no X11/Screen/Display on Ondroid N2 Manjaro-ARM 19.12
New Manjaro-ARM Install to emmc-card with manjaro-arm-installer.
Boot without Screen / Black Screen .. terminal login via ssh successful
someone an idea .. what can i do ?
Xorg.log says...
[  1809.491]
X.Org X Server 1.20.6
[  1809.491] Build Operating System: Linux Arch Linux
[  1809.491] Current Operating System: Linux MjON2aarch64emmc 5.4.8-1-MANJARO-ARM #1 SMP Sun Jan 5 07:06:25 UTC 2020 aarch64
[  1809.491] Kernel command line: root=/dev/mmcblk0p2 rootwait rw console=ttyS0,115200n8  no_console_suspend fsck.repair=yes net.ifnames=0 elevator=noop hdmimode=custombuilt cvbsmode=576cvbs max_freq_a53=1896 max_freq_a73=1800 maxcpus=6 voutmode=hdmi modeline= disablehpd=false cvbscable= overscan=100  monitor_onoff=false logo=osd0,loaded hdmitx=cec3f
[  1809.491] Build Date: 04 January 2020  11:18:16AM
[  1809.491]
[  1809.491] Current version of pixman: 0.38.4
[  1809.491] 	Before reporting problems, check http://wiki.x.org
[  1809.491] Markers: (--) probed, (**) from config file, (==) default setting,
[  1809.491] (==) Log file: "/var/log/Xorg.3.log", Time: Sun Jan  5 23:12:43 2020
[  1809.491] (==) Using config directory: "/etc/X11/xorg.conf.d"
[  1809.492] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  1809.492] (==) No Layout section.  Using the first Screen section.
[  1809.492] (==) No screen section available. Using defaults.
[  1809.492] (**) |-->Screen "Default Screen Section" (0)
[  1809.492] (**) |   |-->Monitor "<default monitor>"
[  1809.492] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[  1809.492] (**) |   |-->Device "Allwinner A10/A13 FBDEV"
[  1809.492] (==) No monitor specified for screen "Default Screen Section".
[  1809.492] (==) Automatically adding devices
[  1809.493] (==) Automatically enabling devices
[  1809.493] (==) Automatically adding GPU devices
[  1809.493] (==) Automatically binding GPU devices
[  1809.493] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  1809.493] (WW) The directory "/usr/share/fonts/misc" does not exist.
[  1809.493] 	Entry deleted from font path.
[  1809.493] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[  1809.493] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[  1809.493] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[  1809.493] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[  1809.493] (==) FontPath set to:
	/usr/share/fonts/TTF
[  1809.493] (==) ModulePath set to "/usr/lib/xorg/modules"
[  1809.493] (II) The server relies on udev to provide the list of input devices.
[  1809.493] (II) Module ABI versions:
[  1809.493] 	X.Org ANSI C Emulation: 0.4
[  1809.493] 	X.Org Video Driver: 24.0
[  1809.493] 	X.Org XInput driver : 24.1
[  1809.493] 	X.Org Server Extension : 10.0
[  1809.494] (++) using VT number 7
[  1809.494] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[  1809.495] (II) xfree86: Adding drm device (/dev/dri/card0)
[  1809.512] (II) no primary bus or device found
[  1809.512] 	falling back to /sys/devices/platform/soc/ff900000.vpu/drm/card0
[  1809.512] (II) LoadModule: "glx"
[  1809.513] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  1809.518] (II) Module glx: vendor="X.Org Foundation"
[  1809.518] 	compiled for 1.20.6, module version = 1.0.0
[  1809.518] 	ABI class: X.Org Server Extension, version 10.0
[  1809.518] (II) LoadModule: "fbturbo"
[  1809.518] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[  1809.518] (II) Module fbturbo: vendor="X.Org Foundation"
[  1809.518] 	compiled for 1.20.0, module version = 0.5.1
[  1809.518] 	Module class: X.Org Video Driver
[  1809.518] 	ABI class: X.Org Video Driver, version 24.0
[  1809.518] (II) FBTURBO: driver for framebuffer: fbturbo
[  1809.518] (WW) xf86OpenConsole: setpgid failed: Operation not permitted
[  1809.518] (WW) Falling back to old probe method for fbturbo
[  1809.518] (II) Loading sub module "fbdevhw"
[  1809.518] (II) LoadModule: "fbdevhw"
[  1809.519] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  1809.519] (II) Module fbdevhw: vendor="X.Org Foundation"
[  1809.519] 	compiled for 1.20.6, module version = 0.0.2
[  1809.519] 	ABI class: X.Org Video Driver, version 24.0
[  1809.519] (II) FBTURBO(0): using /dev/fb0
[  1809.519] (II) FBTURBO(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[  1809.519] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[  1809.519] (==) FBTURBO(0): RGB weight 888
[  1809.519] (==) FBTURBO(0): Default visual is TrueColor
[  1809.519] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[  1809.519] (II) FBTURBO(0): hardware: mesondrmfb (video memory: 32400kB)
[  1809.519] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[  1809.519] (**) FBTURBO(0): Option "fbdev" "/dev/fb0"
[  1809.519] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[  1809.519] (II) FBTURBO(0): processor: Unknown
[  1809.519] (II) FBTURBO(0): checking modes against framebuffer device...
