Hi,
after selecting Manjaro in Grub (Manjaro, Windows dual boot) I don’t get any video signal (all monitors report no signal), if I have more than one Monitor attached to my video card (5700XT). I get a video signal if I unplug every monitor except one. Which one I leave plugged in doesn’t seem to make any difference. I currently have two DELL WQHD monitors attached to my machine but they are different models. One is a 166Hz HDR Monitor, the other one is your standard 60Hz office monitor. The problem first popped up at some time last year and persisted ever since. I have the same issue when I try to boot the Manjaro live image. I don’t have this problem with Windows so I don’t think that it is a hardware fault.
Do you have any idea what I can do to get Manjaro working properly again?
Many thanks in advance.
Hello @EXIT_FAILURE
The xorg logs at /var/log/
can enlighten the problem. Please post them here. And please as code or post a link. Thanks
Gnome have the xorg logs somewhere hidden in your home folder, since it starts xorg as user.
I currently use XFCE4 as my Desktop environment. I had GNOME in my profile since that’s what I use on my laptop. Sorry for the confusion.
I am not allowed to insert links into my post, so I put them here as a code snippet:
Xorg.0.log:
[ 6.631]
X.Org X Server 1.20.10
[ 6.631] Build Operating System: Linux Manjaro Linux
[ 6.631] Current Operating System: Linux HeManLinux 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[ 6.631] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=43a06c6b-fbc3-44af-a654-29e55b5a739e ro quiet splash video=SVIDEO-1:d apparmor=1 security=apparmor resume=UUID=88382dcc-9b42-48ba-b8bd-274af0b9cbad udev.log_priority=3
[ 6.631] Build Date: 16 December 2020 10:33:32PM
[ 6.631]
[ 6.631] Current version of pixman: 0.40.0
[ 6.631] Before reporting problems, check http://wiki.x.org
[ 6.631] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.631] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 2 13:05:51 2021
[ 6.631] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.631] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.631] (==) No Layout section. Using the first Screen section.
[ 6.631] (==) No screen section available. Using defaults.
[ 6.631] (**) |-->Screen "Default Screen Section" (0)
[ 6.631] (**) | |-->Monitor "<default monitor>"
[ 6.631] (==) No monitor specified for screen "Default Screen Section".
[ 6.631] (==) Automatically adding devices
[ 6.631] (==) Automatically enabling devices
[ 6.631] (==) Automatically adding GPU devices
[ 6.631] (==) Automatically binding GPU devices
[ 6.631] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.631] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.631] Entry deleted from font path.
[ 6.631] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.631] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.631] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.631] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 6.631] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.631] (II) The server relies on udev to provide the list of input devices.
[ 6.631] (II) Module ABI versions:
[ 6.631] X.Org ANSI C Emulation: 0.4
[ 6.631] X.Org Video Driver: 24.1
[ 6.631] X.Org XInput driver : 24.1
[ 6.631] X.Org Server Extension : 10.0
[ 6.632] (++) using VT number 7
[ 6.632] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.632] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.646] (--) PCI:*(12@0:0:0) 1002:731f:148c:2398 rev 193, Mem @ 0xa00000000/8589934592, 0x900000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 6.646] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.646] (II) LoadModule: "glx"
[ 6.646] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.647] (II) Module glx: vendor="X.Org Foundation"
[ 6.647] compiled for 1.20.10, module version = 1.0.0
[ 6.647] ABI class: X.Org Server Extension, version 10.0
[ 6.647] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 6.647] loading driver: amdgpu
[ 6.647] (==) Matched amdgpu as autoconfigured driver 0
[ 6.647] (==) Matched ati as autoconfigured driver 1
[ 6.647] (==) Matched modesetting as autoconfigured driver 2
[ 6.647] (==) Matched fbdev as autoconfigured driver 3
[ 6.647] (==) Matched vesa as autoconfigured driver 4
[ 6.647] (==) Assigned the driver to the xf86ConfigLayout
[ 6.647] (II) LoadModule: "amdgpu"
[ 6.647] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 6.650] (II) Module amdgpu: vendor="X.Org Foundation"
[ 6.650] compiled for 1.20.8, module version = 19.1.0
[ 6.650] Module class: X.Org Video Driver
[ 6.650] ABI class: X.Org Video Driver, version 24.1
[ 6.650] (II) LoadModule: "ati"
[ 6.650] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 6.650] (II) Module ati: vendor="X.Org Foundation"
[ 6.660] (II) LoadModule: "radeon"
[ 6.661] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 6.661] (II) Module radeon: vendor="X.Org Foundation"
[ 6.661] compiled for 1.20.8, module version = 19.1.0
[ 6.661] Module class: X.Org Video Driver
