"No space left on device" when there is 100gb left
#1
I can’t download or install anything from AUR anymore, it says there is no space left on device but that’s not true because my hdd still has 100gb left
:: Parsing SRCINFO (1/1): program
/usr/share/makepkg/util/parseopts.sh: line 119: cannot create temp file for here-document: No space left on device
makepkg: option '--' is ambiguous; possibilities: 'allsource' 'check' 'clean' 'cleanbuild' 'config' 'force' 'geninteg' 'help' 'holdver' 'ignorearch' 'install' 'key' 'log' 'noarchive' 'nobuild' 'nocolor' 'nocheck' 'nodeps' 'noextract' 'noprepare' 'nosign' 'packagelist' 'printsrcinfo' 'repackage' 'rmdeps' 'sign' 'skipchecksums' 'skipinteg' 'skippgpcheck' 'source' 'syncdeps' 'verifysource' 'version' 'asdeps' 'noconfirm' 'needed' 'noprogressbar'
Error downloading sources: program
#2
Possible cause:
By default, makepkg runs in tmpfs (/tmp) which is in RAM.
Change BUILDDIR in /etc/makepkg.conf to a directory residing on your HDD/SSD.
However, please tell us which package you build and which tools you use to build it.
#3
I tried installing anaconda and gnu-icecat, both same issue.
I think you are right, but I have 8b of ram. How can building these packages consume so much ram?
#4
There’s no gnu-icecat in AUR.
As for icecat, that is quite normal, it’s Firefox after all, it’s a huge project and compilation needs tons of RAM and lots of time.
#5
same issue:
:: Parsing SRCINFO (1/1): anaconda
Error downloading sources: anaconda
Do I maybe need to refresh something?
#6
What tool are you using to build?
#7
I just tried yay, but package manager also gives a similar feedback
curl: (23) Failed writing body (838 != 16366)
==> ERROR: Failure while downloading http://repo.continuum.io/archive/Anaconda3-2018.12-Linux-x86_64.sh
    Aborting...
#8
The download works here with yay.
Seems like something is messed up…
Is your system fully up to date?
Line 119 here says: IFS='=' read -r opt optarg <<< "${1#--}"
And just to make sure, please show output of df -h
Oh, very important: did you uncomment (i.e. remove the hash) the line with BUILDDIR in /etc/makepkg.conf?
#9
Yes
here it says:
df -h
Filesystem      Size  Used Avail Use% Mounted on
dev             3,9G     0  3,9G   0% /dev
run             3,9G  1,4M  3,9G   1% /run
/dev/dm-0       284G  152G  119G  57% /
tmpfs           3,9G   25M  3,9G   1% /dev/shm
tmpfs           3,9G     0  3,9G   0% /sys/fs/cgroup
tmpfs           3,9G  3,9G  4,0K 100% /tmp
tmpfs           786M   32K  786M   1% /run/user/1000
/dev/dm-2       459G  355G   81G  82% /run/media/tp/dump
Yes
#10
Your tmpfs on /tmp is full, that’s the problem.
Rebooting cleans it up.
#11
How do I fix it? and why did it get full ?
#12
Because you’re trying to build two huge packages. They don’t fit into 4 GB.
That’s what BUILDDIR is for, it allows you to choose a different build directory.
#13
alright so how do I empty it? and do I still use the new BUILDDIR directory without RAM?
#14
Reboot.
Simply set BUILDDIR to something like /home/username/builddir or any other directory that is located on the HDD.
Make sure the directory exists, if not create it.
#15
alright thank you, rebooting now
#16
I commented the builddir out again though, so it was probably on RAM
Preparing...
Cloning anaconda build files...
Checking anaconda dependencies...
Building anaconda...
==> Making package: anaconda 2018.12-1 (ma 11 feb 2019 17:45:17 CET)
==> Retrieving sources...
  -> Downloading Anaconda3-2018.12-Linux-x86_64.sh...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
  0  652M    0  750k    0     0   425k      0  0:26:10  0:00:01  0:26:09  814k
  0  652M    0 1630k    0     0   588k      0  0:18:55  0:00:02  0:18:53  845k
  0  652M    0 2526k    0     0   671k      0  0:16:35  0:00:03  0:16:32  864k
  0  652M    0 3326k    0     0   698k      0  0:15:56  0:00:04  0:15:52  848k
  0  652M    0 4014k    0     0   696k      0  0:15:59  0:00:05  0:15:54  815k
  0  652M    0 4526k    0     0   661k      0  0:16:50  0:00:06  0:16:44  743k
  0  652M    0 5246k    0     0   675k      0  0:16:28  0:00:07  0:16:21  723k
  0  652M    0 5950k    0     0   678k      0  0:16:24  0:00:08  0:16:16  684k
  1  652M    1 6766k    0     0   692k      0  0:16:04  0:00:09  0:15:55  687k
  1  652M    1 7422k    0     0   689k      0  0:16:09  0:00:10  0:15:59  681k
  1  652M    1 8046k    0     0   679k      0  0:16:23  0:00:11  0:16:12  703k
  1  652M    1 8766k    0     0   686k      0  0:16:13  0:00:12  0:16:01  704k
  1  652M    1 9614k    0     0   698k      0  0:15:56  0:00:13  0:15:43  732k
  1  652M    1 10.2M    0     0   709k      0  0:15:41  0:00:14  0:15:27  742k
  1  652M    1 11.0M    0     0   716k      0  0:15:32  0:00:15  0:15:17  775k
  1  652M    1 11.8M    0     0   726k      0  0:15:20  0:00:16  0:15:04  839k
  1  652M    1 12.7M    0     0   735k      0  0:15:08  0:00:17  0:14:51  860k
  2  652M    2 13.6M    0     0   744k      0  0:14:57  0:00:18  0:14:39  870k
  2  652M    2 14.0M    0     0   723k      0  0:15:24  0:00:19  0:15:05  762k
  2  652M    2 14.4M    0     0   714k      0  0:15:35  0:00:20  0:15:15  705k
  2  652M    2 14.9M    0     0   701k      0  0:15:51  0:00:21  0:15:30  620k
  2  652M    2 15.8M    0     0   713k      0  0:15:36  0:00:22  0:15:14  633k
  2  652M    2 16.5M    0     0   711k      0  0:15:39  0:00:23  0:15:16  588k
  2  652M    2 17.1M    0     0   707k      0  0:15:44  0:00:24  0:15:20  643k
  2  652M    2 17.8M    0     0   709k      0  0:15:41  0:00:25  0:15:16  691k
  2  652M    2 18.7M    0     0   716k      0  0:15:32  0:00:26  0:15:06  780k
  3  652M    3 19.6M    0     0   723k      0  0:15:23  0:00:27  0:14:56  771k
  3  652M    3 20.4M    0     0   728k      0  0:15:17  0:00:28  0:14:49  808k
  3  652M    3 21.3M    0     0   733k      0  0:15:10  0:00:29  0:14:41  864k
  3  652M    3 22.1M    0     0   737k      0  0:15:06  0:00:30  0:14:36  877k
  3  652M    3 23.0M    0     0   742k      0  0:14:59  0:00:31  0:14:28  883k
  3  652M    3 23.8M    0     0   746k      0  0:14:54  0:00:32  0:14:22  873k
  3  652M    3 24.7M    0     0   748k      0  0:14:52  0:00:33  0:14:19  868k
  3  652M    3 25.5M    0     0   753k      0  0:14:47  0:00:34  0:14:13  869k
  4  652M    4 26.4M    0     0   757k      0  0:14:42  0:00:35  0:14:07  882k
  4  652M    4 27.0M    0     0   754k      0  0:14:45  0:00:36  0:14:09  828k
  4  652M    4 27.9M    0     0   758k      0  0:14:40  0:00:37  0:14:03  838k
  4  652M    4 28.8M    0     0   761k      0  0:14:37  0:00:38  0:13:59  849k
  4  652M    4 29.7M    0     0   764k      0  0:14:33  0:00:39  0:13:54  846k
  4  652M    4 30.5M    0     0   768k      0  0:14:29  0:00:40  0:13:49  847k
  4  652M    4 31.4M    0     0   771k      0  0:14:26  0:00:41  0:13:45  892k
  4  652M    4 32.0M    0     0   766k      0  0:14:31  0:00:42  0:13:49  828k
  5  652M    5 33.1M    0     0   775k      0  0:14:21  0:00:43  0:13:38  880k
  5  652M    5 34.1M    0     0   780k      0  0:14:15  0:00:44  0:13:31  905k
  5  652M    5 35.0M    0     0   784k      0  0:14:11  0:00:45  0:13:26  918k
  5  652M    5 36.1M    0     0   791k      0  0:14:04  0:00:46  0:13:18  963k
  5  652M    5 37.0M    0     0   794k      0  0:14:01  0:00:47  0:13:14 1027k
  5  652M    5 38.2M    0     0   803k      0  0:13:51  0:00:48  0:13:03 1049k
  6  652M    6 39.3M    0     0   810k      0  0:13:44  0:00:49  0:12:55 1079k
  6  652M    6 40.3M    0     0   813k      0  0:13:41  0:00:50  0:12:51 1071k
  6  652M    6 41.2M    0     0   815k      0  0:13:39  0:00:51  0:12:48 1036k
  6  652M    6 42.1M    0     0   817k      0  0:13:37  0:00:52  0:12:45 1036k
  6  652M    6 42.9M    0     0   817k      0  0:13:36  0:00:53  0:12:43  958k
  6  652M    6 43.8M    0     0   819k      0  0:13:35  0:00:54  0:12:41  908k
  6  652M    6 44.6M    0     0   820k      0  0:13:34  0:00:55  0:12:39  896k
  6  652M    6 45.6M    0     0   822k      0  0:13:32  0:00:56  0:12:36  899k
  7  652M    7 46.5M    0     0   824k      0  0:13:30  0:00:57  0:12:33  902k
  7  652M    7 47.4M    0     0   826k      0  0:13:28  0:00:58  0:12:30  913k
  7  652M    7 48.2M    0     0   825k      0  0:13:29  0:00:59  0:12:30  892k
  7  652M    7 49.1M    0     0   828k      0  0:13:26  0:01:00  0:12:26  912k
  7  652M    7 50.0M    0     0   829k      0  0:13:25  0:01:01  0:12:24  905k
  7  652M    7 50.9M    0     0   830k      0  0:13:24  0:01:02  0:12:22  903k
  7  652M    7 51.3M    0     0   825k      0  0:13:29  0:01:03  0:12:26  815k
  7  652M    7 51.6M    0     0   816k      0  0:13:38  0:01:04  0:12:34  709k
  7  652M    7 52.0M    0     0   809k      0  0:13:45  0:01:05  0:12:40  588k
  8  652M    8 52.3M    0     0   803k      0  0:13:51  0:01:06  0:12:45  479k
  8  652M    8 52.9M    0     0   799k      0  0:13:55  0:01:07  0:12:48  404k
  8  652M    8 53.6M    0     0   798k      0  0:13:56  0:01:08  0:12:48  461k
  8  652M    8 54.4M    0     0   798k      0  0:13:56  0:01:09  0:12:47  563k
  8  652M    8 54.9M    0     0   795k      0  0:13:59  0:01:10  0:12:49  611k
  8  652M    8 55.8M    0     0   796k      0  0:13:58  0:01:11  0:12:47  708k