[  1809.519] (II) FBTURBO(0): checking modes against monitor...
[  1809.520] (II) FBTURBO(0): Virtual size is 3840x2160 (pitch 3840)
[  1809.520] (**) FBTURBO(0):  Built-in mode "current"
[  1809.520] (==) FBTURBO(0): DPI set to (96, 96)
[  1809.520] (II) Loading sub module "fb"
[  1809.520] (II) LoadModule: "fb"
[  1809.520] (II) Loading /usr/lib/xorg/modules/libfb.so
[  1809.521] (II) Module fb: vendor="X.Org Foundation"
[  1809.521] 	compiled for 1.20.6, module version = 1.0.0
[  1809.521] 	ABI class: X.Org ANSI C Emulation, version 0.4
[  1809.521] (**) FBTURBO(0): using shadow framebuffer
[  1809.521] (II) Loading sub module "shadow"
[  1809.521] (II) LoadModule: "shadow"
[  1809.521] (II) Loading /usr/lib/xorg/modules/libshadow.so
[  1809.521] (II) Module shadow: vendor="X.Org Foundation"
[  1809.521] 	compiled for 1.20.6, module version = 1.1.0
[  1809.712] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[  1809.713] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[  1809.713] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[  1809.713] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[  1809.713] (==) FBTURBO(0): Backing store enabled
[  1809.713] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[  1809.714] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[  1809.715] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[  1809.716] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[  1809.717] (EE) FBTURBO(0): FBIOPUTCMAP: Invalid argument
[  1809.717] (==) FBTURBO(0): DPMS enabled
[  1809.717] (II) FBTURBO(0): failed to enable hardware cursor
[  1809.717] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[  1809.717] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[  1809.717] (II) Initializing extension Generic Event Extension
[  1809.717] (II) Initializing extension SHAPE
[  1809.717] (II) Initializing extension MIT-SHM
[  1809.717] (II) Initializing extension XInputExtension
[  1809.717] (II) Initializing extension XTEST
[  1809.717] (II) Initializing extension BIG-REQUESTS
[  1809.717] (II) Initializing extension SYNC
[  1809.717] (II) Initializing extension XKEYBOARD
[  1809.717] (II) Initializing extension XC-MISC
[  1809.717] (II) Initializing extension SECURITY
[  1809.717] (II) Initializing extension XFIXES
[  1809.717] (II) Initializing extension RENDER
[  1809.717] (II) Initializing extension RANDR
[  1809.717] (II) Initializing extension COMPOSITE
[  1809.717] (II) Initializing extension DAMAGE
[  1809.717] (II) Initializing extension MIT-SCREEN-SAVER
[  1809.717] (II) Initializing extension DOUBLE-BUFFER
[  1809.717] (II) Initializing extension RECORD
[  1809.717] (II) Initializing extension DPMS
[  1809.717] (II) Initializing extension Present
[  1809.717] (II) Initializing extension DRI3
[  1809.717] (II) Initializing extension X-Resource
[  1809.717] (II) Initializing extension XVideo
[  1809.717] (II) Initializing extension XVideo-MotionCompensation
[  1809.717] (II) Initializing extension GLX
[  1809.718] (II) AIGLX: Screen 0 is not DRI2 capable
[  1809.908] (II) IGLX: Loaded and initialized swrast
[  1809.908] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[  1809.908] (II) Initializing extension XFree86-VidModeExtension
[  1809.908] (II) Initializing extension XFree86-DGA
[  1809.908] (II) Initializing extension XFree86-DRI
[  1809.908] (II) Initializing extension DRI2
[  1810.061] (II) config/udev: Adding input device dw_hdmi (/dev/input/event5)
[  1810.061] (**) dw_hdmi: Applying InputClass "libinput keyboard catchall"
[  1810.061] (**) dw_hdmi: Applying InputClass "system-keyboard"
[  1810.061] (II) LoadModule: "libinput"
[  1810.061] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[  1810.066] (II) Module libinput: vendor="X.Org Foundation"
[  1810.066] 	compiled for 1.20.5, module version = 0.29.0
[  1810.066] 	Module class: X.Org XInput Driver
[  1810.066] 	ABI class: X.Org XInput driver, version 24.1
[  1810.066] (II) Using input driver 'libinput' for 'dw_hdmi'
