Hello, I’m having issues with Manjaro. After a reboot (I didn’t install any new packages as far as I remember)
Here’s the output of inxi -Fazy
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=759c5942-a42f-4370-bfe8-fa4cfa3281e8 rw quiet splash apparmor=1
security=apparmor resume=UUID=781fe0ae-7244-4c2d-b4e0-3ef218bf3d2a
udev.log_priority=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81UH v: Lenovo Legion Y740-15IRHg
serial: <filter> Chassis: type: 10 v: Lenovo Legion Y740-15IRHg
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: BVCN11WW(V1.07) date: 07/04/2019
ID-1: BAT1 charge: 44.3 Wh condition: 48.7/57.4 Wh (85%) volts: 13.0/11.6
model: Celxpert L17C3PG2 type: Li-ion serial: <filter> status: Charging
Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 12.0 MiB
bogomips: 62431
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 1068 2: 910
3: 903 4: 991 5: 907 6: 1377 7: 934 8: 950 9: 907 10: 903 11: 905 12: 909
Type: l1tf
Device-1: NVIDIA TU106BM [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f51
Device-2: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo
bus ID: 1-7:4 chip ID: 04f2:b604 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f9
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Wireless-AC 9560 [Jefferson Peak]
vendor: Bigfoot Networks Killer driver: iwlwifi v: kernel bus ID: 00:14.3
chip ID: 8086:a370
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 3f:00.0
chip ID: 10ec:8168
IF: enp63s0 state: down mac: <filter>
IF-ID-1: br-6d3840142d80 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 19.12 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HALR-000L2
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 5L1QEXA7 scheme: MBR
ID-1: / raw size: 919.45 GiB size: 904.02 GiB (98.32%)
used: 19.12 GiB (2.1%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2
System Temperatures: cpu: 60.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 314 Uptime: 16m Memory: 31.28 GiB used: 3.43 GiB (11.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1238 pacman: 1231
lib: 320 flatpak: 0 snap: 7 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.08
And for pa-info
________________
> pulseaudio_ps_do
asdruba+ 1382 4.6 0.0 2265096 18400 ? S<sl 21:59 0:48 /usr/bin/pulseaudio --daemonize=no --log-target=journal
root 6881 0.0 0.0 3144 784 pts/0 S+ 22:16 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1382
________________
> pulseaudio --version
pulseaudio 14.0
________________
> pactl info
________________
> pactl list
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; remixing-produce-lfe = no
; remixing-consume-lfe = no
; lfe-crossover-freq = 0
; flat-volumes = no
; rescue-streams = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 3 Dec 10 22:09 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 4 Dec 10 22:09 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116, 10 Dec 10 22:00 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 11 Dec 10 21:59 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 7 Dec 10 21:59 /dev/snd/pcmC1D11p
crw-rw----+ 1 root audio 116, 6 Dec 10 21:59 /dev/snd/pcmC1D10p
crw-rw----+ 1 root audio 116, 5 Dec 10 21:59 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116, 2 Dec 10 21:59 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 13 Dec 10 21:58 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 12 Dec 10 21:58 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 9 Dec 10 21:58 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 8 Dec 10 21:58 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 33 Dec 10 21:58 /dev/snd/timer
crw-rw----+ 1 root audio 116, 1 Dec 10 21:58 /dev/snd/seq
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Dec 10 21:58 .
lrwxrwxrwx 1 root root 12 Dec 10 21:58 pci-0000:00:1f.3 -> ../controlC0
drwxr-xr-x 3 root root 340 Dec 10 21:58 ..
