No wifi or touchpad working in OEM Laptop (XFCE)
I haven't been able to get wifi or the touchpad working on a OEM laptop i got my hands to,
the model is Vero K146 but im certain its just OEM rebranding.
without more info, it's not possible for anyone here to help you.
if your not sure, always include the terminal output of inxi -Fxxxz when making a help request.
that said, it seems that laptop is universally problematic on both windows and linux.
not much info available in english, use a translator browser extension like Mate if you need it translated
Sorry i was in a rush, Im surprised its a greek rebrand huh.
           tk: Gtk 3.24.10 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: VERO product: K146 v: N/A serial: <filter>
           Mobo: WEIBU model: N/A serial: <filter> UEFI: American Megatrends v: HQ-BI-14.1-Y116AR130-AA54E-010-B
           date: 12/27/2017
Battery:   ID-1: BAT0 charge: 33.5 Wh condition: 50.0/N/A Wh volts: 7.6/N/A model: Intel SR 1 SR Real Battery type: Unknown
           serial: <filter> status: Discharging
CPU:       Topology: Dual Core model: Intel Celeron N3350 bits: 64 type: MCP arch: Goldmont rev: 9 L2 cache: 1024 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 4377
           Speed: 796 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 796 2: 796
Graphics:  Device-1: Intel driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5a85
           Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting alternate: fbdev,vesa
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 500 (Broxton 2x6) v: 4.5 Mesa 19.1.3 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster driver: snd_hda_intel v: kernel
           bus ID: 00:0e.0 chip ID: 8086:5a98
           Sound Server: ALSA v: k5.0.21-rt16-MANJARO
Network:   Message: No Device data found.
           Device-1: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152 bus ID: 1-5.3:7 chip ID: 0bda:8152
           serial: <filter>
           IF: enp0s21f0u5u3 state: up speed: 100 Mbps duplex: full mac: <filter>
           IF-ID-1: wlp0s21f0u7i2 state: down mac: <filter>
Drives:    Local Storage: total: 29.12 GiB used: 8.08 GiB (27.7%)
           ID-1: /dev/mmcblk0 model: DF4032 size: 29.12 GiB serial: <filter> rev: 0x8 scheme: GPT
Partition: ID-1: / size: 20.26 GiB used: 8.08 GiB (39.9%) fs: ext4 dev: /dev/mmcblk0p2
           ID-2: swap-1 size: 8.12 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/mmcblk0p3
Sensors:   System Temperatures: cpu: 59.0 C mobo: N/A
Info:      Processes: 200 Uptime: 1m Memory: 3.69 GiB used: 1.15 GiB (31.1%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           Shell: bash v: 5.0.7 running in: xfce4-terminal inxi: 3.0.35
the wifi adapter is not even listed, and even on windows needs to be right next to the router to even barely work. so for wifi you might need to pickup a usb wifi adapter which are very cheap. the touchpad you could maybe get working, but again if it's not detected you would need to track down drivers that work for that touchpad. i think you should give up on the built in wifi and get a usb wifi, you'll likely spend a lot of time trying to get it working and if your even able to it will likely be trash to use.
for the touchpad, post:
libinput list-devices
hwinfo --mouse
if hwinfo is not installed, install it first.
Kernel:           /dev/input/event7
Group:            1
Seat:             seat0, default
Capabilities:     keyboard
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Middle emulation: n/a
Calibration:      n/a
Scroll methods:   none
Click methods:    none
Disable-w-typing: n/a
Accel profiles:   n/a
Rotation:         n/a
Device:           Lid Switch
Kernel:           /dev/input/event0
Group:            2
Capabilities:     switch
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Power Button
Kernel:           /dev/input/event1
Group:            3
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH Mic
Kernel:           /dev/input/event9
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH Headphone
Kernel:           /dev/input/event10
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=3
Kernel:           /dev/input/event11
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=7
Kernel:           /dev/input/event12
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=8
Kernel:           /dev/input/event13
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=9
Kernel:           /dev/input/event14
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           HDA Intel PCH HDMI/DP,pcm=10
Kernel:           /dev/input/event15
Group:            4
Capabilities:
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           YSPRINGTECH USB OPTICAL MOUSE
Kernel:           /dev/input/event3
Group:            5
Capabilities:     pointer
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      disabled
Nat.scrolling:    disabled
Middle emulation: disabled
Calibration:      n/a
Scroll methods:   button
Click methods:    none
Accel profiles:   flat *adaptive
Rotation:         n/a
Device:           phy1 WPS Button
Kernel:           /dev/input/event16
Group:            6
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           USB 2.0 Camera: USB 2.0 Camera
Kernel:           /dev/input/event8
Group:            7
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Intel HID events
Kernel:           /dev/input/event4
Group:            8
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           Intel HID 5 button array
Kernel:           /dev/input/event5
Group:            9
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
Device:           AT Translated Set 2 keyboard
Kernel:           /dev/input/event2
Group:            10
Tap-to-click:     n/a
Tap-and-drag:     n/a
Tap drag lock:    n/a
Left-handed:      n/a
Nat.scrolling:    n/a
Calibration:      n/a
Click methods:    none
Accel profiles:   n/a
Rotation:         n/a
And hardware info only shows my usb mouse.
if that laptop wasnt so obscure then i could maybe suggest a touchpad driver that may or may not work with it but theres next to nothing out there in regards to that laptop and linux other than they dont play well together. that laptop doesnt even play well with the OS is was made to work with so thats not usually a good indicator.
all i could say is try other kernels, start with the older ones like 3.16, 4.4, 4.9, 4.14
check hwinfo on each kernel and see if it's detected at all so you can at least get the hardware info