[  1810.066] (**) dw_hdmi: always reports core events
[  1810.066] (**) Option "Device" "/dev/input/event5"
[  1810.066] (**) Option "_source" "server/udev"
[  1810.071] (II) event5  - dw_hdmi: is tagged by udev as: Keyboard Pointingstick
[  1810.072] (II) event5  - dw_hdmi: device is a pointer
[  1810.072] (II) event5  - dw_hdmi: device is a keyboard
[  1810.072] (II) event5  - dw_hdmi: device removed
[  1810.110] (II) libinput: dw_hdmi: needs a virtual subdevice
[  1810.110] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff600000.bus/ff600000.hdmi-tx/rc/rc1/input5/event5"
[  1810.110] (II) XINPUT: Adding extended input device "dw_hdmi" (type: MOUSE, id 6)
[  1810.110] (**) Option "AccelerationScheme" "none"
[  1810.110] (**) dw_hdmi: (accel) selected scheme none/0
[  1810.110] (**) dw_hdmi: (accel) acceleration factor: 2.000
[  1810.110] (**) dw_hdmi: (accel) acceleration threshold: 4
[  1810.113] (II) event5  - dw_hdmi: is tagged by udev as: Keyboard Pointingstick
[  1810.113] (II) event5  - dw_hdmi: device is a pointer
[  1810.113] (II) event5  - dw_hdmi: device is a keyboard
[  1810.115] (II) config/udev: Adding input device meson-ir (/dev/input/event4)
[  1810.115] (**) meson-ir: Applying InputClass "libinput keyboard catchall"
[  1810.115] (**) meson-ir: Applying InputClass "system-keyboard"
[  1810.115] (II) Using input driver 'libinput' for 'meson-ir'
[  1810.115] (**) meson-ir: always reports core events
[  1810.115] (**) Option "Device" "/dev/input/event4"
[  1810.115] (**) Option "_source" "server/udev"
[  1810.118] (II) event4  - meson-ir: is tagged by udev as: Keyboard Pointingstick
[  1810.118] (II) event4  - meson-ir: device is a pointer
[  1810.118] (II) event4  - meson-ir: device is a keyboard
[  1810.119] (II) event4  - meson-ir: device removed
[  1810.150] (II) libinput: meson-ir: needs a virtual subdevice
[  1810.150] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4/event4"
[  1810.150] (II) XINPUT: Adding extended input device "meson-ir" (type: MOUSE, id 7)
[  1810.150] (**) Option "AccelerationScheme" "none"
[  1810.150] (**) meson-ir: (accel) selected scheme none/0
[  1810.150] (**) meson-ir: (accel) acceleration factor: 2.000
[  1810.150] (**) meson-ir: (accel) acceleration threshold: 4
[  1810.153] (II) event4  - meson-ir: is tagged by udev as: Keyboard Pointingstick
[  1810.153] (II) event4  - meson-ir: device is a pointer
[  1810.153] (II) event4  - meson-ir: device is a keyboard
[  1810.156] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event0)
[  1810.156] (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[  1810.156] (**) Logitech USB Optical Mouse: Applying InputClass "system-keyboard"
[  1810.156] (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
[  1810.157] (**) Logitech USB Optical Mouse: always reports core events
[  1810.157] (**) Option "Device" "/dev/input/event0"
[  1810.157] (**) Option "_source" "server/udev"
[  1810.161] (II) event0  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[  1810.161] (II) event0  - Logitech USB Optical Mouse: device is a pointer
[  1810.162] (II) event0  - Logitech USB Optical Mouse: device removed
[  1810.210] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C018.0001/input/input0/event0"
[  1810.210] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 8)
[  1810.210] (**) Option "AccelerationScheme" "none"
[  1810.210] (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
[  1810.210] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[  1810.210] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[  1810.214] (II) event0  - Logitech USB Optical Mouse: is tagged by udev as: Mouse
[  1810.214] (II) event0  - Logitech USB Optical Mouse: device is a pointer
[  1810.217] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
[  1810.217] (**) Logitech USB Optical Mouse: Applying InputClass "system-keyboard"
[  1810.217] (II) No input driver specified, ignoring this device.
