Hello !
Since the last 10 days, i started to experience random crashes :
the screen turns black but the led on the power button stays on
the pc reboots by itself
I updated BIOS, but nothing changed.
Here are my specs :
Software :
Manjaro 21.1.0
Testing branch
KDE Plasma 5.22.3
Noyau 5.10.50-1
X11
Hardware :
Ryzen 7 PRO 4750U
16 go RAM
Vega 7
Fabby
21 July 2021 11:36
2
Switch to the stable branch
Install an LTS (Long Time Support) kernel on top of the existing kernel. (don’'t remove kernels you need before you install a new one)
If that doesn’t help, please read this first:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the trees for the wood any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
After you’ve read all of the above, backup all your data and reinstall with all the knowledge you now have due to the other problems you’ve had so far…
Thanks for the answer !
I switched to the stable branch, and was already on a LTS kernel…
So no other solution than reinstalling ?
Fabby
21 July 2021 11:45
4
TBH: reading the N00b tutorial and doing a clean install without trying to use weird themes, applications from source, and applying the kernel parameters from your other posts would be the prudent thing to do…
KISS! (Keep It Simply Stupid)
and before you post your next question, please read this too:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Bonne chance et désolé!
Well i reinstalled Manjaro, and the bug is still here
Kernel: 5.10.47-1-rt46-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=acefd849-e868-4199-ae2d-b21eece66296 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20Y1CTO1WW v: ThinkPad P14s Gen 1
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20Y1CTO1WW serial: <filter> UEFI: LENOVO
v: R1BET65W(1.34 ) date: 06/17/2021
ID-1: BAT0 charge: 48.1 Wh (93.4%) condition: 51.5/50.5 Wh (101.9%)
volts: 12.6 min: 11.6 model: LGC 5B10W139 type: Li-poly serial: <filter>
status: Discharging cycles: 57
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 13.45 GiB used: 2.84 GiB (21.1%)
Info: 8-Core model: AMD Ryzen 7 PRO 4750U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L2: 4 MiB bogomips: 54319
Speed: 1470 MHz min/max: 1400/1700 MHz boost: enabled Core speeds (MHz):
1: 1470 2: 2111 3: 1257 4: 1287 5: 1811 6: 1929 7: 1288 8: 1267 9: 1755
10: 1457 11: 1652 12: 1802 13: 1697 14: 1973 15: 1271 16: 1327
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 07:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-2:2
chip-ID: 04f2:b6d0 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.47-1-rt46-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.47-1-rt46-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3400 bus-ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 6-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 53.63 GiB (11.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GD9TNI-L2B0B
lanes: 4 type: SSD serial: <filter> rev: 11720C10 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 53.63 GiB (11.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: acefd849-e868-4199-ae2d-b21eece66296
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2626-7A44
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 2-2:2 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6d0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 4-2:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 6-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.1 C mobo: 0.0 C gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): cpu: 0
Processes: 320 Uptime: 11m wakeups: 5 Init: systemd v: 248 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1199 lib: 326 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: yakuake inxi: 3.3.06
Fabby
27 July 2021 07:44
7
