My Manjaro install upgraded yesterday and after reboot I lost sound output from speaker, wired headphone and bluetooth. I only have Manjaro Linux in my laptop (no duel boot).
I had kernel 5.9.16-1 even after update. I manually upgraded to 5.10.59-1 today with no luck getting back sound.
When I run
inxi -Faz
I get this
System: Kernel: 5.10.59-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=01e6c1d9-5825-4b3c-b03d-96752433aa3e ro
nouveau.modset=0 quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ZenBook UX434DA_UM433DA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: UX434DA v: 1.0 serial: <filter> UEFI: American Megatrends v: UX434DA_UM433DA.302
date: 09/05/2019
Battery: ID-1: BAT0 charge: 41.8 Wh (100.0%) condition: 41.8/50.0 Wh (83.7%) volts: 11.9 min: 11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging cycles: 82
CPU: Info: Quad Core model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 36751
Speed: 1294 MHz min/max: 1400/2300 MHz boost: enabled Core speeds (MHz): 1: 1294 2: 1486 3: 1209 4: 1177 5: 1213
6: 1177 7: 1359 8: 1174
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo bus-ID: 3-2:3 chip-ID: 13d3:56cb
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0 5.10.59-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Advanced Micro D![audio settings|689x482, 75%](upload://sOiP2RfPWx9fNlWP8ttDEBuUDyw.png)
evices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 43.07 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GDJTNG-8310A size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: 80001C00 temp: 42.9 C
scheme: GPT
Partition: ID-1: / raw-size: 50 GiB size: 48.97 GiB (97.93%) used: 21.56 GiB (44.0%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 410.44 GiB size: 403 GiB (98.19%) used: 21.51 GiB (5.3%) fs: ext4 dev: /dev/nvme0n1p4
maj-min: 259:4
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 60.6 C mobo: 60.0 C gpu: amdgpu temp: 60.0 C
Fan Speeds (RPM): cpu: 2800
Info: Processes: 256 Uptime: 11m wakeups: 464 Memory: 13.67 GiB used: 2.6 GiB (19.0%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1410 pacman: 1403 lib: 401 flatpak: 0 snap: 7 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.06
I noticed in my system settings for audio, the Audio Controller profile simply has “Off” with nothing else to chose for. To be honest I never checked it before if there was a profile set
