Hi,
After last update, my VPN connection doesn’t work anymore. I can connect, but there is no traffic to any of the IPs that should work on VPN. I’ve checked and it is not a DNS issue, since I can’t ping any IPs or names (I receive a DNS server after connect to a VPN). I use this application to connect to a VPN: aur/ike 2.2.1-5
I tried to import the .VPN file into the system IPSEC VPN, but for some reason it doesn’t import the file (Maybe incompatible)
Here is the NetworkManager logs:
> jun 10 16:38:21 rodrigo-pc NetworkManager[843]: <warn> [1654871901.3922] platform-linux: do-add-ip6-address[3: fe80::c317:a617:3868:a5a]: failure 95 (Operation not supported)
> jun 10 16:38:23 rodrigo-pc NetworkManager[843]: <warn> [1654871903.3935] platform-linux: do-add-ip6-address[3: fe80::af22:31c6:2a6:d32f]: failure 95 (Operation not supported)
> jun 10 16:38:25 rodrigo-pc NetworkManager[843]: <warn> [1654871905.3945] platform-linux: do-add-ip6-address[3: fe80::82c9:afd:ecb1:6325]: failure 95 (Operation not supported)
> jun 10 16:38:27 rodrigo-pc NetworkManager[843]: <warn> [1654871907.3970] ipv6ll[879023a7626e6ee6,ifindex=3]: changed: no IPv6 link local address to retry after Duplicate Address Detection failures (back off)
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1351] manager: (tap0): new Tun device (/org/freedesktop/NetworkManager/Devices/7)
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1483] device (tap0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1487] device (tap0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1493] device (tap0): Activation: starting connection 'tap0' (8fcddb34-1649-4f03-a59e-50af1d7cb7ee)
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1495] device (tap0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1498] device (tap0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1500] device (tap0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1502] device (tap0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1675] device (tap0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1678] device (tap0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
> jun 10 16:38:36 rodrigo-pc NetworkManager[843]: <info> [1654871916.1682] device (tap0): Activation: successful, device activated.
> jun 10 16:38:37 rodrigo-pc NetworkManager[843]: <warn> [1654871917.3979] platform-linux: do-add-ip6-address[3: fe80::810c:b661:9f3a:b4e9]: failure 95 (Operation not supported)
> jun 10 16:38:39 rodrigo-pc NetworkManager[843]: <warn> [1654871919.3985] platform-linux: do-add-ip6-address[3: fe80::f9c7:67a4:9c7b:54c2]: failure 95 (Operation not supported)
> jun 10 16:38:41 rodrigo-pc NetworkManager[843]: <warn> [1654871921.3990] platform-linux: do-add-ip6-address[3: fe80::321c:3cea:fead:3dff]: failure 95 (Operation not supported)
> jun 10 16:38:43 rodrigo-pc NetworkManager[843]: <warn> [1654871923.3996] platform-linux: do-add-ip6-address[3: fe80::c317:a617:3868:a5a]: failure 95 (Operation not supported)
> jun 10 16:38:45 rodrigo-pc NetworkManager[843]: <warn> [1654871925.4025] platform-linux: do-add-ip6-address[3: fe80::af22:31c6:2a6:d32f]: failure 95 (Operation not supported)
> jun 10 16:38:47 rodrigo-pc NetworkManager[843]: <warn> [1654871927.4035] platform-linux: do-add-ip6-address[3: fe80::82c9:afd:ecb1:6325]: failure 95 (Operation not supported)
> jun 10 16:38:49 rodrigo-pc NetworkManager[843]: <warn> [1654871929.4043] ipv6ll[879023a7626e6ee6,ifindex=3]: changed: no IPv6 link local address to retry after Duplicate Address Detection failures (back off)
> jun 10 16:38:52 rodrigo-pc NetworkManager[843]: <info> [1654871932.1311] device (tap0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
I’m not sure which other logs I can provide to get some help.
inxi --admin --verbosity=7 --filter --width
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=badeb9d2-958c-4cf7-9452-2a4ac658ac2d rw quiet
resume=UUID=9a33e4a5-6838-4d02-8905-987482b4b36b ipv6.disable=1
pcie_aspm=off net.ifnames=0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SAMSUNG product: 800G5M/800G5W v: P14RDV
Mobo: SAMSUNG model: NP800G5M-XG2BR
v: SGL8832A0Y-C01-G003-S0001+10.0.14393 serial: <superuser required>
UEFI: American Megatrends v: P14RDV.078.181113.XJ date: 11/13/2018
ID-1: BAT1 charge: 24.6 Wh (98.0%) condition: 25.1/43.1 Wh (58.2%)
volts: 12.5 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: N/A cycles: 127
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.26 GiB used: 4.6 GiB (14.7%)
RAM Report:
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 44817
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Samsung Co driver: i915 v: kernel
ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Samsung Co
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Maxwell pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: ANYKA V380 FHD Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-1.2:6 chip-ID: 0380:2006 class-ID: 0301 serial: <filter>
Device-4: Silicon Motion Web Camera type: USB driver: uvcvideo
bus-ID: 1-8:8 chip-ID: 2232:1080 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
model: Lenovo LEN G27c-10 serial: <filter> built: 2021 res: 1920x1080
dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x06b9 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.0.4
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: ANYKA V380 FHD Camera type: USB driver: snd-usb-audio,uvcvideo
Device-3: C-Media Maono Fairy type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.3:9 chip-ID: 0d8c:016c
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.51 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Samsung Co driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
vendor: Samsung Co driver: r8169 v: kernel modules: r8168 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: eth0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
chip-ID: 0cf3:e500 class-ID: e001
Local Storage: total: 1.31 TiB used: 494.87 GiB (36.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM12.2 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 71E0 scheme: GPT
ID-1: / raw-size: 885.16 GiB size: 870.19 GiB (98.31%)
used: 494.87 GiB (56.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: badeb9d2-958c-4cf7-9452-2a4ac658ac2d
used: 284 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 03EF-24FB
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 9a33e4a5-6838-4d02-8905-987482b4b36b
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: WINTOUSB
uuid: A263-990F
ID-2: /dev/sda2 maj-min: 8:2 size: 447.02 GiB fs: ntfs label: WinToUSB
uuid: 8EEC6A8FEC6A717F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Hub-3: 1-1.1:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 1-1.1.2:7 info: Tenx Mouse type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1130:1650
Device-2: 1-1.1.4:10 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-1.2:6 info: ANYKA V380 FHD Camera type: Video,Audio,Mouse
driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 0380:2006 class-ID: 0301 serial: <filter>
Device-4: 1-1.3:9 info: C-Media Maono Fairy type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:016c class-ID: 0300
serial: <filter>
Device-5: 1-1.4:11 info: Megawin Defender Gaming Keyboard type: Keyboard
power: 100mA chip-ID: 0e6a:02c0 class-ID: 0301
Device-6: 1-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-7: 1-6:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
class-ID: e001
Device-8: 1-8:8 info: Silicon Motion Web Camera type: Video
Hub-4: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-1:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-6: 2-1.1:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 51.0 C pch: 48.5 C mobo: 51.0 C
Processes: 314 Uptime: 41m wakeups: 5 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 2129 apt: 0 pacman: 2112
lib: 521 flatpak: 8 snap: 9 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.16