  8  652M    8 56.7M    0     0   798k      0  0:13:57  0:01:12  0:12:45  780k
  8  652M    8 57.5M    0     0   799k      0  0:13:56  0:01:13  0:12:43  806k
  8  652M    8 58.4M    0     0   800k      0  0:13:55  0:01:14  0:12:41  822k
  9  652M    9 59.2M    0     0   801k      0  0:13:54  0:01:15  0:12:39  876k
  9  652M    9 60.1M    0     0   802k      0  0:13:53  0:01:16  0:12:37  879k
  9  652M    9 61.0M    0     0   803k      0  0:13:51  0:01:17  0:12:34  883k
  9  652M    9 61.8M    0     0   804k      0  0:13:50  0:01:18  0:12:32  882k
  9  652M    9 62.7M    0     0   805k      0  0:13:49  0:01:19  0:12:30  886k
  9  652M    9 63.5M    0     0   806k      0  0:13:48  0:01:20  0:12:28  879k
  9  652M    9 64.4M    0     0   807k      0  0:13:47  0:01:21  0:12:26  886k
  9  652M    9 65.2M    0     0   806k      0  0:13:48  0:01:22  0:12:26  854k
 10  652M   10 65.9M    0     0   805k      0  0:13:49  0:01:23  0:12:26  825k
 10  652M   10 66.7M    0     0   805k      0  0:13:49  0:01:24  0:12:25  812k
 10  652M   10 67.4M    0     0   805k      0  0:13:49  0:01:25  0:12:24  803k
 10  652M   10 68.3M    0     0   806k      0  0:13:48  0:01:26  0:12:22  793k
 10  652M   10 69.1M    0     0   806k      0  0:13:48  0:01:27  0:12:21  803k
 10  652M   10 69.9M    0     0   807k      0  0:13:47  0:01:28  0:12:19  829k
 10  652M   10 70.8M    0     0   807k      0  0:13:47  0:01:29  0:12:18  838k
 10  652M   10 71.6M    0     0   808k      0  0:13:46  0:01:30  0:12:16  844k
 11  652M   11 72.2M    0     0   806k      0  0:13:48  0:01:31  0:12:17  810k
 11  652M   11 73.0M    0     0   805k      0  0:13:49  0:01:32  0:12:17  796k
 11  652M   11 73.9M    0     0   807k      0  0:13:47  0:01:33  0:12:14  806k
 11  652M   11 74.8M    0     0   808k      0  0:13:46  0:01:34  0:12:12  819k
 11  652M   11 75.8M    0     0   810k      0  0:13:44  0:01:35  0:12:09  857k
 11  652M   11 76.9M    0     0   814k      0  0:13:40  0:01:36  0:12:04  953k
 11  652M   11 77.9M    0     0   816k      0  0:13:37  0:01:37  0:12:00 1020k
 12  652M   12 79.1M    0     0   820k      0  0:13:34  0:01:38  0:11:56 1075k
 12  652M   12 80.2M    0     0   823k      0  0:13:31  0:01:39  0:11:52 1104k
 12  652M   12 81.2M    0     0   824k      0  0:13:30  0:01:40  0:11:50 1096k
 12  652M   12 82.0M    0     0   825k      0  0:13:29  0:01:41  0:11:48 1052k
 12  652M   12 83.1M    0     0   828k      0  0:13:26  0:01:42  0:11:44 1059k
 12  652M   12 84.3M    0     0   832k      0  0:13:22  0:01:43  0:11:39 1059k
 13  652M   13 85.3M    0     0   833k      0  0:13:21  0:01:44  0:11:37 1046k
 13  652M   13 86.4M    0     0   837k      0  0:13:18  0:01:45  0:11:33 1085k
 13  652M   13 87.6M    0     0   840k      0  0:13:15  0:01:46  0:11:29 1132k
 13  652M   13 88.7M    0     0   843k      0  0:13:12  0:01:47  0:11:25 1139k
 13  652M   13 89.7M    0     0   844k      0  0:13:11  0:01:48  0:11:23 1100k
 13  652M   13 90.8M    0     0   847k      0  0:13:08  0:01:49  0:11:19 1136k
 14  652M   14 91.6M    0     0   847k      0  0:13:08  0:01:50  0:11:18 1065k
 14  652M   14 92.8M    0     0   850k      0  0:13:05  0:01:51  0:11:14 1069k
 14  652M   14 93.9M    0     0   853k      0  0:13:02  0:01:52  0:11:10 1075k
 14  652M   14 95.1M    0     0   856k      0  0:13:00  0:01:53  0:11:07 1110k
 14  652M   14 96.2M    0     0   858k      0  0:12:57  0:01:54  0:11:03 1107k
 14  652M   14 97.4M    0     0   861k      0  0:12:55  0:01:55  0:11:00 1177k
 15  652M   15 98.5M    0     0   864k      0  0:12:53  0:01:56  0:10:57 1171k
 15  652M   15 99.6M    0     0   866k      0  0:12:51  0:01:57  0:10:54 1164k
 15  652M   15  100M    0     0   869k      0  0:12:48  0:01:58  0:10:50 1161k
 15  652M   15  101M    0     0   871k      0  0:12:46  0:01:59  0:10:47 1155k
 15  652M   15  102M    0     0   871k      0  0:12:46  0:02:00  0:10:46 1094k
 15  652M   15  103M    0     0   874k      0  0:12:44  0:02:01  0:10:43 1103k
 16  652M   16  105M    0     0   876k      0  0:12:42  0:02:02  0:10:40 1107k
 16  652M   16  106M    0     0   878k      0  0:12:40  0:02:03  0:10:37 1103k
 16  652M   16  107M    0     0   881k      0  0:12:38  0:02:04  0:10:34 1113k
 16  652M   16  108M    0     0   883k      0  0:12:36  0:02:05  0:10:31 1175k
 16  652M   16  109M    0     0   885k      0  0:12:34  0:02:06  0:10:28 1168k
 16  652M   16  110M    0     0   887k      0  0:12:32  0:02:07  0:10:25 1171k
 17  652M   17  111M    0     0   890k      0  0:12:30  0:02:08  0:10:22 1172k
 17  652M   17  112M    0     0   890k      0  0:12:30  0:02:09  0:10:21 1129k
 17  652M   17  113M    0     0   892k      0  0:12:28  0:02:10  0:10:18 1123k
 17  652M   17  115M    0     0   894k      0  0:12:26  0:02:11  0:10:15 1126k
 17  652M   17  116M    0     0   896k      0  0:12:25  0:02:12  0:10:13 1123k
 17  652M   17  117M    0     0   896k      0  0:12:25  0:02:13  0:10:12 1073k
 18  652M   18  118M    0     0   898k      0  0:12:23  0:02:14  0:10:09 1094k
 18  652M   18  119M    0     0   899k      0  0:12:22  0:02:15  0:10:07 1088k
 18  652M   18  120M    0     0   901k      0  0:12:20  0:02:16  0:10:04 1088k
 18  652M   18  121M    0     0   903k      0  0:12:19  0:02:17  0:10:02 1084k
 18  652M   18  122M    0     0   905k      0  0:12:17  0:02:18  0:09:59 1142k
 18  652M   18  123M    0     0   907k      0  0:12:16  0:02:19  0:09:57 1161k
 19  652M   19  125M    0     0   909k      0  0:12:14  0:02:20  0:09:54 1174k
 19  652M   19  126M    0     0   911k      0  0:12:13  0:02:21  0:09:52 1167k
 19  652M   19  127M    0     0   913k      0  0:12:11  0:02:22  0:09:49 1171k
 19  652M   19  128M    0     0   911k      0  0:12:13  0:02:23  0:09:50 1074k
 19  652M   19  128M    0     0   910k      0  0:12:13  0:02:24  0:09:49  988k
 19  652M   19  129M    0     0   910k      0  0:12:14  0:02:25  0:09:49  928k
 19  652M   19  130M    0     0   909k      0  0:12:14  0:02:26  0:09:48  870k
 20  652M   20  131M    0     0   909k      0  0:12:14  0:02:27  0:09:47  802k
 20  652M   20  132M    0     0   908k      0  0:12:15  0:02:28  0:09:47  827k
 20  652M   20  132M    0     0   907k      0  0:12:16  0:02:29  0:09:47  822k
 20  652M   20  133M    0     0   906k      0  0:12:16  0:02:30  0:09:46  812k
 20  652M   20  134M    0     0   906k      0  0:12:17  0:02:31  0:09:46  803k
 20  652M   20  135M    0     0   905k      0  0:12:17  0:02:32  0:09:45  804k
 20  652M   20  135M    0     0   903k      0  0:12:19  0:02:33  0:09:46  735k
 20  652M   20  136M    0     0   902k      0  0:12:20  0:02:34  0:09:46  761k
 21  652M   21  137M    0     0   902k      0  0:12:20  0:02:35  0:09:45  764k
 21  652M   21  138M    0     0   901k      0  0:12:20  0:02:36  0:09:44  767k
 21  652M   21  138M    0     0   900k      0  0:12:21  0:02:37  0:09:44  744k
 21  652M   21  139M    0     0   899k      0  0:12:22  0:02:38  0:09:44  795k
 21  652M   21  140M    0     0   899k      0  0:12:22  0:02:39  0:09:43  803k
 21  652M   21  141M    0     0   899k      0  0:12:23  0:02:40  0:09:43  800k
 21  652M   21  141M    0     0   898k      0  0:12:23  0:02:41  0:09:42  800k
 21  652M   21  142M    0     0   897k      0  0:12:24  0:02:42  0:09:42  795k
 21  652M   21  143M    0     0   894k      0  0:12:26  0:02:43  0:09:43  726k
 21  652M   21  143M    0     0   891k      0  0:12:29  0:02:44  0:09:45  620k
 22  652M   22  143M    0     0   888k      0  0:12:32  0:02:45  0:09:47  536k
 22  652M   22  144M    0     0   885k      0  0:12:34  0:02:46  0:09:48  467k
 22  652M   22  144M    0     0   883k      0  0:12:36  0:02:47  0:09:49  435k
 22  652M   22  145M    0     0   880k      0  0:12:38  0:02:48  0:09:50  428k
 22  652M   22  145M    0     0   879k      0  0:12:39  0:02:49  0:09:50  502k
 22  652M   22  146M    0     0   877k      0  0:12:41  0:02:50  0:09:51  532k
 22  652M   22  146M    0     0   875k      0  0:12:43  0:02:51  0:09:52  528k
 22  652M   22  147M    0     0   874k      0  0:12:44  0:02:52  0:09:52  550k
 22  652M   22  148M    0     0   873k      0  0:12:44  0:02:53  0:09:51  637k
 22  652M   22  149M    0     0   873k      0  0:12:45  0:02:54  0:09:51  649k
 22  652M   22  149M    0     0   873k      0  0:12:45  0:02:55  0:09:50  716k
 23  652M   23  150M    0     0   873k      0  0:12:45  0:02:56  0:09:49  810k
 23  652M   23  151M    0     0   873k      0  0:12:44  0:02:57  0:09:47  857k
 23  652M   23  152M    0     0   872k      0  0:12:45  0:02:58  0:09:47  828k
 23  652M   23  153M    0     0   873k      0  0:12:44  0:02:59  0:09:45  892k
 23  652M   23  153M    0     0   872k      0  0:12:46  0:03:00  0:09:46  832k
 23  652M   23  154M    0     0   869k      0  0:12:48  0:03:01  0:09:47  735k
 23  652M   23  154M    0     0   867k      0  0:12:50  0:03:02  0:09:48  634k
 23  652M   23  155M    0     0   866k      0  0:12:51  0:03:03  0:09:48  639k
 23  652M   23  156M    0     0   864k      0  0:12:53  0:03:04  0:09:49  536k
 24  652M   24  156M    0     0   863k      0  0:12:53  0:03:05  0:09:48  547k
 24  652M   24  157M    0     0   863k      0  0:12:53  0:03:06  0:09:47  645k
 24  652M   24  157M    0     0   861k      0  0:12:55  0:03:07  0:09:48  651k
 24  652M   24  158M    0     0   861k      0  0:12:55  0:03:08  0:09:47  688k