[ 6.661] ABI class: X.Org Video Driver, version 24.1
[ 6.661] (II) LoadModule: "modesetting"
[ 6.661] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.661] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.661] compiled for 1.20.10, module version = 1.20.10
[ 6.661] (II) LoadModule: "fbdev"
[ 6.661] (WW) Warning, couldn't open module fbdev
[ 6.661] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 6.661] (II) LoadModule: "vesa"
[ 6.661] (WW) Warning, couldn't open module vesa
[ 6.661] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 6.661] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 6.661] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 6.663] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.663] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 6.663] (WW) Falling back to old probe method for modesetting
[ 6.664] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 6.664] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 6.664] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 6.664] (==) AMDGPU(0): Default visual is TrueColor
[ 6.664] (==) AMDGPU(0): RGB weight 888
[ 6.664] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 6.664] (--) AMDGPU(0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
[ 6.664] (II) Loading sub module "fb"
[ 6.664] (II) LoadModule: "fb"
[ 6.664] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.664] (II) Module fb: vendor="X.Org Foundation"
[ 6.664] compiled for 1.20.10, module version = 1.0.0
[ 6.664] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.664] (II) Loading sub module "dri2"
[ 6.664] (II) LoadModule: "dri2"
[ 6.664] (II) Module "dri2" already built-in
[ 6.806] (II) Loading sub module "glamoregl"
[ 6.806] (II) LoadModule: "glamoregl"
[ 6.806] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 6.811] (II) Module glamoregl: vendor="X.Org Foundation"
[ 6.811] compiled for 1.20.10, module version = 1.0.1
[ 6.811] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.831] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 5700 XT (NAVI10, DRM 3.40.0, 5.11.6-1-MANJARO, LLVM 11.1.0)
[ 6.831] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 6.831] (==) AMDGPU(0): TearFree property default: auto
[ 6.831] (==) AMDGPU(0): VariableRefresh: disabled
[ 6.831] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 6.831] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 6.832] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 6.832] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[ 6.832] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 6.844] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 6.844] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 6.844] (II) AMDGPU(0): Manufacturer: DEL Model: d0f4 Serial#: 809058902
[ 6.844] (II) AMDGPU(0): Year: 2020 Week: 16
[ 6.844] (II) AMDGPU(0): EDID Version: 1.4
[ 6.844] (II) AMDGPU(0): Digital Display Input
[ 6.844] (II) AMDGPU(0): 10 bits per channel
[ 6.844] (II) AMDGPU(0): Digital interface is DisplayPort
[ 6.844] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 70 vert.: 40
[ 6.844] (II) AMDGPU(0): Gamma: 2.20
[ 6.844] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 6.844] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 6.844] (II) AMDGPU(0): First detailed timing is preferred mode
[ 6.844] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 6.844] (II) AMDGPU(0): Display is continuous-frequency
[ 6.844] (II) AMDGPU(0): redX: 0.676 redY: 0.314 greenX: 0.272 greenY: 0.657
[ 6.844] (II) AMDGPU(0): blueX: 0.151 blueY: 0.068 whiteX: 0.313 whiteY: 0.329
[ 6.844] (II) AMDGPU(0): Supported established timings:
[ 6.844] (II) AMDGPU(0): 720x400@70Hz
[ 6.844] (II) AMDGPU(0): 640x480@60Hz
[ 6.844] (II) AMDGPU(0): 640x480@75Hz
[ 6.844] (II) AMDGPU(0): 800x600@60Hz
[ 6.844] (II) AMDGPU(0): 800x600@75Hz
[ 6.844] (II) AMDGPU(0): 1024x768@60Hz
[ 6.844] (II) AMDGPU(0): 1024x768@75Hz
[ 6.844] (II) AMDGPU(0): 1280x1024@75Hz
[ 6.844] (II) AMDGPU(0): Manufacturer's mask: 0
[ 6.844] (II) AMDGPU(0): Supported standard timings:
[ 6.844] (II) AMDGPU(0): #0: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 6.844] (II) AMDGPU(0): #1: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 6.844] (II) AMDGPU(0): #2: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 6.844] (II) AMDGPU(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 6.844] (II) AMDGPU(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 6.844] (II) AMDGPU(0): #5: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 6.844] (II) AMDGPU(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 6.844] (II) AMDGPU(0): Supported detailed timing:
[ 6.844] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 697 x 392 mm
[ 6.844] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 6.844] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 6.844] (II) AMDGPU(0): Serial No: B38M4W2
[ 6.844] (II) AMDGPU(0): Monitor name: DELL S3220DGF
[ 6.844] (II) AMDGPU(0): Ranges: V min: 48 V max: 164 Hz, H min: 250 H max: 250 kHz, PixClock max 655 MHz
