No user dirs in thunar
No user dirs (downloads, music, documents…) in side panel (places).
xdg-user-dirs installed,
user-dirs.dirs and user-dirs.locale where they should be.
Don’t understand what am i doing wrong, maybe anyone can help.
First check if the folders exist in your home
ls $HOME
If they are it is a matter of configuring xfce
If they are not then you need them to be created
xdg-user-dirs-update --force
Since you mention thunar - I think xfce
xdg-user-dirs-gtk-update
Just grab the folder (left click and hold) and slide it over to the left where you want it to be in the side panel.
xdg-user-dirs-gtk fixes the problem, thank you.
May i ask why it’s not installed by default?
By the way i use Manjaro Xfce minimal.
Perhaps because it is the minimal :man_shrugging: but I really don’t know.