 24  652M   24  159M    0     0   859k      0  0:12:57  0:03:09  0:09:48  686k
 24  652M   24  160M    0     0   859k      0  0:12:57  0:03:10  0:09:47  727k
 24  652M   24  161M    0     0   860k      0  0:12:56  0:03:11  0:09:45  729k
 24  652M   24  161M    0     0   859k      0  0:12:57  0:03:12  0:09:45  795k
 24  652M   24  162M    0     0   860k      0  0:12:56  0:03:13  0:09:43  812k
 25  652M   25  163M    0     0   857k      0  0:12:58  0:03:14  0:09:44  792k
 25  652M   25  163M    0     0   856k      0  0:13:00  0:03:15  0:09:45  717k
 25  652M   25  164M    0     0   853k      0  0:13:02  0:03:16  0:09:46  602k
 25  652M   25  164M    0     0   851k      0  0:13:04  0:03:17  0:09:47  542k
 25  652M   25  165M    0     0   850k      0  0:13:05  0:03:18  0:09:47  486k
 25  652M   25  165M    0     0   850k      0  0:13:05  0:03:19  0:09:46  560k
 25  652M   25  166M    0     0   850k      0  0:13:05  0:03:20  0:09:45  640k
 25  652M   25  167M    0     0   850k      0  0:13:06  0:03:21  0:09:45  714k
 25  652M   25  168M    0     0   850k      0  0:13:06  0:03:22  0:09:44  790k
 25  652M   25  169M    0     0   849k      0  0:13:06  0:03:23  0:09:43  815k
 26  652M   26  170M    0     0   850k      0  0:13:05  0:03:24  0:09:41  834k
 26  652M   26  170M    0     0   850k      0  0:13:05  0:03:25  0:09:40  825k
 26  652M   26  171M    0     0   848k      0  0:13:07  0:03:26  0:09:41  796k
 26  652M   26  171M    0     0   846k      0  0:13:08  0:03:27  0:09:41  720k
 26  652M   26  172M    0     0   845k      0  0:13:10  0:03:28  0:09:42  669k
 26  652M   26  172M    0     0   843k      0  0:13:12  0:03:29  0:09:43  549k
 26  652M   26  173M    0     0   841k      0  0:13:13  0:03:30  0:09:43  496k
 26  652M   26  173M    0     0   839k      0  0:13:16  0:03:31  0:09:45  451k
 26  652M   26  174M    0     0   838k      0  0:13:17  0:03:32  0:09:45  465k
 26  652M   26  174M    0     0   837k      0  0:13:17  0:03:33  0:09:44  513k
 26  652M   26  175M    0     0   837k      0  0:13:18  0:03:34  0:09:44  593k
 26  652M   26  176M    0     0   835k      0  0:13:19  0:03:35  0:09:44  561k
 27  652M   27  176M    0     0   834k      0  0:13:20  0:03:36  0:09:44  643k
 27  652M   27  177M    0     0   834k      0  0:13:20  0:03:37  0:09:43  675k
 27  652M   27  178M    0     0   833k      0  0:13:21  0:03:38  0:09:43  641k
 27  652M   27  178M    0     0   831k      0  0:13:23  0:03:39  0:09:44  590k
 27  652M   27  178M    0     0   829k      0  0:13:25  0:03:40  0:09:45  577k
 27  652M   27  179M    0     0   828k      0  0:13:26  0:03:41  0:09:45  547k
 27  652M   27  180M    0     0   828k      0  0:13:26  0:03:42  0:09:44  563k
 27  652M   27  180M    0     0   827k      0  0:13:27  0:03:43  0:09:44  564k
 27  652M   27  181M    0     0   827k      0  0:13:27  0:03:44  0:09:43  636k
 27  652M   27  182M    0     0   826k      0  0:13:28  0:03:45  0:09:43  689k
 27  652M   27  182M    0     0   824k      0  0:13:30  0:03:46  0:09:44  630k
 28  652M   28  183M    0     0   823k      0  0:13:31  0:03:47  0:09:44  601k
 28  652M   28  183M    0     0   823k      0  0:13:31  0:03:48  0:09:43  643k
 28  652M   28  184M    0     0   823k      0  0:13:31  0:03:49  0:09:42  636k
 28  652M   28  185M    0     0   823k      0  0:13:31  0:03:50  0:09:41  699k
 28  652M   28  186M    0     0   823k      0  0:13:31  0:03:51  0:09:40  785k
 28  652M   28  186M    0     0   821k      0  0:13:33  0:03:52  0:09:41  745k
 28  652M   28  187M    0     0   820k      0  0:13:34  0:03:53  0:09:41  693k
 28  652M   28  188M    0     0   820k      0  0:13:34  0:03:54  0:09:40  687k
 28  652M   28  188M    0     0   820k      0  0:13:34  0:03:55  0:09:39  668k
 29  652M   29  189M    0     0   820k      0  0:13:34  0:03:56  0:09:38  697k
 29  652M   29  190M    0     0   819k      0  0:13:35  0:03:57  0:09:38  729k
 29  652M   29  191M    0     0   820k      0  0:13:34  0:03:58  0:09:36  799k
 29  652M   29  191M    0     0   819k      0  0:13:35  0:03:59  0:09:36  765k
 29  652M   29  192M    0     0   818k      0  0:13:36  0:04:00  0:09:36  727k
 29  652M   29  192M    0     0   817k      0  0:13:37  0:04:01  0:09:36  652k
 29  652M   29  193M    0     0   817k      0  0:13:37  0:04:02  0:09:35  704k
 29  652M   29  194M    0     0   816k      0  0:13:38  0:04:03  0:09:35  636k
 29  652M   29  194M    0     0   814k      0  0:13:39  0:04:04  0:09:35  614k
 29  652M   29  195M    0     0   814k      0  0:13:39  0:04:05  0:09:34  647k
 30  652M   30  196M    0     0   813k      0  0:13:41  0:04:06  0:09:35  652k
 30  652M   30  196M    0     0   813k      0  0:13:41  0:04:07  0:09:34  646k
 30  652M   30  197M    0     0   813k      0  0:13:41  0:04:08  0:09:33  665k
 30  652M   30  198M    0     0   813k      0  0:13:41  0:04:09  0:09:32  750k
 30  652M   30  199M    0     0   813k      0  0:13:41  0:04:10  0:09:31  751k
 30  652M   30  200M    0     0   813k      0  0:13:41  0:04:11  0:09:30  803k
 30  652M   30  200M    0     0   813k      0  0:13:40  0:04:12  0:09:28  822k
 30  652M   30  201M    0     0   812k      0  0:13:42  0:04:13  0:09:29  762k
 30  652M   30  201M    0     0   811k      0  0:13:43  0:04:14  0:09:29  687k
 31  652M   31  202M    0     0   810k      0  0:13:43  0:04:15  0:09:28  674k
 31  652M   31  203M    0     0   810k      0  0:13:44  0:04:16  0:09:28  642k
 31  652M   31  203M    0     0   809k      0  0:13:45  0:04:17  0:09:28  563k
 31  652M   31  204M    0     0   807k      0  0:13:47  0:04:18  0:09:29  589k
 31  652M   31  204M    0     0   807k      0  0:13:47  0:04:19  0:09:28  640k
 31  652M   31  205M    0     0   807k      0  0:13:47  0:04:20  0:09:27  650k
 31  652M   31  206M    0     0   806k      0  0:13:48  0:04:21  0:09:27  633k
 31  652M   31  206M    0     0   806k      0  0:13:48  0:04:22  0:09:26  652k
 31  652M   31  207M    0     0   806k      0  0:13:48  0:04:23  0:09:25  711k
 31  652M   31  208M    0     0   805k      0  0:13:49  0:04:24  0:09:25  680k
 32  652M   32  208M    0     0   804k      0  0:13:50  0:04:25  0:09:25  636k
 32  652M   32  209M    0     0   804k      0  0:13:50  0:04:26  0:09:24  691k
 32  652M   32  210M    0     0   804k      0  0:13:50  0:04:27  0:09:23  745k
 32  652M   32  211M    0     0   805k      0  0:13:49  0:04:28  0:09:21  757k
 32  652M   32  211M    0     0   804k      0  0:13:50  0:04:29  0:09:21  734k
 32  652M   32  212M    0     0   804k      0  0:13:50  0:04:30  0:09:20  805k
 32  652M   32  213M    0     0   804k      0  0:13:50  0:04:31  0:09:19  822k
 32  652M   32  214M    0     0   804k      0  0:13:50  0:04:32  0:09:18  800k
 32  652M   32  215M    0     0   804k      0  0:13:50  0:04:33  0:09:17  772k
 33  652M   33  215M    0     0   804k      0  0:13:50  0:04:34  0:09:16  806k
 33  652M   33  216M    0     0   804k      0  0:13:50  0:04:35  0:09:15  793k
 33  652M   33  217M    0     0   804k      0  0:13:50  0:04:36  0:09:14  796k
 33  652M   33  218M    0     0   804k      0  0:13:50  0:04:37  0:09:13  790k
 33  652M   33  218M    0     0   804k      0  0:13:51  0:04:38  0:09:13  768k
 33  652M   33  219M    0     0   804k      0  0:13:50  0:04:39  0:09:11  809k
 33  652M   33  220M    0     0   804k      0  0:13:50  0:04:40  0:09:10  815k
 33  652M   33  221M    0     0   804k      0  0:13:50  0:04:41  0:09:09  812k
 34  652M   34  222M    0     0   804k      0  0:13:50  0:04:42  0:09:08  803k
 34  652M   34  222M    0     0   803k      0  0:13:51  0:04:43  0:09:08  771k
 34  652M   34  223M    0     0   803k      0  0:13:51  0:04:44  0:09:07  739k
 34  652M   34  224M    0     0   803k      0  0:13:51  0:04:45  0:09:06  742k
 34  652M   34  225M    0     0   803k      0  0:13:51  0:04:46  0:09:05  736k
 34  652M   34  225M    0     0   804k      0  0:13:50  0:04:47  0:09:03  777k
 34  652M   34  226M    0     0   804k      0  0:13:50  0:04:48  0:09:02  873k
 34  652M   34  227M    0     0   805k      0  0:13:49  0:04:49  0:09:00  911k
 35  652M   35  228M    0     0   805k      0  0:13:49  0:04:50  0:08:59  912k
 35  652M   35  229M    0     0   805k      0  0:13:49  0:04:51  0:08:58  918k
 35  652M   35  230M    0     0   806k      0  0:13:48  0:04:52  0:08:56  921k
 35  652M   35  231M    0     0   806k      0  0:13:48  0:04:53  0:08:55  904k
 35  652M   35  232M    0     0   806k      0  0:13:48  0:04:54  0:08:54  899k
 35  652M   35  233M    0     0   806k      0  0:13:48  0:04:55  0:08:53  883k
 35  652M   35  233M    0     0   807k      0  0:13:47  0:04:56  0:08:51  886k
 35  652M   35  234M    0     0   807k      0  0:13:47  0:04:57  0:08:50  883k
 36  652M   36  235M    0     0   807k      0  0:13:47  0:04:58  0:08:49  864k
 36  652M   36  236M    0     0   808k      0  0:13:46  0:04:59  0:08:47  918k
 36  652M   36  237M    0     0   809k      0  0:13:45  0:05:00  0:08:45  982k
 36  652M   36  238M    0     0   810k      0  0:13:44  0:05:01  0:08:43 1033k
 36  652M   36  240M    0     0   812k      0  0:13:42  0:05:02  0:08:40 1088k
 36  652M   36  241M    0     0   812k      0  0:13:42  0:05:03  0:08:39 1142k
 37  652M   37  242M    0     0   813k      0  0:13:40  0:05:04  0:08:36 1138k
