Wifi connections aren’t showing up in the networks tab in the live boot environment. Do i just need to actually install it first, or will wifi be the same so i know how to fix it before installing?
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: N/A pcie: speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 03:00.0 chip-id: 10ec:8852
Kernel 5.15.60-1
could be not detected because:
fast boot needs to be disabled in bios - you may not have this option
fast startup needs to be disabled in windows
A quick search: AUR (en) - Packages
GitHub - lwfinger/rtw89: Driver for Realtek 8852AE, an 802.11ax device
pamac build rtw89-dkms-git
This DKMS is needed for any Kernel below 5.16. Any Kernel above has it included, so you need to blacklist the kernel driver to use this dkms. If both are installed and none is blacklisted then you get weird results.