[ 6.844] (II) AMDGPU(0): clock: 641.0 MHz Image Size: 697 x 392 mm
[ 6.844] (II) AMDGPU(0): h_active: 2560 h_sync: 2568 h_sync_end 2600 h_blank_end 2640 h_border: 0
[ 6.844] (II) AMDGPU(0): v_active: 1440 v_sync: 1446 v_sync_end 1454 v_blanking: 1480 v_border: 0
[ 6.844] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 697 x 392 mm
[ 6.844] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 6.844] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 6.844] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 6.844] (II) AMDGPU(0): EDID (in hex):
[ 6.844] (II) AMDGPU(0): 00ffffffffffff0010acf4d056423930
[ 6.844] (II) AMDGPU(0): 101e0104b5462878fb2de5ad5045a826
[ 6.844] (II) AMDGPU(0): 115054a54b008100b300d100714fa940
[ 6.844] (II) AMDGPU(0): 8180d1c00101565e00a0a0a029503020
[ 6.844] (II) AMDGPU(0): 3500b9882100001a000000ff00423338
[ 6.844] (II) AMDGPU(0): 4d3457320a2020202020000000fc0044
[ 6.844] (II) AMDGPU(0): 454c4c205333323230444746000000fd
[ 6.844] (II) AMDGPU(0): 0030a4fafa41010a202020202020014b
[ 6.844] (II) AMDGPU(0): 02033bf14f9005040302071601061112
[ 6.844] (II) AMDGPU(0): 1513141f230907078301000065030c00
[ 6.844] (II) AMDGPU(0): 1000e305c000e60605096c6c2c6d1a00
[ 6.844] (II) AMDGPU(0): 00020330a4000f6c2c6c2c64fa0050a0
[ 6.844] (II) AMDGPU(0): a0285008206800b9882100001a023a80
[ 6.844] (II) AMDGPU(0): 1871382d40582c4500b9882100001e00
[ 6.844] (II) AMDGPU(0): 00000000000000000000000000000000
[ 6.844] (II) AMDGPU(0): 00000000000000000000000000000014
[ 6.844] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[ 6.845] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 6.845] (II) AMDGPU(0): Modeline "2560x1440"x164.1 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1440x900"x60.0 241.50 1440 2608 2640 2720 900 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.845] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6.845] (II) AMDGPU(0): EDID for output DisplayPort-2
[ 6.845] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 6.845] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 6.845] (II) AMDGPU(0): Output DisplayPort-1 connected
[ 6.845] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[ 6.845] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 6.845] (II) AMDGPU(0): Using exact sizes for initial modes
[ 6.845] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 2560x1440 +0+0
[ 6.845] (II) AMDGPU(0): mem size init: gart size :1fe5bd000 vram size: s:1fce94000 visible:1fce94000
[ 6.845] (==) AMDGPU(0): DPI set to (96, 96)
[ 6.845] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.845] (II) Loading sub module "ramdac"
[ 6.845] (II) LoadModule: "ramdac"
[ 6.845] (II) Module "ramdac" already built-in
[ 6.845] (II) UnloadModule: "radeon"
[ 6.845] (II) Unloading radeon
[ 6.845] (II) UnloadModule: "modesetting"
[ 6.845] (II) Unloading modesetting
[ 6.845] (II) AMDGPU(0): [DRI2] Setup complete
[ 6.845] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 6.845] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 6.846] (II) AMDGPU(0): Front buffer pitch: 10240 bytes
[ 6.847] (II) AMDGPU(0): SYNC extension fences enabled
[ 6.847] (II) AMDGPU(0): Present extension enabled
[ 6.847] (==) AMDGPU(0): DRI3 enabled
[ 6.847] (==) AMDGPU(0): Backing store enabled
[ 6.847] (II) AMDGPU(0): Direct rendering enabled
[ 6.864] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 6.864] (II) AMDGPU(0): Acceleration enabled
[ 6.864] (==) AMDGPU(0): DPMS enabled
[ 6.864] (==) AMDGPU(0): Silken mouse disabled
[ 6.865] (II) AMDGPU(0): Set up textured video (glamor)
[ 6.878] (II) Initializing extension Generic Event Extension
[ 6.878] (II) Initializing extension SHAPE
[ 6.878] (II) Initializing extension MIT-SHM
[ 6.878] (II) Initializing extension XInputExtension
[ 6.878] (II) Initializing extension XTEST
[ 6.878] (II) Initializing extension BIG-REQUESTS
[ 6.878] (II) Initializing extension SYNC
[ 6.878] (II) Initializing extension XKEYBOARD
[ 6.878] (II) Initializing extension XC-MISC
[ 6.878] (II) Initializing extension SECURITY
[ 6.878] (II) Initializing extension XFIXES
[ 6.879] (II) Initializing extension RENDER
[ 6.879] (II) Initializing extension RANDR
[ 6.879] (II) Initializing extension COMPOSITE
[ 6.879] (II) Initializing extension DAMAGE
[ 6.879] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.879] (II) Initializing extension DOUBLE-BUFFER
[ 6.879] (II) Initializing extension RECORD
[ 6.879] (II) Initializing extension DPMS
[ 6.879] (II) Initializing extension Present
[ 6.879] (II) Initializing extension DRI3
[ 6.879] (II) Initializing extension X-Resource
[ 6.880] (II) Initializing extension XVideo
[ 6.880] (II) Initializing extension XVideo-MotionCompensation
[ 6.880] (II) Initializing extension GLX
[ 6.883] (II) AIGLX: Loaded and initialized radeonsi
[ 6.883] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 6.883] (II) Initializing extension XFree86-VidModeExtension
[ 6.884] (II) Initializing extension XFree86-DGA
[ 6.884] (II) Initializing extension XFree86-DRI
