6x12
20 August 2023 18:14
34
If you’re good with a screwdriver or you live in a place where computer service is cheap here is a video of how to open/service your laptop: https://www.youtube.com/watch?v=zukdFwIooJU .
The cmos battery is under the keyboard and appears in the video at around 1:55, they are cheap and easy to get, type and model are engraved on it. Replacing them is useful because it keeps the bios settings stable even if your main battery is dead (I think it is but replacing that is not really worth it.):
Until you replace the cmos just keep your laptop plugged in at all times even when it’s shut down.
Edit:
First do your updates, reboot and run
inxi -Fazy
again so we can see the wifi card and driver status
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e0ec0b47-6af7-486a-9cc3-5456a7489838 rw quiet apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Portable System: Dell product: Inspiron N5110 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 0FXK2Y v: A07 serial: <superuser required> BIOS: Dell
v: A07 date: 07/18/2011
Info: model: Intel Core i5-2430M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/3000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 19164
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 525M] vendor: Dell driver: N/A
alternate: nouveau non-free: series: 390.xx+ status: legacy-active (EOL~late
2022) arch: Fermi code: GF1xx process: 40/28nm built: 2010-16 pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0df5 class-ID: 0300
Device-3: Microdia Laptop_Integrated_Webcam_HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.5:4
chip-ID: 0c45:6485 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: intel dri: i965 gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: AU Optronics 0x22ec built: 2009
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 0.125.0 status: off tools: N/A
Server-2: PipeWire v: 0.3.77 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 05:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Dell
driver: ath9k v: kernel pcie: speed: Unknown lanes: 63 link-max: gen: 6
speed: 64 GT/s bus-ID: 09:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
IF-ID-1: enp0s26u1u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-1.1:7 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Device-2: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:5 chip-ID: 0cf3:3005
class-ID: e001
Local Storage: total: 698.64 GiB used: 26.2 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD7500BPVT-75HXZT3 size: 698.64 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A03 scheme: MBR
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 26.2 GiB (26.8%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
compressor: zstd max-pool: 25%
ID-1: swap-1 type: file size: 8 GiB used: 249.8 MiB (3.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 61.0 C mobo: N/A
Fan Speeds (rpm): cpu: 4427
Processes: 209 Uptime: 49m wakeups: 1 Memory: total: 4 GiB
available: 3.74 GiB used: 3.18 GiB (85.0%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1195 libs: 348 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.29
6x12
20 August 2023 20:08
36
So it is indeed a Qualcomm Atheros and the driver is loaded but it’s down and that last line looks odd. Have you tried activating wifi by pressing Fn+F2 again? What does
rfkill list
show?
Also, it is possible to (de)activate the wlan by right clicking the Network Applet in the tray or panel and checking/unchecking the checkbox.
Happened more than once to my father without him realizing it and then coming to me asking me to fix the non-working wlan connection
and all I had to do was to check the box … to activate it
WLAN = wifi. It says “NotInstalled” and same for Bluetooth. So either it’s switched off or there’s a hardware issue with the wifi card.
If it is a hardware issue the card can be replaced quite easily;
system
Closed
4 December 2023 21:15
39