 37  652M   37  242M    0     0   813k      0  0:13:41  0:05:05  0:08:36 1056k
 37  652M   37  244M    0     0   814k      0  0:13:40  0:05:06  0:08:34 1056k
 37  652M   37  245M    0     0   815k      0  0:13:38  0:05:07  0:08:31 1049k
 37  652M   37  246M    0     0   816k      0  0:13:37  0:05:08  0:08:29 1068k
 37  652M   37  247M    0     0   818k      0  0:13:36  0:05:09  0:08:27 1072k
 38  652M   38  248M    0     0   819k      0  0:13:35  0:05:10  0:08:25 1156k
 38  652M   38  249M    0     0   820k      0  0:13:34  0:05:11  0:08:23 1155k
 38  652M   38  250M    0     0   820k      0  0:13:34  0:05:12  0:08:22 1115k
 38  652M   38  251M    0     0   821k      0  0:13:33  0:05:13  0:08:20 1072k
 38  652M   38  252M    0     0   821k      0  0:13:33  0:05:14  0:08:19 1056k
 38  652M   38  253M    0     0   823k      0  0:13:31  0:05:15  0:08:16 1060k
 39  652M   39  254M    0     0   824k      0  0:13:30  0:05:16  0:08:14 1059k
 39  652M   39  256M    0     0   825k      0  0:13:29  0:05:17  0:08:12 1098k
 39  652M   39  257M    0     0   826k      0  0:13:28  0:05:18  0:08:10 1145k
 39  652M   39  258M    0     0   826k      0  0:13:28  0:05:19  0:08:09 1144k
 39  652M   39  259M    0     0   828k      0  0:13:26  0:05:20  0:08:06 1145k
 39  652M   39  260M    0     0   827k      0  0:13:27  0:05:21  0:08:06 1066k
 40  652M   40  261M    0     0   828k      0  0:13:26  0:05:22  0:08:04 1047k
 40  652M   40  262M    0     0   829k      0  0:13:25  0:05:23  0:08:02 1056k
 40  652M   40  263M    0     0   830k      0  0:13:24  0:05:24  0:08:00 1046k
 40  652M   40  264M    0     0   831k      0  0:13:23  0:05:25  0:07:58 1043k
 40  652M   40  265M    0     0   832k      0  0:13:22  0:05:26  0:07:56 1125k
 40  652M   40  266M    0     0   833k      0  0:13:21  0:05:27  0:07:54 1144k
 41  652M   41  267M    0     0   834k      0  0:13:20  0:05:28  0:07:52 1139k
 41  652M   41  268M    0     0   835k      0  0:13:19  0:05:29  0:07:50 1158k
 41  652M   41  270M    0     0   836k      0  0:13:18  0:05:30  0:07:48 1161k
 41  652M   41  271M    0     0   836k      0  0:13:18  0:05:31  0:07:47 1136k
 41  652M   41  272M    0     0   837k      0  0:13:17  0:05:32  0:07:45 1136k
 41  652M   41  273M    0     0   838k      0  0:13:16  0:05:33  0:07:43 1119k
 42  652M   42  274M    0     0   838k      0  0:13:16  0:05:34  0:07:42 1068k
 42  652M   42  275M    0     0   839k      0  0:13:15  0:05:35  0:07:40 1068k
 42  652M   42  276M    0     0   840k      0  0:13:14  0:05:36  0:07:38 1094k
 42  652M   42  277M    0     0   841k      0  0:13:13  0:05:37  0:07:36 1100k
 42  652M   42  278M    0     0   842k      0  0:13:12  0:05:38  0:07:34 1113k
 42  652M   42  279M    0     0   843k      0  0:13:12  0:05:39  0:07:33 1139k
 43  652M   43  280M    0     0   843k      0  0:13:11  0:05:40  0:07:31 1111k
 43  652M   43  281M    0     0   844k      0  0:13:11  0:05:41  0:07:30 1093k
 43  652M   43  282M    0     0   843k      0  0:13:11  0:05:42  0:07:29  988k
 43  652M   43  283M    0     0   844k      0  0:13:11  0:05:43  0:07:28  940k
 43  652M   43  284M    0     0   844k      0  0:13:11  0:05:44  0:07:27  918k
 43  652M   43  285M    0     0   844k      0  0:13:11  0:05:45  0:07:26  878k
 43  652M   43  285M    0     0   844k      0  0:13:11  0:05:46  0:07:25  844k
 43  652M   43  286M    0     0   844k      0  0:13:11  0:05:47  0:07:24  889k
 44  652M   44  287M    0     0   844k      0  0:13:10  0:05:48  0:07:22  886k
 44  652M   44  288M    0     0   844k      0  0:13:10  0:05:49  0:07:21  886k
 44  652M   44  289M    0     0   844k      0  0:13:10  0:05:50  0:07:20  881k
 44  652M   44  290M    0     0   844k      0  0:13:10  0:05:51  0:07:19  876k
 44  652M   44  290M    0     0   844k      0  0:13:11  0:05:52  0:07:19  828k
 44  652M   44  291M    0     0   844k      0  0:13:11  0:05:53  0:07:18  831k
 44  652M   44  292M    0     0   845k      0  0:13:10  0:05:54  0:07:16  873k
 45  652M   45  294M    0     0   846k      0  0:13:09  0:05:55  0:07:14  944k
 45  652M   45  295M    0     0   847k      0  0:13:08  0:05:56  0:07:12 1001k
 45  652M   45  296M    0     0   847k      0  0:13:08  0:05:57  0:07:11 1056k
 45  652M   45  297M    0     0   848k      0  0:13:07  0:05:58  0:07:09 1110k
 45  652M   45  298M    0     0   849k      0  0:13:06  0:05:59  0:07:07 1126k
 45  652M   45  299M    0     0   850k      0  0:13:06  0:06:00  0:07:06 1123k
 46  652M   46  300M    0     0   850k      0  0:13:05  0:06:01  0:07:04 1123k
 46  652M   46  301M    0     0   851k      0  0:13:04  0:06:02  0:07:02 1162k
 46  652M   46  302M    0     0   851k      0  0:13:04  0:06:03  0:07:01 1084k
 46  652M   46  303M    0     0   852k      0  0:13:03  0:06:04  0:06:59 1084k
 46  652M   46  304M    0     0   852k      0  0:13:03  0:06:05  0:06:58 1036k
 46  652M   46  305M    0     0   853k      0  0:13:02  0:06:06  0:06:56 1036k
 47  652M   47  306M    0     0   854k      0  0:13:02  0:06:07  0:06:55 1051k
 47  652M   47  307M    0     0   854k      0  0:13:01  0:06:08  0:06:53 1097k
 47  652M   47  308M    0     0   855k      0  0:13:00  0:06:09  0:06:51 1094k
 47  652M   47  310M    0     0   856k      0  0:13:00  0:06:10  0:06:50 1115k
 47  652M   47  311M    0     0   857k      0  0:12:59  0:06:11  0:06:48 1132k
 47  652M   47  312M    0     0   857k      0  0:12:58  0:06:12  0:06:46 1120k
 47  652M   47  313M    0     0   858k      0  0:12:58  0:06:13  0:06:45 1096k
 48  652M   48  314M    0     0   858k      0  0:12:58  0:06:14  0:06:44 1091k
 48  652M   48  315M    0     0   859k      0  0:12:57  0:06:15  0:06:42 1121k
 48  652M   48  316M    0     0   860k      0  0:12:56  0:06:16  0:06:40 1097k
 48  652M   48  317M    0     0   860k      0  0:12:56  0:06:17  0:06:39 1065k
 48  652M   48  318M    0     0   861k      0  0:12:55  0:06:18  0:06:37 1114k
 48  652M   48  319M    0     0   862k      0  0:12:55  0:06:19  0:06:36 1106k
 49  652M   49  320M    0     0   861k      0  0:12:55  0:06:20  0:06:35 1001k
 49  652M   49  321M    0     0   861k      0  0:12:55  0:06:21  0:06:34  947k
 49  652M   49  322M    0     0   861k      0  0:12:55  0:06:22  0:06:33  937k
 49  652M   49  322M    0     0   861k      0  0:12:55  0:06:23  0:06:32  882k
 49  652M   49  323M    0     0   861k      0  0:12:55  0:06:24  0:06:31  838k
 49  652M   49  324M    0     0   861k      0  0:12:55  0:06:25  0:06:30  892k
 49  652M   49  325M    0     0   862k      0  0:12:55  0:06:26  0:06:29  901k
 50  652M   50  326M    0     0   862k      0  0:12:55  0:06:27  0:06:28  896k
 50  652M   50  327M    0     0   862k      0  0:12:54  0:06:28  0:06:26  901k
 50  652M   50  328M    0     0   862k      0  0:12:54  0:06:29  0:06:25  905k
 50  652M   50  329M    0     0   862k      0  0:12:54  0:06:30  0:06:24  905k
 50  652M   50  329M    0     0   862k      0  0:12:54  0:06:31  0:06:23  874k
 50  652M   50  330M    0     0   862k      0  0:12:55  0:06:32  0:06:23  859k
 50  652M   50  331M    0     0   862k      0  0:12:54  0:06:33  0:06:21  868k
 50  652M   50  332M    0     0   862k      0  0:12:54  0:06:34  0:06:20  902k
 51  652M   51  333M    0     0   863k      0  0:12:53  0:06:35  0:06:18  937k
 51  652M   51  334M    0     0   864k      0  0:12:53  0:06:36  0:06:17 1015k
 51  652M   51  335M    0     0   864k      0  0:12:53  0:06:37  0:06:16 1024k
 51  652M   51  336M    0     0   864k      0  0:12:52  0:06:38  0:06:14 1039k
 51  652M   51  337M    0     0   865k      0  0:12:52  0:06:39  0:06:13 1041k
 51  652M   51  338M    0     0   865k      0  0:12:52  0:06:40  0:06:12 1027k
 52  652M   52  339M    0     0   866k      0  0:12:51  0:06:41  0:06:10 1019k
 52  652M   52  340M    0     0   866k      0  0:12:50  0:06:42  0:06:08 1075k
 52  652M   52  341M    0     0   866k      0  0:12:50  0:06:43  0:06:07 1038k
 52  652M   52  342M    0     0   866k      0  0:12:51  0:06:44  0:06:07  970k
 52  652M   52  343M    0     0   866k      0  0:12:50  0:06:45  0:06:05  963k
 52  652M   52  344M    0     0   867k      0  0:12:50  0:06:46  0:06:04  975k
 52  652M   52  345M    0     0   867k      0  0:12:50  0:06:47  0:06:03  937k
 53  652M   53  346M    0     0   868k      0  0:12:49  0:06:48  0:06:01  993k
 53  652M   53  347M    0     0   868k      0  0:12:49  0:06:49  0:06:00  995k
 53  652M   53  348M    0     0   868k      0  0:12:49  0:06:50  0:05:59  985k
 53  652M   53  349M    0     0   868k      0  0:12:49  0:06:51  0:05:58  912k
 53  652M   53  349M    0     0   868k      0  0:12:49  0:06:52  0:05:57  899k
 53  652M   53  350M    0     0   868k      0  0:12:49  0:06:53  0:05:56  857k
 53  652M   53  351M    0     0   868k      0  0:12:49  0:06:54  0:05:55  888k
 54  652M   54  352M    0     0   868k      0  0:12:49  0:06:55  0:05:54  879k
 54  652M   54  353M    0     0   868k      0  0:12:49  0:06:56  0:05:53  889k
 54  652M   54  354M    0     0   868k      0  0:12:49  0:06:57  0:05:52  882k
 54  652M   54  355M    0     0   868k      0  0:12:49  0:06:58  0:05:51  879k
 54  652M   54  355M    0     0   868k      0  0:12:49  0:06:59  0:05:50  867k
 54  652M   54  356M    0     0   867k      0  0:12:50  0:07:00  0:05:50  787k
