No wifi no ethernet no nothing Its a Stable Build of Manjaro After fresh install no wifi Ethernet.
I had A windows install now its broken the windows and the files are still there but its not showing in bios only manjaro
Hello @Lollll
Start at least with this command for information on the terminal:
inxi --full --admin --filter --width 80
and post the out put here as code:
code
code
If no other way around, then post a picture here. You are new. Links and pictures cant be posted by Trustlevel 0. Upload the picture somewhere else and post the link here as code like that with 2 backticks:
`https://mydomain.com` → https://mydomain.com
With time and action on the forum, you will reach TL1 and can post links and pictures. It is mainly spam protection. Read this: Understanding Discourse Trust Levels | Blog
Will do