[ 6.884] (II) Initializing extension DRI2
[ 6.888] (II) AMDGPU(0): Setting screen physical size to 677 x 381
[ 7.002] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.002] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.002] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.002] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.002] (II) LoadModule: "libinput"
[ 7.002] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.005] (II) Module libinput: vendor="X.Org Foundation"
[ 7.005] compiled for 1.20.8, module version = 0.30.0
[ 7.005] Module class: X.Org XInput Driver
[ 7.005] ABI class: X.Org XInput driver, version 24.1
[ 7.005] (II) Using input driver 'libinput' for 'Power Button'
[ 7.005] (**) Power Button: always reports core events
[ 7.005] (**) Option "Device" "/dev/input/event1"
[ 7.005] (**) Option "_source" "server/udev"
[ 7.010] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.010] (II) event1 - Power Button: device is a keyboard
[ 7.010] (II) event1 - Power Button: device removed
[ 7.053] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 7.053] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.053] (**) Option "xkb_layout" "de"
[ 7.071] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.071] (II) event1 - Power Button: device is a keyboard
[ 7.071] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 7.071] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.071] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.071] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.071] (II) Using input driver 'libinput' for 'Power Button'
[ 7.071] (**) Power Button: always reports core events
[ 7.071] (**) Option "Device" "/dev/input/event0"
[ 7.071] (**) Option "_source" "server/udev"
[ 7.072] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 7.072] (II) event0 - Power Button: device is a keyboard
[ 7.072] (II) event0 - Power Button: device removed
[ 7.120] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 7.120] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 7.120] (**) Option "xkb_layout" "de"
[ 7.120] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 7.121] (II) event0 - Power Button: device is a keyboard
[ 7.121] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/event9)
[ 7.121] (II) No input driver specified, ignoring this device.
[ 7.121] (II) This device may have been added with another device file.
[ 7.122] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/js0)
[ 7.122] (II) No input driver specified, ignoring this device.
[ 7.122] (II) This device may have been added with another device file.
[ 7.123] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event3)
[ 7.123] (II) No input driver specified, ignoring this device.
[ 7.123] (II) This device may have been added with another device file.
[ 7.124] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event4)
[ 7.124] (II) No input driver specified, ignoring this device.
[ 7.124] (II) This device may have been added with another device file.
[ 7.124] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event5)
[ 7.124] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event6)
[ 7.125] (II) No input driver specified, ignoring this device.
[ 7.125] (II) This device may have been added with another device file.
[ 7.125] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event7)
[ 7.125] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event8)
[ 7.126] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)
[ 7.126] (II) No input driver specified, ignoring this device.
[ 7.126] (II) This device may have been added with another device file.
[ 7.934] (II) config/udev: Adding input device Creative Technology Ltd Sound BlasterX G6 (/dev/input/event10)
[ 7.934] (**) Creative Technology Ltd Sound BlasterX G6: Applying InputClass "evdev keyboard catchall"
[ 7.934] (**) Creative Technology Ltd Sound BlasterX G6: Applying InputClass "libinput keyboard catchall"
[ 7.934] (**) Creative Technology Ltd Sound BlasterX G6: Applying InputClass "system-keyboard"
[ 7.934] (II) Using input driver 'libinput' for 'Creative Technology Ltd Sound BlasterX G6'
[ 7.934] (**) Creative Technology Ltd Sound BlasterX G6: always reports core events
[ 7.934] (**) Option "Device" "/dev/input/event10"
[ 7.934] (**) Option "_source" "server/udev"
[ 7.937] (II) event10 - Creative Technology Ltd Sound BlasterX G6: is tagged by udev as: Keyboard
[ 7.937] (II) event10 - Creative Technology Ltd Sound BlasterX G6: device is a keyboard
[ 7.937] (II) event10 - Creative Technology Ltd Sound BlasterX G6: device removed
[ 7.960] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.2/3-2.2:1.3/0003:041E:3256.0001/input/input10/event10"
[ 7.960] (II) XINPUT: Adding extended input device "Creative Technology Ltd Sound BlasterX G6" (type: KEYBOARD, id 8)
[ 7.960] (**) Option "xkb_layout" "de"
[ 7.962] (II) event10 - Creative Technology Ltd Sound BlasterX G6: is tagged by udev as: Keyboard
[ 7.962] (II) event10 - Creative Technology Ltd Sound BlasterX G6: device is a keyboard