[  1810.217] (II) This device may have been added with another device file.
[  1810.219] (II) config/udev: Adding input device Logitech HID compliant keyboard (/dev/input/event1)
[  1810.219] (**) Logitech HID compliant keyboard: Applying InputClass "libinput keyboard catchall"
[  1810.219] (**) Logitech HID compliant keyboard: Applying InputClass "system-keyboard"
[  1810.219] (II) Using input driver 'libinput' for 'Logitech HID compliant keyboard'
[  1810.219] (**) Logitech HID compliant keyboard: always reports core events
[  1810.219] (**) Option "Device" "/dev/input/event1"
[  1810.219] (**) Option "_source" "server/udev"
[  1810.223] (II) event1  - Logitech HID compliant keyboard: is tagged by udev as: Keyboard
[  1810.223] (II) event1  - Logitech HID compliant keyboard: device is a keyboard
[  1810.224] (II) event1  - Logitech HID compliant keyboard: device removed
[  1810.290] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C30E.0002/input/input1/event1"
[  1810.290] (II) XINPUT: Adding extended input device "Logitech HID compliant keyboard" (type: KEYBOARD, id 9)
[  1810.290] (**) Option "xkb_layout" "de"
[  1810.367] (II) event1  - Logitech HID compliant keyboard: is tagged by udev as: Keyboard
[  1810.368] (II) event1  - Logitech HID compliant keyboard: device is a keyboard
[  1810.370] (II) config/udev: Adding input device Logitech HID compliant keyboard Consumer Control (/dev/input/event2)
[  1810.371] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "libinput pointer catchall"
[  1810.371] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1810.371] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "system-keyboard"
[  1810.371] (II) Using input driver 'libinput' for 'Logitech HID compliant keyboard Consumer Control'
[  1810.371] (**) Logitech HID compliant keyboard Consumer Control: always reports core events
[  1810.371] (**) Option "Device" "/dev/input/event2"
[  1810.371] (**) Option "_source" "server/udev"
[  1810.375] (II) event2  - Logitech HID compliant keyboard Consumer Control: is tagged by udev as: Keyboard Mouse
[  1810.375] (II) event2  - Logitech HID compliant keyboard Consumer Control: device is a pointer
[  1810.375] (II) event2  - Logitech HID compliant keyboard Consumer Control: device is a keyboard
[  1810.375] (II) event2  - Logitech HID compliant keyboard Consumer Control: device removed
[  1810.410] (II) libinput: Logitech HID compliant keyboard Consumer Control: needs a virtual subdevice
[  1810.410] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C30E.0003/input/input2/event2"
[  1810.410] (II) XINPUT: Adding extended input device "Logitech HID compliant keyboard Consumer Control" (type: MOUSE, id 10)
[  1810.410] (**) Option "AccelerationScheme" "none"
[  1810.410] (**) Logitech HID compliant keyboard Consumer Control: (accel) selected scheme none/0
[  1810.410] (**) Logitech HID compliant keyboard Consumer Control: (accel) acceleration factor: 2.000
[  1810.410] (**) Logitech HID compliant keyboard Consumer Control: (accel) acceleration threshold: 4
[  1810.414] (II) event2  - Logitech HID compliant keyboard Consumer Control: is tagged by udev as: Keyboard Mouse
[  1810.415] (II) event2  - Logitech HID compliant keyboard Consumer Control: device is a pointer
[  1810.415] (II) event2  - Logitech HID compliant keyboard Consumer Control: device is a keyboard
[  1810.417] (II) config/udev: Adding input device Logitech HID compliant keyboard System Control (/dev/input/event3)
[  1810.418] (**) Logitech HID compliant keyboard System Control: Applying InputClass "libinput keyboard catchall"
[  1810.418] (**) Logitech HID compliant keyboard System Control: Applying InputClass "system-keyboard"
[  1810.418] (II) Using input driver 'libinput' for 'Logitech HID compliant keyboard System Control'
