Hello friends, it’s been several months such that pacman doesn’t update metadata properly and doesn’t notify me when new version of some packages are available.
Even if I go check the package on pacman, it doesn’t show me the real up to date version of the package.
I need to construct the package again so pacman update it.
Is there a way to solve this problem?
You may need to refresh the database, try: sudo pacman -Syyu
Welcome to the forum!
pacman
does not handle the AUR, and it also doesn’t have a GUI. Did you mean pamac
instead?
Thanks for the fast answer, I checked just a few seconds ago
I don’t why but AUR update check was disabled
Really sorry for bothering
Apologies, I missed that the thread was tagged AUR
You’re right, I always mix them up
Sorry