 54  652M   54  357M    0     0   867k      0  0:12:50  0:07:01  0:05:49  771k
 54  652M   54  357M    0     0   866k      0  0:12:51  0:07:02  0:05:49  699k
 54  652M   54  358M    0     0   866k      0  0:12:51  0:07:03  0:05:48  688k
 55  652M   55  359M    0     0   865k      0  0:12:51  0:07:04  0:05:47  652k
 55  652M   55  359M    0     0   865k      0  0:12:52  0:07:05  0:05:47  672k
 55  652M   55  360M    0     0   864k      0  0:12:52  0:07:06  0:05:46  675k
 55  652M   55  361M    0     0   864k      0  0:12:52  0:07:07  0:05:45  759k
 55  652M   55  362M    0     0   865k      0  0:12:52  0:07:08  0:05:44  771k
 55  652M   55  363M    0     0   865k      0  0:12:52  0:07:09  0:05:43  822k
 55  652M   55  363M    0     0   865k      0  0:12:52  0:07:10  0:05:42  883k
 55  652M   55  364M    0     0   865k      0  0:12:52  0:07:11  0:05:41  908k
 56  652M   56  365M    0     0   865k      0  0:12:52  0:07:12  0:05:40  908k
 56  652M   56  366M    0     0   865k      0  0:12:52  0:07:13  0:05:39  880k
 56  652M   56  367M    0     0   865k      0  0:12:52  0:07:14  0:05:38  851k
 56  652M   56  368M    0     0   864k      0  0:12:52  0:07:15  0:05:37  838k
 56  652M   56  368M    0     0   864k      0  0:12:52  0:07:16  0:05:36  830k
 56  652M   56  369M    0     0   865k      0  0:12:52  0:07:17  0:05:35  832k
 56  652M   56  370M    0     0   865k      0  0:12:52  0:07:18  0:05:34  857k
 56  652M   56  371M    0     0   864k      0  0:12:52  0:07:19  0:05:33  832k
 57  652M   57  371M    0     0   864k      0  0:12:53  0:07:20  0:05:33  800k
 57  652M   57  372M    0     0   864k      0  0:12:53  0:07:21  0:05:32  804k
 57  652M   57  373M    0     0   864k      0  0:12:53  0:07:22  0:05:31  796k
 57  652M   57  374M    0     0   864k      0  0:12:52  0:07:23  0:05:29  803k
 57  652M   57  375M    0     0   863k      0  0:12:53  0:07:24  0:05:29  771k
 57  652M   57  375M    0     0   862k      0  0:12:54  0:07:25  0:05:29  748k
 57  652M   57  376M    0     0   862k      0  0:12:54  0:07:26  0:05:28  732k
 57  652M   57  377M    0     0   862k      0  0:12:54  0:07:27  0:05:27  739k
 57  652M   57  378M    0     0   863k      0  0:12:54  0:07:28  0:05:26  736k
 58  652M   58  378M    0     0   862k      0  0:12:54  0:07:29  0:05:25  793k
 58  652M   58  379M    0     0   862k      0  0:12:54  0:07:30  0:05:24  857k
 58  652M   58  380M    0     0   862k      0  0:12:54  0:07:31  0:05:23  864k
 58  652M   58  381M    0     0   862k      0  0:12:54  0:07:32  0:05:22  857k
 58  652M   58  382M    0     0   862k      0  0:12:54  0:07:33  0:05:21  860k
 58  652M   58  383M    0     0   863k      0  0:12:54  0:07:34  0:05:20  883k
 58  652M   58  384M    0     0   863k      0  0:12:54  0:07:35  0:05:19  877k
 59  652M   59  384M    0     0   863k      0  0:12:54  0:07:36  0:05:18  886k
 59  652M   59  385M    0     0   862k      0  0:12:54  0:07:37  0:05:17  851k
 59  652M   59  386M    0     0   862k      0  0:12:54  0:07:38  0:05:16  847k
 59  652M   59  387M    0     0   862k      0  0:12:54  0:07:39  0:05:15  826k
 59  652M   59  387M    0     0   862k      0  0:12:55  0:07:40  0:05:15  768k
 59  652M   59  388M    0     0   861k      0  0:12:55  0:07:41  0:05:14  681k
 59  652M   59  389M    0     0   861k      0  0:12:55  0:07:42  0:05:13  713k
 59  652M   59  390M    0     0   861k      0  0:12:55  0:07:43  0:05:12  712k
 59  652M   59  390M    0     0   861k      0  0:12:55  0:07:44  0:05:11  737k
 60  652M   60  391M    0     0   861k      0  0:12:55  0:07:45  0:05:10  809k
 60  652M   60  392M    0     0   861k      0  0:12:55  0:07:46  0:05:09  899k
 60  652M   60  393M    0     0   861k      0  0:12:55  0:07:47  0:05:08  934k
 60  652M   60  394M    0     0   862k      0  0:12:54  0:07:48  0:05:06  986k
 60  652M   60  395M    0     0   862k      0  0:12:54  0:07:49  0:05:05  982k
 60  652M   60  396M    0     0   862k      0  0:12:54  0:07:50  0:05:04  979k
 60  652M   60  397M    0     0   862k      0  0:12:54  0:07:51  0:05:03  972k
 61  652M   61  398M    0     0   862k      0  0:12:54  0:07:52  0:05:02  947k
 61  652M   61  398M    0     0   862k      0  0:12:54  0:07:53  0:05:01  847k
 61  652M   61  399M    0     0   862k      0  0:12:55  0:07:54  0:05:01  812k
 61  652M   61  400M    0     0   861k      0  0:12:55  0:07:55  0:05:00  777k
 61  652M   61  401M    0     0   861k      0  0:12:55  0:07:56  0:04:59  774k
 61  652M   61  402M    0     0   861k      0  0:12:55  0:07:57  0:04:58  761k
 61  652M   61  402M    0     0   861k      0  0:12:55  0:07:58  0:04:57  806k
 61  652M   61  403M    0     0   861k      0  0:12:55  0:07:59  0:04:56  842k
 62  652M   62  404M    0     0   861k      0  0:12:55  0:08:00  0:04:55  873k
 62  652M   62  405M    0     0   861k      0  0:12:55  0:08:01  0:04:54  815k
 62  652M   62  405M    0     0   860k      0  0:12:56  0:08:02  0:04:54  783k
 62  652M   62  406M    0     0   860k      0  0:12:56  0:08:03  0:04:53  730k
 62  652M   62  407M    0     0   860k      0  0:12:56  0:08:04  0:04:52  729k
 62  652M   62  408M    0     0   860k      0  0:12:56  0:08:05  0:04:51  729k
 62  652M   62  409M    0     0   860k      0  0:12:56  0:08:06  0:04:50  794k
 62  652M   62  409M    0     0   860k      0  0:12:56  0:08:07  0:04:49  832k
 62  652M   62  410M    0     0   860k      0  0:12:56  0:08:08  0:04:48  885k
 63  652M   63  411M    0     0   860k      0  0:12:56  0:08:09  0:04:47  837k
 63  652M   63  412M    0     0   860k      0  0:12:56  0:08:10  0:04:46  822k
 63  652M   63  413M    0     0   860k      0  0:12:56  0:08:11  0:04:45  822k
 63  652M   63  413M    0     0   860k      0  0:12:56  0:08:12  0:04:44  822k
 63  652M   63  414M    0     0   860k      0  0:12:56  0:08:13  0:04:43  793k
 63  652M   63  415M    0     0   860k      0  0:12:56  0:08:14  0:04:42  852k
 63  652M   63  416M    0     0   860k      0  0:12:56  0:08:15  0:04:41  908k
 64  652M   64  417M    0     0   861k      0  0:12:55  0:08:16  0:04:39  950k
 64  652M   64  418M    0     0   861k      0  0:12:55  0:08:17  0:04:38 1011k
 64  652M   64  419M    0     0   861k      0  0:12:55  0:08:18  0:04:37 1042k
 64  652M   64  420M    0     0   862k      0  0:12:54  0:08:19  0:04:35 1078k
 64  652M   64  421M    0     0   862k      0  0:12:54  0:08:20  0:04:34 1088k
 64  652M   64  423M    0     0   863k      0  0:12:53  0:08:21  0:04:32 1100k
 65  652M   65  424M    0     0   864k      0  0:12:53  0:08:22  0:04:31 1091k
 65  652M   65  424M    0     0   863k      0  0:12:53  0:08:23  0:04:30 1025k
 65  652M   65  425M    0     0   862k      0  0:12:54  0:08:24  0:04:30  896k
 65  652M   65  425M    0     0   862k      0  0:12:54  0:08:25  0:04:29  809k
 65  652M   65  426M    0     0   862k      0  0:12:54  0:08:26  0:04:28  777k
 65  652M   65  427M    0     0   862k      0  0:12:54  0:08:27  0:04:27  732k
 65  652M   65  428M    0     0   862k      0  0:12:54  0:08:28  0:04:26  802k
 65  652M   65  429M    0     0   863k      0  0:12:53  0:08:29  0:04:24  925k
 66  652M   66  430M    0     0   863k      0  0:12:53  0:08:30  0:04:23 1011k
 66  652M   66  431M    0     0   864k      0  0:12:53  0:08:31  0:04:22 1014k
 66  652M   66  432M    0     0   864k      0  0:12:53  0:08:32  0:04:21 1007k
 66  652M   66  433M    0     0   864k      0  0:12:52  0:08:33  0:04:19 1056k
 66  652M   66  435M    0     0   865k      0  0:12:52  0:08:34  0:04:18 1072k
 66  652M   66  436M    0     0   865k      0  0:12:51  0:08:35  0:04:16 1052k
 66  652M   66  437M    0     0   866k      0  0:12:51  0:08:36  0:04:15 1078k
 67  652M   67  438M    0     0   866k      0  0:12:51  0:08:37  0:04:14 1116k
 67  652M   67  439M    0     0   866k      0  0:12:50  0:08:38  0:04:12 1068k
 67  652M   67  440M    0     0   867k      0  0:12:50  0:08:39  0:04:11 1052k
 67  652M   67  441M    0     0   867k      0  0:12:50  0:08:40  0:04:10 1068k
 67  652M   67  442M    0     0   868k      0  0:12:49  0:08:41  0:04:08 1059k
 67  652M   67  443M    0     0   868k      0  0:12:49  0:08:42  0:04:07 1078k
 68  652M   68  444M    0     0   869k      0  0:12:48  0:08:43  0:04:05 1129k
 68  652M   68  445M    0     0   869k      0  0:12:48  0:08:44  0:04:04 1152k
 68  652M   68  446M    0     0   870k      0  0:12:47  0:08:45  0:04:02 1126k
 68  652M   68  447M    0     0   870k      0  0:12:47  0:08:46  0:04:01 1139k
 68  652M   68  448M    0     0   870k      0  0:12:47  0:08:47  0:04:00 1056k
 68  652M   68  449M    0     0   870k      0  0:12:47  0:08:48  0:03:59 1039k
 69  652M   69  450M    0     0   871k      0  0:12:46  0:08:49  0:03:57 1026k
 69  652M   69  451M    0     0   871k      0  0:12:46  0:08:50  0:03:56 1061k
 69  652M   69  453M    0     0   872k      0  0:12:45  0:08:51  0:03:54 1062k
 69  652M   69  454M    0     0   872k      0  0:12:45  0:08:52  0:03:53 1110k
 69  652M   69  454M    0     0   872k      0  0:12:45  0:08:53  0:03:52 1062k
 69  652M   69  455M    0     0   872k      0  0:12:45  0:08:54  0:03:51 1010k
 70  652M   70  456M    0     0   873k      0  0:12:45  0:08:55  0:03:50 1004k
 70  652M   70  457M    0     0   873k      0  0:12:45  0:08:56  0:03:49  950k