[ 7.965] (II) config/udev: Adding input device DEMO1 (/dev/input/event19)
[ 7.965] (**) DEMO1 : Applying InputClass "evdev keyboard catchall"
[ 7.965] (**) DEMO1 : Applying InputClass "libinput keyboard catchall"
[ 7.965] (**) DEMO1 : Applying InputClass "system-keyboard"
[ 7.965] (II) Using input driver 'libinput' for 'DEMO1 '
[ 7.965] (**) DEMO1 : always reports core events
[ 7.965] (**) Option "Device" "/dev/input/event19"
[ 7.965] (**) Option "_source" "server/udev"
[ 7.967] (II) event19 - DEMO1 : is tagged by udev as: Keyboard
[ 7.967] (II) event19 - DEMO1 : device is a keyboard
[ 7.967] (II) event19 - DEMO1 : device removed
[ 8.048] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.2/3-2.1.2:1.0/input/input21/event19"
[ 8.048] (II) XINPUT: Adding extended input device "DEMO1 " (type: KEYBOARD, id 9)
[ 8.048] (**) Option "xkb_layout" "de"
[ 8.053] (II) event19 - DEMO1 : is tagged by udev as: Keyboard
[ 8.053] (II) event19 - DEMO1 : device is a keyboard
[ 8.139] (II) config/udev: Adding input device Logitech USB Receiver System Control (/dev/input/event14)
[ 8.139] (**) Logitech USB Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 8.139] (**) Logitech USB Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 8.139] (**) Logitech USB Receiver System Control: Applying InputClass "system-keyboard"
[ 8.139] (II) Using input driver 'libinput' for 'Logitech USB Receiver System Control'
[ 8.139] (**) Logitech USB Receiver System Control: always reports core events
[ 8.139] (**) Option "Device" "/dev/input/event14"
[ 8.139] (**) Option "_source" "server/udev"
[ 8.142] (II) event14 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 8.142] (II) event14 - Logitech USB Receiver System Control: device is a keyboard
[ 8.142] (II) event14 - Logitech USB Receiver System Control: device removed
[ 8.186] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.3/3-2.1.1.3:1.1/0003:046D:C53D.0004/input/input14/event14"
[ 8.186] (II) XINPUT: Adding extended input device "Logitech USB Receiver System Control" (type: KEYBOARD, id 10)
[ 8.186] (**) Option "xkb_layout" "de"
[ 8.189] (II) event14 - Logitech USB Receiver System Control: is tagged by udev as: Keyboard
[ 8.189] (II) event14 - Logitech USB Receiver System Control: device is a keyboard
[ 8.190] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event11)
[ 8.190] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[ 8.190] (**) Logitech USB Receiver: Applying InputClass "libinput keyboard catchall"
[ 8.190] (**) Logitech USB Receiver: Applying InputClass "system-keyboard"
[ 8.190] (II) Using input driver 'libinput' for 'Logitech USB Receiver'
[ 8.190] (**) Logitech USB Receiver: always reports core events
[ 8.190] (**) Option "Device" "/dev/input/event11"
[ 8.190] (**) Option "_source" "server/udev"
[ 8.192] (II) event11 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 8.192] (II) event11 - Logitech USB Receiver: device is a keyboard
[ 8.192] (II) event11 - Logitech USB Receiver: device removed
[ 8.226] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.3/3-2.1.1.3:1.0/0003:046D:C53D.0003/input/input11/event11"
[ 8.226] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[ 8.226] (**) Option "xkb_layout" "de"
[ 8.229] (II) event11 - Logitech USB Receiver: is tagged by udev as: Keyboard
[ 8.229] (II) event11 - Logitech USB Receiver: device is a keyboard
[ 8.230] (II) config/udev: Adding input device Logitech USB Receiver Consumer Control (/dev/input/event13)
[ 8.230] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.230] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.230] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 8.230] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 8.230] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 8.230] (**) Option "Device" "/dev/input/event13"
[ 8.230] (**) Option "_source" "server/udev"
[ 8.232] (II) event13 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 8.232] (II) event13 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 8.233] (II) event13 - Logitech USB Receiver Consumer Control: device removed
[ 8.253] (II) libinput: Logitech USB Receiver Consumer Control: needs a virtual subdevice
[ 8.253] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.3/3-2.1.1.3:1.1/0003:046D:C53D.0004/input/input13/event13"
[ 8.253] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: MOUSE, id 12)
[ 8.253] (**) Option "AccelerationScheme" "none"
[ 8.253] (**) Logitech USB Receiver Consumer Control: (accel) selected scheme none/0
[ 8.253] (**) Logitech USB Receiver Consumer Control: (accel) acceleration factor: 2.000
[ 8.253] (**) Logitech USB Receiver Consumer Control: (accel) acceleration threshold: 4
[ 8.255] (II) event13 - Logitech USB Receiver Consumer Control: is tagged by udev as: Keyboard
[ 8.255] (II) event13 - Logitech USB Receiver Consumer Control: device is a keyboard
