no system sounds in Deepin logout shutdown
I installed Deepin with the architect installer. I have no system sounds when shutdown or logout ...etc
I really like the sounds in Deepin
How can I get them to play on manjaro.
You should check if here
/usr/share/sounds/deepin/stereo
are the Deepin-system sound files.
If the files are there, have you activated system sounds in your settings?
That means you did not install the deepin-desktop-schemas-manjaro that contains the default gschemas including the dependency of deepin-sound-theme package. So, install it manually from terminal:
sudo pacman -S deepin-sound-theme
Then do what was suggested above.
Thank you @pamalosebi and @bogdancovaciu I will check and let you guys know. Thanks for your help guys wonderful will get back to you.
I have checked all deepin sound files are there in /usr/share/sounds/deepin/stereo
in settings they are all activated all the sounds. I still don't have shutdown or logout sound
The deepin-desktop-schemas-manjaro are installed. I don't have shutdown or logout sounds.
