didn’t harm your usb-controller port.
Cables checked. They were fine. It was hard to connect them again. Many small pins.
Maybe updating the BIOS? It worked well with Windows, so I didn’t suspect the bios, but who knows?
Thank you. I’ve installed it now. Let’s see.
