Hello good night.
I want to ask for some suggestions to fix the sound that is not there or maybe even not working on my laptop. I’ve followed some suggestions and tutorials from various people and sources but it’s still not working. maybe i missed something? I beg you from this post I find answers to the problems that occur. thank you.
Welcome to Manjaro forum
If you can explain in more detail what you have already tried it will save time repeating the same things again
Please post system information
inxi -Fazy
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=453b9c68-2bf5-41f7-bb40-6662ecc44f34 rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Acer product: One Z1402 v: V1.07 serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Acer model: One Z1402 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1.7 date: 11/02/2015
ID-1: BAT0 charge: 3.5 Wh (81.4%) condition: 4.3/23.8 Wh (18.2%) volts: 12.1
min: 10.8 model: standard type: Li-ion serial: <filter> status: Discharging
Info: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
L2: 3 MiB
bogomips: 15968
Speed: 799 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 799 2: 799 3: 807
4: 817
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Tongfang Hongkong Limited
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Acer VGA Webcam type: USB driver: uvcvideo bus-ID: 2-7:3
chip-ID: 5986:065e class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 112 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Tongfang Hongkong Limited driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: 3000
bus-ID: 02:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0f1 state: down mac: <filter>
IF-ID-1: wlp0s20u1i2 state: up mac: <filter>
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 2-1:2 chip-ID: 0bda:b720 class-ID: e001
serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 9.93 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-21VHAT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 201.75 GiB size: 197.52 GiB (97.91%) used: 9.93 GiB (5.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 236 Uptime: 23h 21m wakeups: 6 Memory: 3.75 GiB
used: 1.76 GiB (46.9%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1043 pacman: 1036 lib: 288 snap: 7 Shell: Bash
v: 5.1.8 running-in: urxvtd inxi: 3.3.06
[rockefellers@rockefellers-enggarukei ~]$
this is the output, is there a mistake?
You have 2 sound devices detected.
Being lazy why research them, you tell us which one you want sound out of please.
if you install pavucontrol and execute
pavucontrol
and go the far right ConfigurationTAB your options are:
disable HDMI often its the top one
to laptop speakers, often the bottom one, choose Analog stereo duplux
or
for top one, choose some kind of digital surround sound out and
turn off analog sound
the go to Output Devices TAB
if the volume slider is faint you need to unmute by clicking the mute/unmute button at top, third from the right.
You can also adjust volumes with media players like vlc
good luck
thnks u i will try this
Check if package pulseaudio-alsa
is installed
Manjaro i3 can have a problem when installing PulseAudio that additional package pulseaudio-alsa
is not installed (a recommended optional dependency)
The package creates the ALSA configuration for PulseAudio to be default instead of a specific hardware device
If the package is installed and audio is not working, please post more information
pacmd dump
amixer -c1
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 86 [99%] [-0.75dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 31 [100%] [12.00dB] [off]
Front Right: Playback 31 [100%] [12.00dB] [off]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Beep',0
Mono:
Front Left: Playback 12 [39%] [-16.50dB] [off]
Front Right: Playback 12 [39%] [-16.50dB] [off]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic',0
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
this is the output when i run it amixer -c1
but when I run pacmd dump
the output that comes out is
Neither PulseAudio daemon is running, nor is it running as a session daemon.
