Hello everyone.
I have trouble with my network interface on Intel I225-V chipset. Everything works nice, except no RX/TX stats are provided for it, so I can’t track network activity in any of system monitors.
Zero stats on enp6s0 :
eden@sunce:~ > cat /proc/net/dev
Inter-| Receive | Transmit
face |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed
lo: 38925 159 0 0 0 0 0 0 38925 159 0 0 0 0 0 0
enp6s0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
wlp5s0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Stats in separate files:
eden@sunce:~ > cat /sys/class/net/enp6s0/statistics/*
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Available interfaces:
eden@sunce:~ > ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 24:4b:fe:5d:61:4d brd ff:ff:ff:ff:ff:ff
inet 192.168.1.69/24 brd 192.168.1.255 scope global noprefixroute enp6s0
inet6 fe80::e555:b19a:4355:249f/64 scope link noprefixroute
3: wlp5s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 16:65:5c:68:b7:c9 brd ff:ff:ff:ff:ff:ff permaddr a8:7e:ea:c9:f4:69
Here’s the hardware:
eden@sunce:~ > inxi -N
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
Device-2: Intel Ethernet I225-V driver: igc
I tried with different versions of kernels, but the result is same:
5.4.72-1
5.8.16-2
5.9.1-1
If I switch to wlp5s0, stats are available. Any clues?
Thanks.
Fabby
November 1, 2020, 1:34pm
2
As you did not provide a full inxi --admin --verbosity=7 --filter --no-host --width
it’s hard to speculate, but if this is a home-built rig, did you install the UEFI drivers for that card ?
If not a home-built rig: did you upgrade your UEFI firmware yet?
edkirin
November 2, 2020, 12:16am
3
Fabby,
Motherboard manufacturer released new firmware few days ago, I updated it but the problem remains. It’s home-built rig without any additional UEFI drivers installed.
Here’s the full spec:
eden@sunce:~ > inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=8e54b3e5-faff-4f7f-bde6-1e055ed78e1c rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 1202 date: 10/21/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0082
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard PID:0066
status: Discharging
RAM: total: 31.34 GiB used: 12.30 GiB (39.2%)
Topology: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3072 KiB bogomips: 91071
Speed: 2794 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2662 2: 1863 3: 2195 4: 2193 5: 1863 6: 2197 7: 2191 8: 2193 9: 2676
10: 1924 11: 1863 12: 2196
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit
smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
driver: nvidia v: 455.28 alternate: nouveau,nvidia_drm bus ID: 07:00.0
chip ID: 10de:1c02
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 93 s-size: 1049x324mm (41.3x12.8")
s-diag: 1098mm (43.2")
Monitor-1: DVI-D-0 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 10de:10f1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 09:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.9.1-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 05:00.0
chip ID: 8086:2723
IF: wlp5s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus ID: 06:00.0 chip ID: 8086:15f3
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 881.81 GiB (42.0%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: S5Z42105 scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 6B0Q scheme: GPT
ID-3: /dev/sdb vendor: Western Digital model: WD10EAVS-00M4B0
size: 931.51 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 0A01 scheme: MBR
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 14.90 GiB (15.6%)
fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 8e54b3e5-faff-4f7f-bde6-1e055ed78e1c
ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: C031-0060
ID-3: /home raw size: 727.10 GiB size: 714.69 GiB (98.29%)
used: 273.22 GiB (38.2%) fs: ext4 dev: /dev/nvme0n1p5 label: N/A
uuid: 10dc0016-599b-449c-adfb-14d835c9c403
ID-4: /mnt/backup raw size: 238.47 GiB size: 233.73 GiB (98.01%)
used: 71.82 GiB (30.7%) fs: ext4 dev: /dev/sda1 label: backup
uuid: f95b73ab-80f5-4a8d-a622-37c2eb4fb5d9
ID-5: /mnt/wdpass raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 498.73 GiB (54.5%) fs: ext4 dev: /dev/sdb1 label: wdpass
uuid: 20375b64-27c4-4df8-ab73-71c9d3219fcd
ID-6: /run/timeshift/backup raw size: 238.47 GiB
size: <superuser/root required> used: <superuser/root required> fs: ext4
dev: /dev/sda1 label: backup uuid: f95b73ab-80f5-4a8d-a622-37c2eb4fb5d9
ID-7: /var raw size: 97.66 GiB size: 95.62 GiB (97.92%)
used: 23.10 GiB (24.2%) fs: ext4 dev: /dev/nvme0n1p4 label: N/A
uuid: 60ec20d1-e3fb-4233-8113-41ea8e9d439c
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.80 GiB used: 41.3 MiB (0.5%)
priority: -2 dev: /dev/nvme0n1p3 label: N/A
uuid: 5cb90f66-1abb-4bfd-aff6-3f2fd512a218
Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: <vendor specific>
chip ID: 0b05:1939 serial: <filter>
Hub: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0610
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-2:2 info: Logitech LX710 Cordless Desktop Laser
type: Keyboard,Mouse driver: logitech-djreceiver,usbhid interfaces: 2
rev: 1.1 speed: 1.5 Mb/s chip ID: 046d:c517
Device-2: 3-3:3 info: Corsair Vengeance K70R keyboard type: Keyboard,HID
driver: corsair,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 1b1c:1b09
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 45.9 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 359 Uptime: 1d 11h 02m Init: systemd v: 246 Compilers:
gcc: 10.2.0 clang: 10.0.1 Packages: 1464 pacman: 1460 lib: 377 flatpak: 4
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Fabby
November 2, 2020, 10:55am
4
I’m only on page 49 of the 2706 pages of the UEFI manual so I won’t be able to help you any further, except to point you to the Intel UEFI drivers already mentioned before and see if that helps.
(If the generic UEFI driver doesn’t expose statistics to the OS, you will have to install a specific one.)
If you want the full UEFI spec I’m reading as well, that’s here …
edkirin
November 2, 2020, 11:04am
5
Thanks for the help, Fabby. I need to check the whole story with UEFI drivers first, which is not quite my area.
xabbu
November 2, 2020, 11:28am
6
Just before you go to deep into the UEFI spec, which has probably nothing to do with your problem, read this
https://bugzilla.kernel.org/show_bug.cgi?id=208431
There is no solution. It looks more like a normal driver bug.
Interestingly, the ethtool
should show (some) statistics. Maybe you can try it.
edkirin
November 2, 2020, 10:43pm
8
Indeed, ethtool really shows interface stats:
eden@sunce:~ > ethtool -S enp6s0
NIC statistics:
rx_packets: 14558168
tx_packets: 14568229
rx_bytes: 12338911322
tx_bytes: 12914245311
rx_broadcast: 5480
tx_broadcast: 568
rx_multicast: 79984
tx_multicast: 3674
multicast: 79984
collisions: 0
Thanks.
system
Closed
November 17, 2020, 10:43pm
9