[  1810.418] (**) Logitech HID compliant keyboard System Control: always reports core events
[  1810.418] (**) Option "Device" "/dev/input/event3"
[  1810.418] (**) Option "_source" "server/udev"
[  1810.422] (II) event3  - Logitech HID compliant keyboard System Control: is tagged by udev as: Keyboard
[  1810.422] (II) event3  - Logitech HID compliant keyboard System Control: device is a keyboard
[  1810.423] (II) event3  - Logitech HID compliant keyboard System Control: device removed
[  1810.470] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C30E.0003/input/input3/event3"
[  1810.470] (II) XINPUT: Adding extended input device "Logitech HID compliant keyboard System Control" (type: KEYBOARD, id 11)
[  1810.470] (**) Option "xkb_layout" "de"
[  1810.474] (II) event3  - Logitech HID compliant keyboard System Control: is tagged by udev as: Keyboard
[  1810.474] (II) event3  - Logitech HID compliant keyboard System Control: device is a keyboard
[  1810.494] (**) dw_hdmi: Applying InputClass "libinput keyboard catchall"
[  1810.494] (**) dw_hdmi: Applying InputClass "system-keyboard"
[  1810.494] (II) Using input driver 'libinput' for 'dw_hdmi'
[  1810.494] (**) dw_hdmi: always reports core events
[  1810.494] (**) Option "Device" "/dev/input/event5"
[  1810.494] (**) Option "_source" "_driver/libinput"
[  1810.494] (II) libinput: dw_hdmi: is a virtual subdevice
[  1810.494] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff600000.bus/ff600000.hdmi-tx/rc/rc1/input5/event5"
[  1810.494] (II) XINPUT: Adding extended input device "dw_hdmi" (type: KEYBOARD, id 12)
[  1810.494] (**) Option "xkb_layout" "de"
[  1810.495] (**) meson-ir: Applying InputClass "libinput keyboard catchall"
[  1810.495] (**) meson-ir: Applying InputClass "system-keyboard"
[  1810.495] (II) Using input driver 'libinput' for 'meson-ir'
[  1810.495] (**) meson-ir: always reports core events
[  1810.495] (**) Option "Device" "/dev/input/event4"
[  1810.495] (**) Option "_source" "_driver/libinput"
[  1810.495] (II) libinput: meson-ir: is a virtual subdevice
[  1810.495] (**) Option "config_info" "udev:/sys/devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input4/event4"
[  1810.495] (II) XINPUT: Adding extended input device "meson-ir" (type: KEYBOARD, id 13)
[  1810.495] (**) Option "xkb_layout" "de"
[  1810.496] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "libinput pointer catchall"
[  1810.496] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[  1810.496] (**) Logitech HID compliant keyboard Consumer Control: Applying InputClass "system-keyboard"
[  1810.496] (II) Using input driver 'libinput' for 'Logitech HID compliant keyboard Consumer Control'
[  1810.496] (**) Logitech HID compliant keyboard Consumer Control: always reports core events
[  1810.496] (**) Option "Device" "/dev/input/event2"
[  1810.496] (**) Option "_source" "_driver/libinput"
[  1810.496] (II) libinput: Logitech HID compliant keyboard Consumer Control: is a virtual subdevice
[  1810.496] (**) Option "config_info" "udev:/sys/devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C30E.0003/input/input2/event2"
[  1810.496] (II) XINPUT: Adding extended input device "Logitech HID compliant keyboard Consumer Control" (type: KEYBOARD, id 14)
[  1810.496] (**) Option "xkb_layout" "de"
startx .log
(==) Log file: "/var/log/Xorg.4.log", Time: Sun Jan  5 23:26:53 2020
modprobe: FATAL: Module g2d_23 not found in directory /lib/modules/5.4.8-1-MANJARO-ARM
Failed to connect to bus: Datei oder Verzeichnis nicht gefunden
dbus-update-activation-environment: error: unable to connect to D-Bus: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
/etc/X11/xinit/xinitrc: Zeile 52: xclock: Kommando nicht gefunden.