 70  652M   70  458M    0     0   873k      0  0:12:44  0:08:57  0:03:47  988k
 70  652M   70  460M    0     0   874k      0  0:12:44  0:08:58  0:03:46 1051k
 70  652M   70  461M    0     0   874k      0  0:12:43  0:08:59  0:03:44 1095k
 70  652M   70  462M    0     0   875k      0  0:12:43  0:09:00  0:03:43 1100k
 71  652M   71  463M    0     0   875k      0  0:12:42  0:09:01  0:03:41 1158k
 71  652M   71  464M    0     0   876k      0  0:12:42  0:09:02  0:03:40 1155k
 71  652M   71  465M    0     0   876k      0  0:12:42  0:09:03  0:03:39 1066k
 71  652M   71  466M    0     0   876k      0  0:12:42  0:09:04  0:03:38 1018k
 71  652M   71  466M    0     0   876k      0  0:12:42  0:09:05  0:03:37  966k
 71  652M   71  467M    0     0   876k      0  0:12:42  0:09:06  0:03:36  912k
 71  652M   71  468M    0     0   876k      0  0:12:42  0:09:07  0:03:35  863k
 71  652M   71  469M    0     0   876k      0  0:12:42  0:09:08  0:03:34  876k
 72  652M   72  470M    0     0   875k      0  0:12:42  0:09:09  0:03:33  856k
 72  652M   72  471M    0     0   875k      0  0:12:43  0:09:10  0:03:33  835k
 72  652M   72  471M    0     0   875k      0  0:12:43  0:09:11  0:03:32  825k
 72  652M   72  472M    0     0   875k      0  0:12:43  0:09:12  0:03:31  812k
 72  652M   72  473M    0     0   875k      0  0:12:43  0:09:13  0:03:30  783k
 72  652M   72  474M    0     0   875k      0  0:12:43  0:09:14  0:03:29  819k
 72  652M   72  475M    0     0   875k      0  0:12:43  0:09:15  0:03:28  841k
 72  652M   72  475M    0     0   875k      0  0:12:43  0:09:16  0:03:27  847k
 73  652M   73  476M    0     0   875k      0  0:12:43  0:09:17  0:03:26  857k
 73  652M   73  477M    0     0   875k      0  0:12:43  0:09:18  0:03:25  908k
 73  652M   73  478M    0     0   875k      0  0:12:43  0:09:19  0:03:24  863k
 73  652M   73  479M    0     0   875k      0  0:12:43  0:09:20  0:03:23  867k
 73  652M   73  480M    0     0   875k      0  0:12:43  0:09:21  0:03:22  867k
 73  652M   73  481M    0     0   875k      0  0:12:43  0:09:22  0:03:21  857k
 73  652M   73  481M    0     0   875k      0  0:12:43  0:09:23  0:03:20  854k
 73  652M   73  482M    0     0   875k      0  0:12:43  0:09:24  0:03:19  899k
 74  652M   74  483M    0     0   875k      0  0:12:43  0:09:25  0:03:18  892k
 74  652M   74  484M    0     0   875k      0  0:12:43  0:09:26  0:03:17  899k
 74  652M   74  485M    0     0   875k      0  0:12:43  0:09:27  0:03:16  895k
 74  652M   74  486M    0     0   875k      0  0:12:43  0:09:28  0:03:15  860k
 74  652M   74  486M    0     0   875k      0  0:12:43  0:09:29  0:03:14  828k
 74  652M   74  487M    0     0   874k      0  0:12:43  0:09:30  0:03:13  809k
 74  652M   74  488M    0     0   874k      0  0:12:43  0:09:31  0:03:12  802k
 74  652M   74  489M    0     0   874k      0  0:12:43  0:09:32  0:03:11  806k
 75  652M   75  490M    0     0   874k      0  0:12:43  0:09:33  0:03:10  832k
 75  652M   75  491M    0     0   874k      0  0:12:43  0:09:34  0:03:09  857k
 75  652M   75  491M    0     0   874k      0  0:12:43  0:09:35  0:03:08  860k
 75  652M   75  492M    0     0   874k      0  0:12:44  0:09:36  0:03:08  832k
 75  652M   75  493M    0     0   874k      0  0:12:44  0:09:37  0:03:07  818k
 75  652M   75  493M    0     0   873k      0  0:12:44  0:09:38  0:03:06  764k
 75  652M   75  494M    0     0   873k      0  0:12:44  0:09:39  0:03:05  755k
 75  652M   75  495M    0     0   873k      0  0:12:44  0:09:40  0:03:04  771k
 76  652M   76  496M    0     0   873k      0  0:12:44  0:09:41  0:03:03  774k
 76  652M   76  497M    0     0   873k      0  0:12:45  0:09:42  0:03:03  752k
 76  652M   76  497M    0     0   873k      0  0:12:45  0:09:43  0:03:02  809k
 76  652M   76  498M    0     0   873k      0  0:12:45  0:09:44  0:03:01  819k
 76  652M   76  499M    0     0   873k      0  0:12:45  0:09:45  0:03:00  819k
 76  652M   76  500M    0     0   873k      0  0:12:44  0:09:46  0:02:58  851k
 76  652M   76  501M    0     0   873k      0  0:12:44  0:09:47  0:02:57  892k
 76  652M   76  502M    0     0   873k      0  0:12:44  0:09:48  0:02:56  921k
 77  652M   77  503M    0     0   874k      0  0:12:44  0:09:49  0:02:55  975k
 77  652M   77  504M    0     0   874k      0  0:12:44  0:09:50  0:02:54 1005k
 77  652M   77  505M    0     0   874k      0  0:12:44  0:09:51  0:02:53  971k
 77  652M   77  505M    0     0   874k      0  0:12:44  0:09:52  0:02:52  928k
 77  652M   77  506M    0     0   874k      0  0:12:44  0:09:53  0:02:51  905k
 77  652M   77  507M    0     0   874k      0  0:12:44  0:09:54  0:02:50  844k
 77  652M   77  508M    0     0   873k      0  0:12:44  0:09:55  0:02:49  788k
 78  652M   78  509M    0     0   873k      0  0:12:44  0:09:56  0:02:48  790k
 78  652M   78  509M    0     0   873k      0  0:12:45  0:09:57  0:02:48  796k
 78  652M   78  510M    0     0   873k      0  0:12:45  0:09:58  0:02:47  764k
 78  652M   78  511M    0     0   872k      0  0:12:45  0:09:59  0:02:46  732k
 78  652M   78  511M    0     0   872k      0  0:12:45  0:10:00  0:02:45  704k
 78  652M   78  512M    0     0   872k      0  0:12:46  0:10:01  0:02:45  691k
 78  652M   78  513M    0     0   871k      0  0:12:46  0:10:02  0:02:44  659k
 78  652M   78  513M    0     0   871k      0  0:12:46  0:10:03  0:02:43  684k
 78  652M   78  514M    0     0   871k      0  0:12:46  0:10:04  0:02:42  726k
 79  652M   79  515M    0     0   871k      0  0:12:46  0:10:05  0:02:41  774k
 79  652M   79  516M    0     0   871k      0  0:12:46  0:10:06  0:02:40  800k
 79  652M   79  517M    0     0   871k      0  0:12:46  0:10:07  0:02:39  856k
 79  652M   79  518M    0     0   871k      0  0:12:46  0:10:08  0:02:38  851k
 79  652M   79  518M    0     0   871k      0  0:12:46  0:10:09  0:02:37  848k
 79  652M   79  519M    0     0   871k      0  0:12:46  0:10:10  0:02:36  854k
 79  652M   79  520M    0     0   871k      0  0:12:46  0:10:11  0:02:35  867k
 79  652M   79  521M    0     0   870k      0  0:12:47  0:10:12  0:02:35  793k
 79  652M   79  521M    0     0   870k      0  0:12:47  0:10:13  0:02:34  800k
 80  652M   80  522M    0     0   870k      0  0:12:47  0:10:14  0:02:33  796k
 80  652M   80  523M    0     0   870k      0  0:12:47  0:10:15  0:02:32  776k
 80  652M   80  524M    0     0   870k      0  0:12:47  0:10:16  0:02:31  768k
 80  652M   80  525M    0     0   870k      0  0:12:47  0:10:17  0:02:30  825k
 80  652M   80  526M    0     0   870k      0  0:12:47  0:10:18  0:02:29  844k
 80  652M   80  526M    0     0   870k      0  0:12:47  0:10:19  0:02:28  844k
 80  652M   80  527M    0     0   870k      0  0:12:47  0:10:20  0:02:27  865k
 81  652M   81  528M    0     0   870k      0  0:12:47  0:10:21  0:02:26  857k
 81  652M   81  529M    0     0   870k      0  0:12:47  0:10:22  0:02:25  877k
 81  652M   81  530M    0     0   870k      0  0:12:47  0:10:23  0:02:24  828k
 81  652M   81  531M    0     0   870k      0  0:12:47  0:10:24  0:02:23  838k
 81  652M   81  531M    0     0   870k      0  0:12:47  0:10:25  0:02:22  830k
 81  652M   81  532M    0     0   870k      0  0:12:47  0:10:26  0:02:21  847k
 81  652M   81  533M    0     0   870k      0  0:12:47  0:10:27  0:02:20  860k
 81  652M   81  534M    0     0   870k      0  0:12:47  0:10:28  0:02:19  937k
 82  652M   82  535M    0     0   871k      0  0:12:46  0:10:29  0:02:17  992k
 82  652M   82  536M    0     0   871k      0  0:12:46  0:10:30  0:02:16 1018k
 82  652M   82  537M    0     0   871k      0  0:12:46  0:10:31  0:02:15 1049k
 82  652M   82  538M    0     0   872k      0  0:12:46  0:10:32  0:02:14 1081k
 82  652M   82  539M    0     0   872k      0  0:12:45  0:10:33  0:02:12 1072k
 82  652M   82  540M    0     0   871k      0  0:12:46  0:10:34  0:02:12  923k
 82  652M   82  540M    0     0   871k      0  0:12:46  0:10:35  0:02:11  844k
 82  652M   82  541M    0     0   870k      0  0:12:47  0:10:36  0:02:11  751k
 83  652M   83  542M    0     0   870k      0  0:12:47  0:10:37  0:02:10  684k
 83  652M   83  543M    0     0   870k      0  0:12:47  0:10:38  0:02:09  633k
 83  652M   83  543M    0     0   870k      0  0:12:47  0:10:39  0:02:08  722k
 83  652M   83  544M    0     0   870k      0  0:12:47  0:10:40  0:02:07  713k
 83  652M   83  545M    0     0   870k      0  0:12:47  0:10:41  0:02:06  780k
 83  652M   83  546M    0     0   870k      0  0:12:47  0:10:42  0:02:05  812k
 83  652M   83  547M    0     0   870k      0  0:12:47  0:10:43  0:02:04  834k
 83  652M   83  547M    0     0   870k      0  0:12:47  0:10:44  0:02:03  832k
 84  652M   84  548M    0     0   870k      0  0:12:47  0:10:45  0:02:02  875k
 84  652M   84  549M    0     0   869k      0  0:12:48  0:10:46  0:02:02  828k
 84  652M   84  550M    0     0   869k      0  0:12:48  0:10:47  0:02:01  832k
 84  652M   84  551M    0     0   869k      0  0:12:48  0:10:48  0:02:00  828k
 84  652M   84  551M    0     0   869k      0  0:12:48  0:10:49  0:01:59  790k
 84  652M   84  552M    0     0   869k      0  0:12:48  0:10:50  0:01:58  831k
 84  652M   84  553M    0     0   870k      0  0:12:47  0:10:51  0:01:56  924k
 85  652M   85  555M    0     0   870k      0  0:12:47  0:10:52  0:01:55  975k