[ 8.256] (**) Logitech USB Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 8.256] (**) Logitech USB Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 8.256] (**) Logitech USB Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 8.256] (II) Using input driver 'libinput' for 'Logitech USB Receiver Consumer Control'
[ 8.256] (**) Logitech USB Receiver Consumer Control: always reports core events
[ 8.256] (**) Option "Device" "/dev/input/event13"
[ 8.256] (**) Option "_source" "_driver/libinput"
[ 8.256] (II) libinput: Logitech USB Receiver Consumer Control: is a virtual subdevice
[ 8.256] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.3/3-2.1.1.3:1.1/0003:046D:C53D.0004/input/input13/event13"
[ 8.256] (II) XINPUT: Adding extended input device "Logitech USB Receiver Consumer Control" (type: KEYBOARD, id 13)
[ 8.256] (**) Option "xkb_layout" "de"
[ 8.258] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/event12)
[ 8.258] (**) Logitech USB Receiver Mouse: Applying InputClass "evdev pointer catchall"
[ 8.258] (**) Logitech USB Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 8.258] (II) Using input driver 'libinput' for 'Logitech USB Receiver Mouse'
[ 8.258] (**) Logitech USB Receiver Mouse: always reports core events
[ 8.258] (**) Option "Device" "/dev/input/event12"
[ 8.258] (**) Option "_source" "server/udev"
[ 8.261] (II) event12 - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[ 8.261] (II) event12 - Logitech USB Receiver Mouse: device is a pointer
[ 8.262] (II) event12 - Logitech USB Receiver Mouse: device removed
[ 8.346] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.3/3-2.1.1.3:1.1/0003:046D:C53D.0004/input/input12/event12"
[ 8.346] (II) XINPUT: Adding extended input device "Logitech USB Receiver Mouse" (type: MOUSE, id 14)
[ 8.346] (**) Option "AccelerationScheme" "none"
[ 8.346] (**) Logitech USB Receiver Mouse: (accel) selected scheme none/0
[ 8.346] (**) Logitech USB Receiver Mouse: (accel) acceleration factor: 2.000
[ 8.346] (**) Logitech USB Receiver Mouse: (accel) acceleration threshold: 4
[ 8.349] (II) event12 - Logitech USB Receiver Mouse: is tagged by udev as: Mouse
[ 8.349] (II) event12 - Logitech USB Receiver Mouse: device is a pointer
[ 8.350] (II) config/udev: Adding input device Logitech USB Receiver Mouse (/dev/input/mouse0)
[ 8.350] (II) No input driver specified, ignoring this device.
[ 8.350] (II) This device may have been added with another device file.
[ 8.962] (II) config/udev: Adding input device Logitech MX Vertical (/dev/input/mouse1)
[ 8.962] (**) Logitech MX Vertical: Applying InputClass "system-keyboard"
[ 8.962] (II) No input driver specified, ignoring this device.
[ 8.962] (II) This device may have been added with another device file.
[ 9.032] (II) config/udev: Adding input device Logitech MX Vertical (/dev/input/event15)
[ 9.032] (**) Logitech MX Vertical: Applying InputClass "evdev pointer catchall"
[ 9.032] (**) Logitech MX Vertical: Applying InputClass "evdev keyboard catchall"
[ 9.032] (**) Logitech MX Vertical: Applying InputClass "libinput pointer catchall"
[ 9.032] (**) Logitech MX Vertical: Applying InputClass "libinput keyboard catchall"
[ 9.032] (**) Logitech MX Vertical: Applying InputClass "system-keyboard"
[ 9.032] (II) Using input driver 'libinput' for 'Logitech MX Vertical'
[ 9.032] (**) Logitech MX Vertical: always reports core events
[ 9.032] (**) Option "Device" "/dev/input/event15"
[ 9.032] (**) Option "_source" "server/udev"
[ 9.035] (II) event15 - Logitech MX Vertical: is tagged by udev as: Keyboard Mouse
[ 9.035] (II) event15 - Logitech MX Vertical: device is a pointer
[ 9.035] (II) event15 - Logitech MX Vertical: device is a keyboard
[ 9.035] (II) event15 - Logitech MX Vertical: device removed
[ 9.080] (II) libinput: Logitech MX Vertical: needs a virtual subdevice
[ 9.080] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.4/3-2.1.1.4:1.2/0003:046D:C52B.0008/0003:046D:407B.0009/input/input28/event15"
[ 9.080] (II) XINPUT: Adding extended input device "Logitech MX Vertical" (type: MOUSE, id 15)
[ 9.080] (**) Option "AccelerationScheme" "none"
[ 9.080] (**) Logitech MX Vertical: (accel) selected scheme none/0
[ 9.080] (**) Logitech MX Vertical: (accel) acceleration factor: 2.000
[ 9.080] (**) Logitech MX Vertical: (accel) acceleration threshold: 4
[ 9.082] (II) event15 - Logitech MX Vertical: is tagged by udev as: Keyboard Mouse
[ 9.082] (II) event15 - Logitech MX Vertical: device is a pointer
[ 9.082] (II) event15 - Logitech MX Vertical: device is a keyboard
[ 9.083] (**) Logitech MX Vertical: Applying InputClass "evdev pointer catchall"
[ 9.083] (**) Logitech MX Vertical: Applying InputClass "evdev keyboard catchall"
[ 9.083] (**) Logitech MX Vertical: Applying InputClass "libinput pointer catchall"
[ 9.083] (**) Logitech MX Vertical: Applying InputClass "libinput keyboard catchall"
[ 9.083] (**) Logitech MX Vertical: Applying InputClass "system-keyboard"
[ 9.083] (II) Using input driver 'libinput' for 'Logitech MX Vertical'
[ 9.083] (**) Logitech MX Vertical: always reports core events
[ 9.083] (**) Option "Device" "/dev/input/event15"
[ 9.083] (**) Option "_source" "_driver/libinput"
