I run an unpdated Manjaro I3 Linux from an USB card (can’t install on hard drive due to it being a business laptop, but I can boot from USB and it’s not a live distribution: it’s a complete installation). This Linux version has been installed specifically on the machine I use, so driver-wise we should be fine, but alsa had all sorts of bizarre behaviors. Sometimes the sound just wouldn’t work, other times it would work but have a very grainy quality, it was horrible. So I followed a few guides online, suggesting to install pulse, uninstall alsa, no wait, install alsa, but add this kernel parameter on boot, never mind that, remove the parameter, reinstall alsa. And voila’, within 5 minutes, the sound just stopped working. All I can understand is that now alsa thinks that my sound card is not compatible and the list of sinks available is EMPTY.
I think I have undone every single step - beginning of course with removing the extra kernel parameter - but the audio now just does not work. I spent hours on this and I am at the end of my wits. I hate how stupidly convoluted the sound system is on Linux, alsa and pulseaudio and all of that crap. I have used Linux for over 20 years and the audio system is still a black box to me. Please help.
Context:
[niki@usbdisk-i3 ~]$ sudo dmesg | grep -C1 -E 'ALSA|HDA|HDMI|snd[_-]|sound|hda.codec|hda.intel'
[ 0.195026] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.195026] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.195026] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 8.318587] hidraw: raw HID events driver (C) Jiri Kosina
[ 8.452400] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 8.452717] i2c_hid i2c-ELAN9008:00: i2c-ELAN9008:00 supply vdd not found, using dummy regulator
[ 8.649742] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[ 8.649881] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 8.657500] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 8.764760] AES CTR mode by8 optimization enabled
[ 8.827356] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 8.827361] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 8.827363] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 8.827365] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 8.827367] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 8.827369] snd_hda_codec_realtek hdaudioC0D0: Headset Mic=0x19
[ 8.827371] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 8.830081] asus_wmi: ASUS WMI generic driver loaded
[ 9.181762] mousedev: PS/2 mouse device common for all mice
[ 9.321844] input: HDA Intel PCH Headset Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 9.321887] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 9.321922] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 9.321961] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 9.321995] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 9.322028] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 9.322064] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 11.941960] mc: Linux media interface: v0.10
Hey @darioshanghai
At least you could start with some value information:
sudo inxi -Fazy
Please… use markdown for formatting the code like this:
code
I get eye cancer from this above.
Many apologies for your eyes, didn’t understand the editor. Fixed, hopefully. Here is the command you asked:
[niki@usbdisk-i3 ~]$ sudo inxi -Fazy
[sudo] password for niki:
Kernel: 5.4.85-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=a72c70ad-5aa2-4549-9d8d-303d1fa3ff38 rw quiet apparmor=1
Desktop: i3 4.19 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Convertible System: ASUSTeK product: ZenBook UX362FA_UX362FA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX362FA v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX362FA.304 date: 07/04/2019
ID-1: BAT0 charge: 44.3 Wh condition: 44.3/50.0 Wh (89%) volts: 11.9/11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
cycles: 259
Device-1: hid-0018:04F3:284E.0004-battery model: ELAN9008:00 04F3:284E
serial: N/A charge: N/A status: N/A
Device-2: hid-34:88:5d:c6:a5:66-battery model: Keyboard K380 serial: N/A
charge: N/A status: Discharging
Info: Dual Core model: Intel Core i3-8145U socket: BGA1528 (U3E1)
note: check bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: DE L1 cache: 128 KiB
L2 cache: 4 MiB L3 cache: 3.9 MiB
bogomips: 18406
Speed: 1800 MHz min/max: 400/3900 MHz base/boost: 2574/8300 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 1800 2: 1800 3: 1806 4: 1802
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 13d3:56cb serial: <filter>
Display: server: X.Org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.4.85-1-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 3000 bus ID: 00:14.3 chip ID: 8086:9df0
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 2-1.3:4 chip ID: 0bda:8153 serial: <filter>
IF: enp0s20f0u1u3 state: down mac: <filter>
Local Storage: total: 548.54 GiB used: 20.2 GiB (3.7%)
model: PC SN520 SDAPNUW-512G-1002 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
rev: 20110000
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Ultra Fit
size: 57.28 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00
ID-1: / raw size: 56.98 GiB size: 55.84 GiB (97.99%) used: 20.2 GiB (36.2%)
fs: ext4 block size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat block size: 512 B dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3500
Processes: 190 Uptime: 12m wakeups: 11 Memory: 7.57 GiB
used: 1.97 GiB (26.0%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1190 lib: 374 Shell: Bash (sudo) v: 5.1.0 running in: urxvtd
inxi: 3.2.01
@darioshanghai
I guess you are one of the lucky ones who are able to use the sof-firmware: Platforms — SOF Project 0.1 documentation
Install sof-firmware
blacklist snd_hda_intel
and snd_soc_skl
if needed
Make snd_sof_pci
load first.
The reason for not loading snd_sof_pci
is maybe because of the kernels decision to load snd_hda_intel
first, because it has wider support than sof. On newer Kernels than 5.4 it should use sof first.
Here for example on kernel 5.10 it loads snd_sof_pci
first:
[wendy@ThinkPad-X13 ~]$ inxi -Aazy
Device-1: Intel vendor: Lenovo driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:02c8
Sound Server: ALSA v: k5.10.2-2-MANJARO
But well, the sof-firmware
was not installed and sound did not work because of this.
Well, we have progress! I could blacklist those modules, and it loaded sof-audio instead. Unfortunately we’re still silent, and we still seem to have no audio sinks.
Should I try and update my Kernel? I am happy with the Stable version, this is the only issue I have. Or else, what?
kernel v5.4 does not support this type of digital array microphone and sof-firmware
kernel support for sof-firmware was only added about 12 months ago with kernel v5.7 and later
so you should go Manjaro Settings Manager
manjaro-settings-manager -m msm_kernel
and install kernel 5.10.4-2
and also remove any blacklist options that may have been added before
When you boot system with new kernel, it should load snd_soc_skl
instead of snd_hda_intel
driver and internal microphone should work
Simply blacklisting didn’t work. Had to update the kernel as suggested, and then the blacklisting became unnecessary. Sadly, the quality of the sound is still far from ideal.
Thank you folks!
Two things that may help improve audio quality
1 - PulseAudio only runs at CD quality (16bits @44100Hz ) by default, for backwards compatibility to old hardware.
But modern hardware can support DVD quality audio (24bits @48000Hz )
to reconfigure PulseAudio for DVD quality, copy this whole code block to terminal
cat <<EOT > ~/.config/pulse/daemon.conf
resample-method = speex-float-3
default-sample-format = s24le
default-sample-rate = 48000
EOT
then restart PulseAudio
systemctl --user restart pulseaudio
to check if the new configuration is in use and settings have been applied
pulseaudio --dump-conf
2 - You may want to Install pulseaudio-equalizer-ladspa
to add some boost bass for audio to laptop speakers
system
Closed
January 31, 2021, 9:02am
#10
