Hi I’m quite new to Linux and Manjaro.
Could you please tell me: Is there a chance to fix this problem? Could it be a missing driver? Could it be the Kernel? I have no clue. In Alsamixer I tried everything, I think there could be a problem with a profile. In pulseaudio it says: Family 17h … speaker + headphones (as 1 profile, is that possible?)
And in configuration it says at HD Audio Generic (play hifi quality music (unplugged / not available))
No speakers out of laptop but headphones work
Card #0
Driver: module-alsa-card.c
Owner Module: 6
Properties:
alsa.card = "0"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xd04c8000 irq 100"
device.bus_path = "pci-0000:04:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "1002"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
device.product.id = "1637"
device.string = "0"
device.description = "HD-Audio Generic"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Profiles:
HiFi: Play HiFi quality Music (sinks: 2, sources: 0, priority: 8000, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
[Out] HDMI2: HDMI2 Output (type: HDMI, priority: 1200, latency offset: 0 usec, not available)
Part of profile(s): HiFi
[Out] HDMI1: HDMI1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, not available)
Card #1
Owner Module: 8
Properties:
alsa.card = "1"
alsa.long_card_name = "HD-Audio Generic at 0xd04c0000 irq 101"
device.bus_path = "pci-0000:04:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller"
device.string = "1"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller"
Profiles:
HiFi: Play HiFi quality Music (sinks: 1, sources: 2, priority: 8000, available: yes)
Active Profile: HiFi
Ports:
[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, not available)
[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, not available)
Here some more info:
██████████████████ ████████ markk@markk
██████████████████ ████████ OS: Manjaro 21.0.5 Ornara
██████████████████ ████████ Kernel: x86_64 Linux 5.10.36-2-MANJARO
██████████████████ ████████ Uptime: 21m
████████ ████████ Packages: 1061
████████ ████████ ████████ Shell: bash 5.1.8
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: Xfce4
████████ ████████ ████████ WM: Xfwm4
████████ ████████ ████████ WM Theme: Matcha-sea
████████ ████████ ████████ GTK Theme: Matcha-sea [GTK2]
████████ ████████ ████████ Icon Theme: Papirus-Maia
████████ ████████ ████████ Font: Noto Sans 10
████████ ████████ ████████ Disk: 6.9G / 476G (2%)
CPU: AMD Ryzen 5 5500U with Radeon Graphics @ 12x 2.1GHz
GPU: AMD RENOIR (DRM 3.40.0, 5.10.36-2-MANJARO, LLVM 11.1.0)
RAM: 1580MiB / 15418MiB
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "de_DE.utf8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82LM v: IdeaPad 5 14ALC05
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: G5CN16WW(V1.04) date: 02/03/2021
ID-1: BAT1 charge: 56.5 Wh (100.0%) condition: 56.5/56.5 Wh (100.0%)
volts: 13.0 min: 11.6 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31
0x39 0x43 0x33 0x50 0x5650
status: Full
Info: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP arch: Zen note: check rev: 1 cache: L2: 3 MiB
bogomips: 50325
Speed: 1397 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1389 3: 1397 4: 1395 5: 1397 6: 1396 7: 1397 8: 1397 9: 1397
10: 1397 11: 1398 12: 1397
Device-1: AMD vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati
unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.36-2-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 04:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: snd_rn_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-4:3
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 6.84 GiB (1.4%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN730 SDBPNTY-512G-1101 size: 476.94 GiB temp: 41.9 C
ID-1: / size: 468.09 GiB used: 6.84 GiB (1.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 44.6 C mobo: 44.0 C gpu: amdgpu temp: 41.0 C
Processes: 296 Uptime: 26m Memory: 15.06 GiB used: 1.51 GiB (10.1%)
Init: systemd Compilers: gcc: N/A Packages: 1061 Shell: Bash v: 5.1.8
inxi: 3.3.04
and:
pacmd list-sinks | grep -e 'name:' -e 'index:'
* index: 0
