Hello everyone, new manjaro’s user here
I wanted to know if there is a discord who has the noise reduction because i installed it and i didn’t have the noise reduction by default.
IS there is an alternative to this ?
thx
thx
I don’t know anything about Discord but I can recommend NoiseTorch for this.
pamac build noisetorch-bin
I use this without AUR:
pamac install noise-suppression-for-voice
mkdir -pv ~/.config/pipewire/filter-chain.conf.d/
ln -fv /usr/share/pipewire/filter-chain/source-rnnoise.conf ~/.config/pipewire/filter-chain.conf.d/source-rnnoise.conf
mkdir -pv ~/.config/systemd/user/
nano ~/.config/systemd/user/pipewire-filter-chain.service
Put this in:
[Unit]
Description=PipeWire Filter Chain
After=pipewire.service
BindsTo=pipewire.service
[Service]
ExecStart=/usr/bin/pipewire -c filter-chain.conf
Type=simple
Restart=on-failure
[Install]
WantedBy=pipewire.service
and save it.
Restart pipewire:
systemctl --user restart pipewire.service
Noise Cancellation for all Microphones are there on a separate input device “Noise Canceling Source”.
Hello,
I installed discord couple of days ago and I have the noise suppression option by default, no nitro or whatever.
settings → voice&video → (scroll a bit ) and you will see it under voice processing…
the package that I installed is discord from community repo…
oh yeah, thx everyone for your answers ! Linux sounds fun (no humor here) !