 85  652M   85  556M    0     0   871k      0  0:12:47  0:10:53  0:01:54 1027k
 85  652M   85  557M    0     0   871k      0  0:12:46  0:10:54  0:01:52 1120k
 85  652M   85  558M    0     0   871k      0  0:12:46  0:10:55  0:01:51 1141k
 85  652M   85  559M    0     0   872k      0  0:12:45  0:10:56  0:01:49 1142k
 85  652M   85  559M    0     0   871k      0  0:12:46  0:10:58  0:01:48  953k
 85  652M   85  560M    0     0   871k      0  0:12:46  0:10:58  0:01:48  934k
 86  652M   86  561M    0     0   871k      0  0:12:46  0:10:59  0:01:47  831k
 86  652M   86  562M    0     0   871k      0  0:12:47  0:11:00  0:01:47  774k
 86  652M   86  562M    0     0   870k      0  0:12:47  0:11:01  0:01:46  637k
 86  652M   86  563M    0     0   869k      0  0:12:48  0:11:02  0:01:46  664k
 86  652M   86  563M    0     0   869k      0  0:12:48  0:11:03  0:01:45  620k
 86  652M   86  564M    0     0   869k      0  0:12:48  0:11:04  0:01:44  659k
 86  652M   86  565M    0     0   869k      0  0:12:48  0:11:05  0:01:43  684k
 86  652M   86  566M    0     0   869k      0  0:12:48  0:11:06  0:01:42  764k
 86  652M   86  567M    0     0   869k      0  0:12:48  0:11:07  0:01:41  854k
 87  652M   87  568M    0     0   869k      0  0:12:48  0:11:08  0:01:40  873k
 87  652M   87  568M    0     0   869k      0  0:12:48  0:11:09  0:01:39  870k
 87  652M   87  569M    0     0   869k      0  0:12:48  0:11:10  0:01:38  870k
 87  652M   87  570M    0     0   869k      0  0:12:48  0:11:11  0:01:37  864k
 87  652M   87  571M    0     0   869k      0  0:12:48  0:11:12  0:01:36  783k
 87  652M   87  571M    0     0   869k      0  0:12:48  0:11:13  0:01:35  780k
 87  652M   87  572M    0     0   869k      0  0:12:48  0:11:14  0:01:34  780k
 87  652M   87  573M    0     0   869k      0  0:12:48  0:11:15  0:01:33  774k
 88  652M   88  574M    0     0   869k      0  0:12:48  0:11:16  0:01:32  793k
 88  652M   88  575M    0     0   868k      0  0:12:48  0:11:17  0:01:31  848k
 88  652M   88  575M    0     0   868k      0  0:12:49  0:11:18  0:01:31  819k
 88  652M   88  576M    0     0   868k      0  0:12:49  0:11:19  0:01:30  848k
 88  652M   88  577M    0     0   869k      0  0:12:48  0:11:20  0:01:28  892k
 88  652M   88  578M    0     0   869k      0  0:12:48  0:11:21  0:01:27  924k
 88  652M   88  579M    0     0   869k      0  0:12:48  0:11:22  0:01:26  976k
 89  652M   89  580M    0     0   870k      0  0:12:48  0:11:23  0:01:25 1039k
 89  652M   89  581M    0     0   869k      0  0:12:48  0:11:24  0:01:24  988k
 89  652M   89  582M    0     0   869k      0  0:12:48  0:11:25  0:01:23  876k
 89  652M   89  583M    0     0   869k      0  0:12:48  0:11:26  0:01:22  835k
 89  652M   89  583M    0     0   869k      0  0:12:48  0:11:27  0:01:21  791k
 89  652M   89  584M    0     0   868k      0  0:12:48  0:11:28  0:01:20  729k
 89  652M   89  585M    0     0   868k      0  0:12:48  0:11:29  0:01:19  754k
 89  652M   89  586M    0     0   868k      0  0:12:48  0:11:30  0:01:18  819k
 89  652M   89  587M    0     0   869k      0  0:12:48  0:11:31  0:01:17  832k
 90  652M   90  588M    0     0   869k      0  0:12:48  0:11:32  0:01:16  868k
 90  652M   90  589M    0     0   869k      0  0:12:48  0:11:33  0:01:15  950k
 90  652M   90  590M    0     0   870k      0  0:12:48  0:11:34  0:01:14 1014k
 90  652M   90  591M    0     0   870k      0  0:12:47  0:11:35  0:01:12 1078k
 90  652M   90  592M    0     0   870k      0  0:12:47  0:11:36  0:01:11 1056k
 90  652M   90  593M    0     0   870k      0  0:12:47  0:11:37  0:01:10 1091k
 91  652M   91  594M    0     0   871k      0  0:12:47  0:11:38  0:01:09 1070k
 91  652M   91  595M    0     0   871k      0  0:12:47  0:11:39  0:01:08 1027k
 91  652M   91  596M    0     0   871k      0  0:12:46  0:11:40  0:01:06 1043k
 91  652M   91  597M    0     0   872k      0  0:12:46  0:11:41  0:01:05 1110k
 91  652M   91  598M    0     0   872k      0  0:12:46  0:11:42  0:01:04 1055k
 91  652M   91  599M    0     0   872k      0  0:12:46  0:11:43  0:01:03 1013k
 91  652M   91  600M    0     0   871k      0  0:12:46  0:11:44  0:01:02  988k
 92  652M   92  600M    0     0   871k      0  0:12:46  0:11:45  0:01:01  911k
 92  652M   92  601M    0     0   871k      0  0:12:46  0:11:46  0:01:00  841k
 92  652M   92  602M    0     0   871k      0  0:12:46  0:11:47  0:00:59  841k
 92  652M   92  603M    0     0   871k      0  0:12:46  0:11:48  0:00:58  848k
 92  652M   92  604M    0     0   871k      0  0:12:46  0:11:49  0:00:57  808k
 92  652M   92  604M    0     0   871k      0  0:12:46  0:11:50  0:00:56  796k
 92  652M   92  605M    0     0   871k      0  0:12:46  0:11:51  0:00:55  809k
 92  652M   92  606M    0     0   871k      0  0:12:46  0:11:52  0:00:54  800k
 93  652M   93  607M    0     0   871k      0  0:12:46  0:11:53  0:00:53  812k
 93  652M   93  608M    0     0   871k      0  0:12:46  0:11:54  0:00:52  871k
 93  652M   93  609M    0     0   871k      0  0:12:46  0:11:55  0:00:51  903k
 93  652M   93  609M    0     0   871k      0  0:12:47  0:11:56  0:00:51  831k
 93  652M   93  610M    0     0   870k      0  0:12:47  0:11:57  0:00:50  732k
 93  652M   93  610M    0     0   869k      0  0:12:48  0:11:58  0:00:50  628k
 93  652M   93  611M    0     0   869k      0  0:12:48  0:11:59  0:00:49  562k
 93  652M   93  611M    0     0   869k      0  0:12:48  0:12:00  0:00:48  524k
 93  652M   93  612M    0     0   869k      0  0:12:48  0:12:01  0:00:47  587k
 94  652M   94  613M    0     0   869k      0  0:12:48  0:12:02  0:00:46  704k
 94  652M   94  614M    0     0   869k      0  0:12:48  0:12:03  0:00:45  793k
 94  652M   94  615M    0     0   869k      0  0:12:48  0:12:04  0:00:44  857k
 94  652M   94  615M    0     0   869k      0  0:12:48  0:12:05  0:00:43  838k
 94  652M   94  616M    0     0   868k      0  0:12:49  0:12:06  0:00:43  788k
 94  652M   94  617M    0     0   868k      0  0:12:49  0:12:07  0:00:42  771k
 94  652M   94  617M    0     0   868k      0  0:12:49  0:12:08  0:00:41  720k
 94  652M   94  618M    0     0   867k      0  0:12:50  0:12:09  0:00:41  650k
 94  652M   94  619M    0     0   867k      0  0:12:50  0:12:10  0:00:40  646k
 95  652M   95  619M    0     0   867k      0  0:12:50  0:12:11  0:00:39  705k
 95  652M   95  620M    0     0   867k      0  0:12:50  0:12:12  0:00:38  726k
 95  652M   95  621M    0     0   867k      0  0:12:50  0:12:13  0:00:37  796k
 95  652M   95  622M    0     0   868k      0  0:12:49  0:12:14  0:00:35  912k
 95  652M   95  623M    0     0   868k      0  0:12:49  0:12:15  0:00:34 1004k
 95  652M   95  625M    0     0   868k      0  0:12:49  0:12:16  0:00:33 1058k
 95  652M   95  626M    0     0   869k      0  0:12:48  0:12:17  0:00:31 1082k
 96  652M   96  627M    0     0   869k      0  0:12:48  0:12:18  0:00:30 1129k
 96  652M   96  628M    0     0   869k      0  0:12:48  0:12:19  0:00:29 1135k
 96  652M   96  629M    0     0   870k      0  0:12:47  0:12:20  0:00:27 1123k
 96  652M   96  630M    0     0   870k      0  0:12:47  0:12:21  0:00:26 1103k
 96  652M   96  631M    0     0   870k      0  0:12:47  0:12:22  0:00:25 1132k
 96  652M   96  632M    0     0   870k      0  0:12:47  0:12:23  0:00:24 1081k
 97  652M   97  633M    0     0   870k      0  0:12:47  0:12:24  0:00:23 1014k
 97  652M   97  634M    0     0   871k      0  0:12:47  0:12:25  0:00:22 1020k
 97  652M   97  635M    0     0   871k      0  0:12:46  0:12:26  0:00:20 1019k
 97  652M   97  636M    0     0   871k      0  0:12:46  0:12:27  0:00:19 1000k
 97  652M   97  637M    0     0   871k      0  0:12:46  0:12:28  0:00:18  985k
 97  652M   97  638M    0     0   871k      0  0:12:46  0:12:29  0:00:17  962k
 97  652M   97  638M    0     0   871k      0  0:12:46  0:12:30  0:00:16  915k
 98  652M   98  639M    0     0   871k      0  0:12:46  0:12:31  0:00:15  858k
 98  652M   98  640M    0     0   871k      0  0:12:46  0:12:32  0:00:14  812k
 98  652M   98  641M    0     0   871k      0  0:12:46  0:12:33  0:00:13  824k
 98  652M   98  642M    0     0   871k      0  0:12:46  0:12:34  0:00:12  883k
 98  652M   98  643M    0     0   871k      0  0:12:46  0:12:35  0:00:11  879k
 98  652M   98  644M    0     0   871k      0  0:12:46  0:12:36  0:00:10  889k
 98  652M   98  644M    0     0   871k      0  0:12:47  0:12:37  0:00:10  838k
 98  652M   98  645M    0     0   871k      0  0:12:46  0:12:38  0:00:08  849k
 99  652M   99  646M    0     0   870k      0  0:12:47  0:12:39  0:00:08  785k
 99  652M   99  647M    0     0   870k      0  0:12:47  0:12:40  0:00:07  780k
 99  652M   99  647M    0     0   870k      0  0:12:47  0:12:41  0:00:06  742k
 99  652M   99  648M    0     0   870k      0  0:12:47  0:12:42  0:00:05  745k
 99  652M   99  649M    0     0   870k      0  0:12:47  0:12:43  0:00:04  707k
 99  652M   99  649M    0     0   869k      0  0:12:48  0:12:44  0:00:04  705k
 99  652M   99  650M    0     0   870k      0  0:12:48  0:12:45  0:00:03  732k
 99  652M   99  651M    0     0   870k      0  0:12:47  0:12:46  0:00:01  815k
100  652M  100  652M    0     0   870k      0  0:12:47  0:12:47 --:--:--  904k
  -> Found anaconda.install
    Anaconda3-2018.12-Linux-x86_64.sh ... Passed
    anaconda.install ... Passed
==> Extracting sources...