/etc/X11/xinit/xinitrc: Zeile 53: xterm: Kommando nicht gefunden.
/etc/X11/xinit/xinitrc: Zeile 55: exec: xterm: Nicht gefunden.
/etc/X11/xinit/xinitrc: Zeile 54: xterm: Kommando nicht gefunden.
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
You forgot to mention what Device and Edition you chose in the installer.
Don't forget
Chose Odroid N2 and xfce (De) on the first two questions.
Do not use the installer for the first time ...
Installer log is coming up tonight when creating new one
Hi,
Same issue with kde on the n2 with the 19.12, black screen on start after the setup.
No issue with the 19.12 on the c2, but the desktop environment don't start without display plugged, bug already report
https://forum.manjaro.org/t/odroid-c2-manjaro-arm-19-04/88137
okay ..now
i have reinstall "manjaro-arm-installer" and remove "/var/tmp/manjaro-arm-installer"
manjaro-arm-installer Terminal Output - on Pastebin
i see..
Line 1368 - 1390
Creating user bin (n/a) with uid 1 and gid 1.
Creating group daemon with gid 2.
Creating user daemon (n/a) with uid 2 and gid 2.
Creating user mail (n/a) with uid 8 and gid 12.
Creating user ftp (n/a) with uid 14 and gid 11.
Creating group http with gid 33.
Creating user http (n/a) with uid 33 and gid 33.
Creating group nobody with gid 65534.
Creating user nobody (Nobody) with uid 65534 and gid 65534.
Creating group dbus with gid 81.
Creating user dbus (System Message Bus) with uid 81 and gid 81.
Creating group systemd-journal-remote with gid 982.
Creating user systemd-journal-remote (systemd Journal Remote) with uid 982 and gid 982.
Creating group systemd-network with gid 981.
Creating user systemd-network (systemd Network Management) with uid 981 and gid 981.
Creating group systemd-resolve with gid 980.
Creating user systemd-resolve (systemd Resolver) with uid 980 and gid 980.
Creating group systemd-timesync with gid 979.
Creating user systemd-timesync (systemd Time Synchronization) with uid 979 and gid 979.
Creating group systemd-coredump with gid 978.
Creating user systemd-coredump (systemd Core Dumper) with uid 978 and gid 978.
Creating group uuidd with gid 68.
Creating user uuidd (n/a) with uid 68 and gid 68.
Line 2408 - 2421
( 2/28) Updating journal message catalog...
( 3/28) Reloading system manager configuration...
  Skipped: Current root is not booted.
( 4/28) Updating udev hardware database...
( 5/28) Applying kernel sysctl settings...
( 6/28) Creating temporary files...
[/usr/lib/tmpfiles.d/journal-nocow.conf:26] Failed to resolve specifier: uninitialized /etc detected, skipping
All rules containing unresolvable specifiers will be skipped.
Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
error: command failed to execute correctly
( 7/28) Reloading device manager configuration...
  Skipped: Device manager is not running.
( 8/28) Arming ConditionNeedsUpdate...
After this, same result. Black screen and ssh login successful
  -> Doing device specific setups for on2...
  -> Cleaning install for unwanted files...
==> on2 xfce install complete
==> Writing bootloader and cleaning up after install...
==> Time : 14.78 minutes...
These lines are normal. They show on each install. It's because the system is not booted.
Next time, can you login to TTY and try to enable LightDM with
sudo systemctl enable lightdm
and then reboot.
Thank you very much for your help @Strit
yesterday i repeated this command 15 times ago
and pulled HDMI out & in .. nothing.
I am currently writing the emmc with a card reader via USB ..
before > intern card reader + microsd adapter ... worth the test
i will come back soon
Try also renaming the boot.ini and pasting in the new boot.ini from this post.
okay .. now.. i have a screen with vnc-server or ...
... unplugged via HDMI when starting and HDMI plugged in after start.
Display Res. only "1024x768"
xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
   1024x768       0.00*
This topic was automatically closed after 90 days. New replies are no longer allowed.