[ 9.083] (II) libinput: Logitech MX Vertical: is a virtual subdevice
[ 9.083] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.2/0000:03:09.0/0000:09:00.0/usb3/3-2/3-2.1/3-2.1.1/3-2.1.1.4/3-2.1.1.4:1.2/0003:046D:C52B.0008/0003:046D:407B.0009/input/input28/event15"
[ 9.083] (II) XINPUT: Adding extended input device "Logitech MX Vertical" (type: KEYBOARD, id 16)
[ 9.083] (**) Option "xkb_layout" "de"
[ 13.258] (II) AMDGPU(0): EDID vendor "DEL", prod id 53492
[ 13.258] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 13.258] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 13.258] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 13.258] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 13.258] (II) AMDGPU(0): Modeline "2560x1440"x0.0 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 13.258] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 14.196] (II) AMDGPU(0): EDID vendor "DEL", prod id 53492
[ 14.196] (II) AMDGPU(0): Using hsync ranges from config file
[ 14.196] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 14.196] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 14.196] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 14.196] (II) AMDGPU(0): Modeline "2560x1440"x0.0 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 14.196] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 19.078] (II) AMDGPU(0): EDID vendor "DEL", prod id 53492
[ 19.078] (II) AMDGPU(0): Using hsync ranges from config file
[ 19.078] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 19.078] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 19.078] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 19.078] (II) AMDGPU(0): Modeline "2560x1440"x0.0 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 19.078] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 34.104] (II) AMDGPU(0): EDID vendor "DEL", prod id 53492
[ 34.104] (II) AMDGPU(0): Using hsync ranges from config file
[ 34.104] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 34.104] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 34.104] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 34.104] (II) AMDGPU(0): Modeline "2560x1440"x0.0 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 34.104] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 59.114] (II) AMDGPU(0): EDID vendor "DEL", prod id 53492
[ 59.114] (II) AMDGPU(0): Using hsync ranges from config file
[ 59.114] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 59.114] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 59.114] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
[ 59.114] (II) AMDGPU(0): Modeline "2560x1440"x0.0 641.00 2560 2568 2600 2640 1440 1446 1454 1480 +hsync -vsync (242.8 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 59.114] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 184.507] (EE) event11 - Logitech USB Receiver: client bug: event processing lagging behind by 31ms, your system is too slow
[ 265.377] (EE) client bug: timer event15 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[ 265.377] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[ 303.891] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[ 315.009] (EE) client bug: timer event15 debounce: scheduled expiry is in the past (-11ms), your system is too slow
[ 315.009] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-24ms), your system is too slow
[ 411.730] (EE) event15 - Logitech MX Vertical: client bug: event processing lagging behind by 17ms, your system is too slow
[ 428.131] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 517.380] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-5ms), your system is too slow
[ 560.650] (EE) event15 - Logitech MX Vertical: client bug: event processing lagging behind by 14ms, your system is too slow
[ 615.920] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 619.109] (EE) client bug: timer event15 debounce: scheduled expiry is in the past (-4ms), your system is too slow
[ 619.109] (EE) client bug: timer event15 debounce short: scheduled expiry is in the past (-17ms), your system is too slow
Xorg.0.log.old:
[ 6.226]
X.Org X Server 1.20.10
[ 6.226] Build Operating System: Linux Manjaro Linux
[ 6.226] Current Operating System: Linux HeManLinux 5.11.6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[ 6.226] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=43a06c6b-fbc3-44af-a654-29e55b5a739e ro quiet splash video=SVIDEO-1:d apparmor=1 security=apparmor resume=UUID=88382dcc-9b42-48ba-b8bd-274af0b9cbad udev.log_priority=3
[ 6.226] Build Date: 16 December 2020 10:33:32PM
[ 6.226]
[ 6.226] Current version of pixman: 0.40.0
[ 6.226] Before reporting problems, check http://wiki.x.org
[ 6.226] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.226] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 2 13:05:51 2021
[ 6.227] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.227] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.227] (==) No Layout section. Using the first Screen section.