==> Starting prepare()...
  -> Patching Anaconda3-2018.12-Linux-x86_64.sh
==> Entering fakeroot environment...
==> Starting package()...
  -> Installing anaconda to /opt/anaconda
PREFIX=/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda
installing: python-3.7.1-h0371630_7 ...
Python 3.7.1
installing: blas-1.0-mkl ...
installing: ca-certificates-2018.03.07-0 ...
installing: conda-env-2.6.0-1 ...
installing: intel-openmp-2019.1-144 ...
installing: libgcc-ng-8.2.0-hdf63c60_1 ...
installing: libgfortran-ng-7.3.0-hdf63c60_0 ...
installing: libstdcxx-ng-8.2.0-hdf63c60_1 ...
installing: bzip2-1.0.6-h14c3975_5 ...
installing: expat-2.2.6-he6710b0_0 ...
installing: fribidi-1.0.5-h7b6447c_0 ...
installing: gmp-6.1.2-h6c8ec71_1 ...
installing: graphite2-1.3.12-h23475e2_2 ...
installing: icu-58.2-h9c2bf20_1 ...
installing: jbig-2.1-hdba287a_0 ...
installing: jpeg-9b-h024ee3a_2 ...
installing: libffi-3.2.1-hd88cf55_4 ...
installing: liblief-0.9.0-h7725739_1 ...
installing: libsodium-1.0.16-h1bed415_0 ...
installing: libtool-2.4.6-h7b6447c_5 ...
installing: libuuid-1.0.3-h1bed415_2 ...
installing: libxcb-1.13-h1bed415_1 ...
installing: lz4-c-1.8.1.2-h14c3975_0 ...
installing: lzo-2.10-h49e0be7_2 ...
installing: mkl-2019.1-144 ...
installing: ncurses-6.1-he6710b0_1 ...
installing: openssl-1.1.1a-h7b6447c_0 ...
installing: patchelf-0.9-he6710b0_3 ...
installing: pcre-8.42-h439df22_0 ...
installing: pixman-0.34.0-hceecf20_3 ...
installing: snappy-1.1.7-hbae5bb6_3 ...
installing: xz-5.2.4-h14c3975_4 ...
installing: yaml-0.1.7-had09818_2 ...
installing: zlib-1.2.11-h7b6447c_3 ...
installing: blosc-1.14.4-hdbcaa40_0 ...
installing: glib-2.56.2-hd408876_0 ...
installing: hdf5-1.10.2-hba1933b_1 ...
installing: libedit-3.1.20170329-h6b74fdf_2 ...
installing: libpng-1.6.35-hbc83047_0 ...
installing: libssh2-1.8.0-h1ba5d50_4 ...
installing: libtiff-4.0.9-he85c1e1_2 ...
installing: libxml2-2.9.8-h26e45fe_1 ...
installing: mpfr-4.0.1-hdf1c602_3 ...
installing: pandoc-1.19.2.1-hea2e7c5_1 ...
installing: readline-7.0-h7b6447c_5 ...
installing: tk-8.6.8-hbc83047_0 ...
installing: zeromq-4.2.5-hf484d3e_1 ...
installing: zstd-1.3.7-h0b5b093_0 ...
installing: dbus-1.13.2-h714fa37_1 ...
installing: freetype-2.9.1-h8a8886c_1 ...
installing: gstreamer-1.14.0-hb453b48_1 ...
installing: krb5-1.16.1-h173b8e3_7 ...
installing: libarchive-3.3.3-h5d8350f_5 ...
installing: libxslt-1.1.32-h1312cb7_0 ...
installing: mpc-1.1.0-h10f8cd9_1 ...
installing: sqlite-3.26.0-h7b6447c_0 ...
installing: unixodbc-2.3.7-h14c3975_0 ...
installing: fontconfig-2.13.0-h9420a91_0 ...
installing: gst-plugins-base-1.14.0-hbbd80ab_1 ...
installing: libcurl-7.63.0-h20c2e04_1000 ...
installing: alabaster-0.7.12-py37_0 ...
installing: asn1crypto-0.24.0-py37_0 ...
installing: atomicwrites-1.2.1-py37_0 ...
installing: attrs-18.2.0-py37h28b3542_0 ...
installing: backcall-0.1.0-py37_0 ...
installing: backports-1.0-py37_1 ...
installing: beautifulsoup4-4.6.3-py37_0 ...
installing: bitarray-0.8.3-py37h14c3975_0 ...
installing: boto-2.49.0-py37_0 ...
installing: cairo-1.14.12-h8948797_3 ...
installing: certifi-2018.11.29-py37_0 ...
installing: chardet-3.0.4-py37_1 ...
installing: click-7.0-py37_0 ...
installing: cloudpickle-0.6.1-py37_0 ...
installing: colorama-0.4.1-py37_0 ...
installing: contextlib2-0.5.5-py37_0 ...
installing: curl-7.63.0-hbc83047_1000 ...
installing: dask-core-1.0.0-py37_0 ...
installing: decorator-4.3.0-py37_0 ...
installing: defusedxml-0.5.0-py37_1 ...
installing: docutils-0.14-py37_0 ...
installing: entrypoints-0.2.3-py37_2 ...
installing: et_xmlfile-1.0.1-py37_0 ...
installing: fastcache-1.0.2-py37h14c3975_2 ...
installing: filelock-3.0.10-py37_0 ...
installing: future-0.17.1-py37_0 ...
installing: glob2-0.6-py37_1 ...
installing: gmpy2-2.0.8-py37h10f8cd9_2 ...
installing: greenlet-0.4.15-py37h7b6447c_0 ...
installing: heapdict-1.0.0-py37_2 ...
installing: idna-2.8-py37_0 ...
installing: imagesize-1.1.0-py37_0 ...
installing: importlib_metadata-0.6-py37_0 ...
installing: ipython_genutils-0.2.0-py37_0 ...
installing: itsdangerous-1.1.0-py37_0 ...
installing: jdcal-1.4-py37_0 ...
installing: jeepney-0.4-py37_0 ...
installing: kiwisolver-1.0.1-py37hf484d3e_0 ...
installing: lazy-object-proxy-1.3.1-py37h14c3975_2 ...
installing: llvmlite-0.26.0-py37hd408876_0 ...
installing: locket-0.2.0-py37_1 ...
installing: lxml-4.2.5-py37hefd8a0e_0 ...
installing: markupsafe-1.1.0-py37h7b6447c_0 ...
installing: mccabe-0.6.1-py37_1 ...
installing: mistune-0.8.4-py37h7b6447c_0 ...
installing: mkl-service-1.1.2-py37he904b0f_5 ...
installing: mpmath-1.1.0-py37_0 ...
installing: msgpack-python-0.5.6-py37h6bb024c_1 ...
installing: numpy-base-1.15.4-py37hde5b4d6_0 ...
installing: olefile-0.46-py37_0 ...
installing: pandocfilters-1.4.2-py37_1 ...
installing: parso-0.3.1-py37_0 ...
installing: pep8-1.7.1-py37_0 ...
installing: pickleshare-0.7.5-py37_0 ...
installing: pkginfo-1.4.2-py37_1 ...
installing: pluggy-0.8.0-py37_0 ...
installing: ply-3.11-py37_0 ...
installing: prometheus_client-0.5.0-py37_0 ...
installing: psutil-5.4.8-py37h7b6447c_0 ...
installing: ptyprocess-0.6.0-py37_0 ...
installing: py-1.7.0-py37_0 ...
installing: py-lief-0.9.0-py37h7725739_1 ...
installing: pycodestyle-2.4.0-py37_0 ...
installing: pycosat-0.6.3-py37h14c3975_0 ...
installing: pycparser-2.19-py37_0 ...
installing: pycrypto-2.6.1-py37h14c3975_9 ...
installing: pycurl-7.43.0.2-py37h1ba5d50_0 ...
installing: pyflakes-2.0.0-py37_0 ...
installing: pyodbc-4.0.25-py37he6710b0_0 ...
installing: pyparsing-2.3.0-py37_0 ...
installing: pysocks-1.6.8-py37_0 ...
installing: python-libarchive-c-2.8-py37_6 ...
installing: pytz-2018.7-py37_0 ...
installing: pyyaml-3.13-py37h14c3975_0 ...
installing: pyzmq-17.1.2-py37h14c3975_0 ...
installing: qt-5.9.7-h5867ecd_1 ...
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/.install.py", line 617, in <module>
    main2()
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/.install.py", line 598, in main2
    link_dist(opts.link_dist)
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/.install.py", line 453, in link_dist
    link(prefix, dist, linktype)
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/.install.py", line 373, in link
    create_meta(prefix, dist, info_dir, meta)
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/.install.py", line 233, in create_meta
    json.dump(meta, fo, indent=2, sort_keys=True)
  File "/tmp/pamac-build/anaconda/pkg/anaconda/opt/anaconda/pkgs/python-3.7.1-h0371630_7/lib/python3.7/json/__init__.py", line 180, in dump
    fp.write(chunk)
OSError: [Errno 28] No space left on device
==> ERROR: A failure occurred in package().
    Aborting...
#17
it worked, thank you!
