No tengo audio en los parlantes de mi laptop
Hola
Tengo un problema, acabo de instalar manjaro KDE, y no puedo reproducir audio por los parlantes de mi portátil, pero si, cuando conecto los auriculares.
Soy nuevo en esto de linux, espero me tengan mucha paciencia.
System:    Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
           wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: HP product: HP Pavilion Laptop 15-cw0xxx v: N/A serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: HP model: 84E7 v: 99.22 serial: <filter> UEFI: AMI v: F.35 date: 09/24/2019
Battery:   ID-1: BAT0 charge: 38.1 Wh condition: 38.1/38.1 Wh (100%) volts: 13.1/11.6 model: Hewlett-Packard Primary
           type: Li-ion serial: N/A status: Full cycles: 342
Memory:    RAM: total: 10.71 GiB used: 1.97 GiB (18.4%)
CPU:       Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen rev: 0
           L2 cache: 2 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31949
           Speed: 1477 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1477 2: 2040 3: 1397 4: 1523 5: 1371
           6: 1374 7: 1371 8: 1376
Graphics:  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Hewlett-Packard driver: amdgpu
           v: kernel bus ID: 03:00.0 chip ID: 1002:15dd
           Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Integrated Webcam type: USB driver: uvcvideo
           bus ID: 3-1.2:3 chip ID: 05c8:03bc
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,ati unloaded: modesetting
           alternate: fbdev,vesa resolution: 1366x768~60Hz s-dpi: 96
           OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.0) v: 4.6 Mesa 20.3.1
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus ID: 03:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.9.16-1-MANJARO
Network:   Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8821ce v: N/A
           port: f000 bus ID: 01:00.0 chip ID: 10ec:c821
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
           port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 931.51 GiB used: 8.17 GiB (0.9%)
           ID-1: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 1C
Partition: ID-1: / size: 95.67 GiB used: 8.17 GiB (8.5%) fs: ext4 dev: /dev/sda9
           ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda6
Swap:      ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda7
Sensors:   System Temperatures: cpu: 54.5 C mobo: N/A gpu: amdgpu temp: 54.0 C
Info:      Processes: 220 Uptime: 21m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1241
           Shell: Bash v: 5.1.0 running in: yakuake inxi: 3.2.01
Espero me puedan ayudar.
¿Estamos hablando de conectar por el conector Jack? Es decir, ¿tanto los parlantes como los auriculares se conectan por Jack? Si es así, entonces no parece un problema de Manjaro sino de tus parlantes.
No, tengo instalado el manjaro en una laptop y tiene los parlantes incorporados. El problema es que no tengo audio en esos parlantes, pero si tengo audio cuando conecto un auricular o un parlante externo, por medio del jack.
¿Has probado a ver si con alsamixer puedes solucionar el problema?
ya se soluciono el error gracias, hubo una actualización y se soluciono solo el error gracias.