[ 6.227] (==) No screen section available. Using defaults.
[ 6.227] (**) |-->Screen "Default Screen Section" (0)
[ 6.227] (**) | |-->Monitor "<default monitor>"
[ 6.227] (==) No monitor specified for screen "Default Screen Section".
[ 6.227] (==) Automatically adding devices
[ 6.227] (==) Automatically enabling devices
[ 6.227] (==) Automatically adding GPU devices
[ 6.227] (==) Automatically binding GPU devices
[ 6.227] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.227] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.227] Entry deleted from font path.
[ 6.227] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.227] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.227] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.227] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 6.227] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.227] (II) The server relies on udev to provide the list of input devices.
[ 6.227] (II) Module ABI versions:
[ 6.227] X.Org ANSI C Emulation: 0.4
[ 6.227] X.Org Video Driver: 24.1
[ 6.227] X.Org XInput driver : 24.1
[ 6.227] X.Org Server Extension : 10.0
[ 6.228] (++) using VT number 7
[ 6.228] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.233] (--) PCI:*(12@0:0:0) 1002:731f:148c:2398 rev 193, Mem @ 0xa00000000/8589934592, 0x900000000/2097152, 0xfcc00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 6.233] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.233] (II) LoadModule: "glx"
[ 6.233] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.234] (II) Module glx: vendor="X.Org Foundation"
[ 6.234] compiled for 1.20.10, module version = 1.0.0
[ 6.234] ABI class: X.Org Server Extension, version 10.0
[ 6.234] (==) Matched ati as autoconfigured driver 0
[ 6.234] (==) Matched modesetting as autoconfigured driver 1
[ 6.234] (==) Matched fbdev as autoconfigured driver 2
[ 6.234] (==) Matched vesa as autoconfigured driver 3
[ 6.234] (==) Assigned the driver to the xf86ConfigLayout
[ 6.234] (II) LoadModule: "ati"
[ 6.234] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 6.234] (II) Module ati: vendor="X.Org Foundation"
[ 6.234] compiled for 1.20.8, module version = 19.1.0
[ 6.234] Module class: X.Org Video Driver
[ 6.234] ABI class: X.Org Video Driver, version 24.1
[ 6.235] (II) LoadModule: "radeon"
[ 6.235] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 6.235] (II) Module radeon: vendor="X.Org Foundation"
[ 6.235] compiled for 1.20.8, module version = 19.1.0
[ 6.235] Module class: X.Org Video Driver
[ 6.235] ABI class: X.Org Video Driver, version 24.1
[ 6.235] (II) LoadModule: "modesetting"
[ 6.235] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.236] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.236] compiled for 1.20.10, module version = 1.20.10
[ 6.236] Module class: X.Org Video Driver
[ 6.236] ABI class: X.Org Video Driver, version 24.1
[ 6.236] (II) LoadModule: "fbdev"
[ 6.236] (WW) Warning, couldn't open module fbdev
[ 6.236] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 6.236] (II) LoadModule: "vesa"
[ 6.236] (WW) Warning, couldn't open module vesa
[ 6.236] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 6.236] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 6.238] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.239] (EE) open /dev/dri/card0: No such file or directory
[ 6.239] (WW) Falling back to old probe method for modesetting
[ 6.239] (EE) Screen 0 deleted because of no matching config section.
[ 6.239] (II) UnloadModule: "modesetting"
[ 6.239] (EE) Device(s) detected, but none match those in the config file.
[ 6.239] (EE)
Fatal server error:
[ 6.239] (EE) no screens found(EE)
[ 6.239] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 6.239] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 6.239] (EE)
[ 6.239] (EE) Server terminated with error (1). Closing log file.
The Xorg.1.log file in the same folder was empty.
These logs where from a boot with only one monitor attached. If you need them from a boot with both monitors attached, I’ll activate the ssh server and see if I can get them this way.
Please let me know, if you need anything else.
Thanks for your help.
I moved the thread to boot again since nobdy seed to be able to help in the sunforum the mod moved it to and also: I’m not able to boot the system when more than one monitor is attached, I mean I’m not even able to boot the live image when I have more than one monitor attached.
I see you have modsetting activated, but no config for modsetting set. So therefore it does not display anything.
What says:
mhwd -li
Only video-linux should be displayed. If video-vesa or video-modesetting is there, then remove it.
