No sound through headphones after update; audio playing according to pavucontrol
I just updated my system (mostly audio related packages). Now, although pavucontrol shows audio as normal, with bobbers moving, nothing plays through the wired headphones; if I play through speakers, it works.
➜  ~ inxi -A
  Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 0.3.70 status: active
➜  ~ amixer --card=0
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Playback channels: Mono
  Limits: Playback 0 - 127
  Mono: Playback 81 [64%] [-23.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 127 [100%] [0.00dB] [on]
  Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Headphone Mic',0
  Capabilities: pvolume pswitch cswitch cswitch-joined cswitch-exclusive
  Capture exclusive group: 0
  Capture channels: Mono
  Limits: Playback 0 - 31
  Mono: Capture [off]
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Headphone Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Speaker',0
  Mono:
  Front Left: Playback 0 [0%] [-63.50dB] [off]
  Front Right: Playback 0 [0%] [-63.50dB] [off]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Mono: Playback [off]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 127
  Front Left: Capture 104 [82%] [18.50dB] [on]
  Front Right: Capture 104 [82%] [18.50dB] [on]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Disabled'
Simple mixer control 'Headset Mic',0
  Mono: Capture [off]
Simple mixer control 'Headset Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Internal Mic',0
  Capabilities: cswitch cswitch-joined cswitch-exclusive
  Mono: Capture [on]
Simple mixer control 'Internal Mic Boost',0
  Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
After trying this through other devices, it seems this is almost certainly a problem with my headphones, not a software issue.
