Hi
after doing an pacman -Syyu and rebooting I can not access the internet via wifi any more. Only ethernet is working. It’s strange because the connection to the router works and I can see the machine listed in the active connections.
Does anybody have some idea what’s wrong?
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.14.2
Distro: Manjaro Linux
Machine: Type: Unknown System: Apple product: MacBook4,1 v: 1.0 serial: <filter>
Mobo: Apple model: Mac-F22788A9 v: PVT serial: <filter> UEFI: Apple
v: MB41.88Z.00C1.B00.0802091535 date: 02/09/08
Network: Device-1: Broadcom and subsidiaries BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel port: efa0 bus ID: 02:00.0
IF: wls4 state: up mac: <filter>
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30 port: 5000
bus ID: 03:00.0
IF: ens5 state: down mac: <filter>
And the network log:
66.7170] NetworkManager (version 1.26.4-1) is starting... (for the first time)
66.7218] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
66.8282] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
66.8600] manager[0x55d9561f5030]: monitoring kernel firmware directory '/lib/firmware'.
68.4428] hostname: hostname: using hostnamed
68.4428] hostname: hostname changed from (none) to "white-book"
68.4444] dns-mgr[0x55d9561b0220]: init: dns=default,systemd-resolved rc-manager=symlink
68.4449] manager[0x55d9561f5030]: rfkill: Wi-Fi hardware radio set enabled
68.4449] manager[0x55d9561f5030]: rfkill: WWAN hardware radio set enabled
68.4870] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wifi.so)
68.4907] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-ovs.so)
68.4927] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-adsl.so)
68.5094] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-bluetooth.so)
68.5342] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-team.so)
68.5433] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.26.4-1/libnm-device-plugin-wwan.so)
68.5444] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
68.5449] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
68.5453] manager: Networking is enabled by state file
68.5472] dhcp-init: Using DHCP client 'internal'
68.5534] settings: Loaded settings plugin: keyfile (internal)
68.5851] device (lo): carrier: link connected
68.5872] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
68.5905] manager: (ens5): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
68.6117] ovsdb: Could not connect: No such file or directory
68.6204] device (ens5): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
68.6559] settings: (ens5): created default wired connection 'Wired connection 1'
68.6628] modem-manager: ModemManager available
69.0497] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
69.0568] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.4/0000:02:00.0/ieee80211/phy0/rfkill0) (driver wl)
69.0655] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wls4'
69.0796] device (wls4): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
69.1390] device (wls4): set-hw-addr: set MAC address to x.x.x.x (scanning)
69.2345] device (wls4): supplicant interface state: internal-starting -> disconnected
69.2348] device (wls4): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
75.4828] agent-manager: agent[79073e098c916b5f,:1.31/org.freedesktop.nm-applet/1000]: agent registered
76.1309] policy: auto-activating connection 'SchildiOne 2' (b86d1c60-51c4-4dca-aa82-ca33b3165bdc)
76.1441] device (wls4): Activation: starting connection 'SchildiOne 2' (b86d1c60-51c4-4dca-aa82-ca33b3165bdc)
76.1452] device (wls4): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
76.1499] manager: NetworkManager state is now CONNECTING
76.1612] device (wls4): set-hw-addr: reset MAC address to x.x.x.x.x (preserve)
76.1627] device (wls4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
76.1667] device (wls4): Activation: (wifi) access point 'SchildiOne 2' has security, but secrets are required.
76.1678] device (wls4): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
76.1983] device (wls4): supplicant interface state: disconnected -> interface_disabled
76.1987] device (wls4): supplicant interface state: interface_disabled -> inactive
76.2053] device (wls4): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
76.2093] device (wls4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
76.2111] device (wls4): Activation: (wifi) connection 'SchildiOne 2' has security, and secrets exist. No new secrets needed.
76.2113] Config: added 'ssid' value 'SchildiOne'
76.2115] Config: added 'scan_ssid' value '1'
76.2117] Config: added 'bgscan' value 'simple:30:-70:86400'
76.2118] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
76.2120] Config: added 'auth_alg' value 'OPEN'
76.2121] Config: added 'psk' value '<hidden>'
76.2303] device (wls4): supplicant interface state: inactive -> scanning
79.6723] device (wls4): supplicant interface state: scanning -> associating
79.7512] device (wls4): supplicant interface state: associating -> associated
79.7598] device (wls4): supplicant interface state: associated -> 4way_handshake
79.7749] device (wls4): supplicant interface state: 4way_handshake -> completed
79.7750] device (wls4): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "SchildiOne"
79.7755] device (wls4): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
79.7779] dhcp4 (wls4): activation: beginning transaction (timeout in 45 seconds)
82.0075] dhcp6 (wls4): activation: beginning transaction (timeout in 45 seconds)
24.9743] dhcp4 (wls4): request timed out
24.9744] dhcp4 (wls4): state changed unknown -> timeout
26.9748] dhcp6 (wls4): request timed out
26.9749] dhcp6 (wls4): state changed unknown -> timeout
26.9749] dhcp6 (wls4): canceled DHCP transaction
26.9749] dhcp6 (wls4): state changed timeout -> done
26.9779] device (wls4): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
27.0020] device (wls4): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
27.0029] device (wls4): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
27.0046] manager: NetworkManager state is now CONNECTED_LOCAL
27.0092] manager: NetworkManager state is now CONNECTED_SITE
27.0119] policy: set 'SchildiOne 2' (wls4) as default for IPv6 routing and DNS
27.0166] device (wls4): Activation: successful, device activated.
27.0223] manager: startup complete
