I’m getting absolutely no sound on my new xfce install. And I’m not seeing any solutions from the recommend similar threads. The closest thing I could find is a kernel patch to an outdated kernel version from last year(v5.13),
Well, it wouldn’t; you are listing your soundcards there, not installed software. Wanted to know whether or not the device exists at the Pulseaudio level.
However. Google-Fu is urging to try something else: after potentially sudo pacman -S downgrade if you don’t have it installed already, and using
sudo DOWNGRADE_FROM_ALA=1 downgrade sof-firmware
to downgrade sof-firmware to 2.1.1a and rebooting once more, do you then have sound?
Nah, crap. We may need to eventually look at sudo dmesg >~/dmesg.out but I then for now have only fairly lame advise to try a newer kernel and see if anything’s fixed. You can install e.g. 6.0.8-1 easily from Manjaro Settings Manager → Kernel. You’ll again need to reboot when installing a new kernel.
I’d by the way also update sof-firmware again now that that didn’t help; sudo pacman -Sy sof-firmware
No, if uname -a now says you’re on 6.0.8 you’re good. And, yes, that command certainly did return something, specifically, the file dmesg (or dmesg.out if you used my version) in your home-directory which now consists of the kernel’s startup information and supposedly/maybe then information as to why your sound is crapping out.
Not sure I’m going to be helpful now that the low-hanging fruit’s gone but if you want you can attach that mentioned file to this post (or if it’s too big, post it on some kind of pastebin online for us to look at). If you do, look through it first for any potential privacy matters.
That dmesg is from kernel 5.15.60-1 so just to be sure: uname -a now tells you you’re on 6.0.8-1?
There’s in any case nothing of interest in there regarding audio – except then that it seems all’s in fact fine. As such I will again need to ask if e.g. pactl list cards shows the “HDA Intel” card. And/or whether or not you see the Pulseaudio plugin on your systray (the speaker icon) and if the card’s shown if you click that.
I’ve seen others suggest to try and have just one of Pulseaudio and Pipewire running. You have both – but I also have and this should be fine.
Does speaker-test -D hw:0 -c 2 -t sine -l 1 produce sound? (a sine first on one, then the other channel).
If not; does alsamixer -c 0 show all volumes not zero and no channels muted, i.e., all with a “OO” in green under the sliders as in the attached example?
Still not seeing any issue and fairly specifically not seeing any issue that would keep Pulseaudio from providing you with a fully functional Pulseaudio plugin complete with e.g. volume controls when clicked in the systray – which you appear to say you did not have.
Please confirm: no controls visible from clicking the speaker icon in the systray? No possibility to from there go to the “audio mixer”?
