Noisy fans
Hello,
my only concern with Manjaro on my new Dell is that the computer is very noisy even if do not have almost anything open. I suspect I might have turned on secondary graphic card. I have 16 thread CPU and most of them are barely used. Before I followed some tutorial and installed few packages and it was better but when I updated to gnome 3.36 (which is way snappier then previous) I needed to remove some of them because of conflicts. I can't find the tutorial neither I remember the package names. Can you help me?
inxi -Fxxx
System:    Host: fokot-precision5540 Kernel: 5.4.31-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
           Desktop: Gnome 3.36.1 info: docker wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Precision 5540 v: N/A serial: <root required> Chassis: type: 10
           Mobo: Dell model: 0V030K v: A00 serial: <root required> UEFI: Dell v: 1.5.0 date: 12/25/2019
Battery:   ID-1: BAT0 charge: 87.8 Wh condition: 87.8/97.0 Wh (91%) volts: 13.1/11.4
           model: LGC-LGC8.33 DELL 5XJ289C type: Li-ion serial: 8827 status: Full
CPU:       Topology: 8-Core model: Intel Core i9-9980HK bits: 64 type: MT MCP arch: Kaby Lake rev: D
           L2 cache: 16.0 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 76816
           Speed: 3901 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 3900 2: 3900 3: 3900 4: 3901 5: 3900
           6: 3901 7: 3901 8: 3900 9: 3901 10: 3903 11: 3901 12: 3901 13: 3901 14: 3901 15: 3900 16: 3900
Graphics:  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:3e9b
           Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] driver: nouveau v: kernel bus ID: 01:00.0
           chip ID: 10de:1fb8
           Display: x11 server: X.org 1.20.8 driver: nouveau compositor: gnome-shell
           resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.0.4 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:a348
           Device-2: Plantronics Plantronics .Audio 622 USB type: USB driver: plantronics,snd-usb-audio,usbhid
           bus ID: 1-2:7 chip ID: 047f:c014
           Sound Server: ALSA v: k5.4.31-1-MANJARO
Network:   Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000 bus ID: 3b:00.0
           chip ID: 8086:2526
           IF: wlp59s0 state: up mac: c8:09:a8:ad:cb:f4
           IF-ID-1: br-250d3429f98c state: up speed: N/A duplex: N/A mac: 02:42:a7:ad:c9:39
           IF-ID-2: docker0 state: down mac: 02:42:65:8f:71:7a
           IF-ID-3: veth45bf1c4 state: up speed: 10000 Mbps duplex: full mac: 22:6b:ef:d7:04:29
           IF-ID-4: veth6fd83c4 state: up speed: 10000 Mbps duplex: full mac: 96:33:32:2a:aa:28
           IF-ID-5: vethdd242e7 state: up speed: 10000 Mbps duplex: full mac: 76:ab:f2:7c:51:29
Drives:    Local Storage: total: 476.94 GiB used: 29.52 GiB (6.2%)
           ID-1: /dev/nvme0n1 vendor: Micron model: 2200S NVMe 512GB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
           serial: 194925388B3D rev: 22001030 scheme: GPT
Partition: ID-1: / size: 468.16 GiB used: 29.52 GiB (6.3%) fs: ext4 dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 59.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 4909 fan-2: 4896
Info:      Processes: 476 Uptime: 4d 14h 22m Memory: 62.43 GiB used: 19.22 GiB (30.8%) Init: systemd v: 244
           Compilers: gcc: 9.3.0 Shell: zsh v: 5.8 running in: gnome-terminal inxi: 3.0.37
systemctl status tlp
● tlp.service - TLP system startup/shutdown
     Loaded: loaded (/usr/lib/systemd/system/tlp.service; enabled; vendor preset: disabled)
     Active: active (exited) since Thu 2020-04-16 21:21:35 CEST; 4 days ago
       Docs: https://linrunner.de/tlp
    Process: 1777 ExecStart=/usr/bin/tlp init start (code=exited, status=0/SUCCESS)
   Main PID: 1777 (code=exited, status=0/SUCCESS)
apr 16 21:21:35 fokot-precision5540 systemd[1]: Starting TLP system startup/shutdown...
apr 16 21:21:35 fokot-precision5540 tlp[1777]: Applying power save settings...done.
apr 16 21:21:35 fokot-precision5540 tlp[1777]: Setting battery charge thresholds...done.
apr 16 21:21:35 fokot-precision5540 systemd[1]: Started TLP system startup/shutdown.
Turning off skype was quite helpfull. It took constantly 35-40% CPU. I just do not understand that in System monitor in gnome I could not see it as most processes have 0%. CPU usage in top or htop seems very different
But I still would like to make it more quiet.
A couple of pieces of advice, in general for a new laptop: 1) Repaste the heatsink for both cpu and gpu, the factory paste job is often garbage and contirbutes to high temps which will make that fan go crazy. 2) With hybrid laptop graphics you are going to need to experiment and find a happy spot of both which graphics drivers you are using and when you are using that Quadro GPU. For most tasks that Quadro is not necessary and will contribute to higher temps and power drain. 3) Undervolt that cpu it will run cooler and extend battery life. (https://github.com/erpalma/throttled) I use it and it also works on some Dells. 4) Find a way to control your fan speed or create a custom fan curve. For Thinkpads you can use Thinkfan, I don't know if there is a similar item for Dells. 5) Accept your laptop is going to be a little louder you have an i9 cpu, not much you can do there.
As to System Monitor in Gnome make sure you have All Processes selected otherwise it will only track processes you initiated by default, also make sure it is sorting correctly.
Hope that helps. Good luck.
Thanks @nadb I just repasted it and so far it looks it was very good tip :slight_smile: My usual temperatures were 70+ or 80+ Celsius now it is 50+. And I even open all programs I use to have opened. I will see how it goes