lrwxrwxrwx 1 root root 12 Dec 10 21:58 pci-0000:01:00.1 -> ../controlC1
________________
> lsof /dev/snd/*
________________
> jacks_do
card=0
numid=19,iface=CARD,name='Headphone Jack'
; type=BOOLEAN,access=r-------,values=1
: values=on
numid=18,iface=CARD,name='Internal Mic Phantom Jack'
: values=on
numid=17,iface=CARD,name='Mic Jack'
: values=off
numid=20,iface=CARD,name='Speaker Phantom Jack'
: values=on
card=1
numid=25,iface=CARD,name='HDMI/DP,pcm=10 Jack'
: values=off
numid=31,iface=CARD,name='HDMI/DP,pcm=11 Jack'
: values=off
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=off
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC298 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
HDA NVidia
USB Stream Output
________________
> alsa_info_do
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Fri Dec 11 01:16:43 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: LENOVO
Product Name: 81UH
Product Version: Lenovo Legion Y740-15IRHg
Firmware Version: BVCN11WW(V1.07)
System SKU: LENOVO_MT_81UH_BU_idea_FM_Legion Y740-15IRHg
Board Vendor: LENOVO
Board Name: LNVNB161216
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ELAN0504:01/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT3403:03/status 15
/sys/bus/acpi/devices/INT3403:04/status 15
/sys/bus/acpi/devices/INT3404:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 15
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXPOWER:05/status 1
/sys/bus/acpi/devices/LNXPOWER:06/status 1
/sys/bus/acpi/devices/LNXPOWER:07/status 1
/sys/bus/acpi/devices/MSFT0001:00/status 15
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:00/status 3
/sys/bus/acpi/devices/PNP0C02:01/status 3
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0D:00/status 15
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/VPC2004:00/status 15
/sys/bus/acpi/devices/device:24/status 15
!!Kernel Information
Kernel release: 5.9.11-3-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.11-3-MANJARO
Library version: 1.2.4
Utilities version: 1.2.4
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x9241c000 irq 142
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0x64000000 irq 17
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
Subsystem: Lenovo Device [17aa:3828]
01:00.1 Audio device [0403]: NVIDIA Corporation TU106 High Definition Audio Controller [10de:10f9] (rev a1)
Subsystem: Lenovo Device [17aa:3fee]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC298
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0298
Subsystem Id: 0x17aa383a
Revision Id: 0x100103
No Modem Function Group found
Default PCM:
rates [0x60]: 44100 48000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC298 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x7f, nsteps=0x7f, stepsize=0x01, mute=0
Amp-Out vals: [0x5f 0x5f]
Converter: stream=1, channel=0
PCM:
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Speaker Playback Volume", index=0, device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x04 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x05 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x06 [Audio Output] wcaps 0x411: Stereo
Converter: stream=0, channel=0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Amp-In caps: ofs=0x43, nsteps=0x7f, stepsize=0x01, mute=1
Amp-In vals: [0xc3 0xc3]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In vals: [0x5b 0x5b]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100511: Stereo
SDI-Select: 0
PCM:
rates [0x40]: 48000
formats [0x1]: PCM
Connection: 1
0x25
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Mic Playback Volume", index=0, device=0
Control: name="Mic Playback Switch", index=0, device=0
Control: name="Beep Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=4, ofs=0
Control: name="Beep Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 4
0x18 0x19 0x1a 0x1d
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 1
0x03
Node 0x0e [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Audio Input] wcaps 0x10051b: Stereo Amp-In
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name="Internal Mic Boost Volume", index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00000020: IN
Pin Default 0xb7a60130: [Fixed] Mic at Oth Mobile-In
Conn = Digital, Color = Unknown
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x13 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Pin Default 0x40000000: [N/A] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Node 0x14 [Pin Complex] wcaps 0x40050d: Stereo Amp-Out
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x80 0x80]
Pincap 0x00010010: OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x0c* 0x0d
Node 0x15 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x16 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Speaker Playback Switch", index=0, device=0
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x90170110: [Fixed] Speaker at Int N/A
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Connection: 3
0x0c 0x0d* 0x06
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name="Mic Boost Volume", index=0, device=0
Pincap 0x00003724: IN Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x04a11040: [Jack] Mic at Ext Right
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Connection: 2
0x0c* 0x0d
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4075822d: [N/A] Modem Hand at Ext N/A
Conn = Optical, Color = Purple
DefAssociation = 0x2, Sequence = 0xd
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00000014: OUT Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=150
Node 0x21 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0000001c: OUT HP Detect
Pin Default 0x04211020: [Jack] HP Out at Ext Right
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x0c* 0x0d
Node 0x22 [Audio Selector] wcaps 0x300101: Stereo
Connection: 6
0x18 0x19 0x1a 0x1d 0x0b 0x12*
Node 0x23 [Audio Selector] wcaps 0x300101: Stereo
Connection: 6
0x18 0x19 0x1a* 0x1d 0x0b 0x13
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 2
0x12* 0x13
Node 0x25 [Audio Selector] wcaps 0x300101: Stereo
Connection: 1
0x1f
Codec: Nvidia GPU 93 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0093
Subsystem Id: 0x17aa3fee
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
*Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x08* 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
*Dev 00: PD = 0, ELDV = 0, IA = 0
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=05, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Device: name="HDMI 1", type="HDMI", device=7
Converter: stream=5, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC298 Analog [ALC298 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 0/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0x9241c000 irq 142'
Mixer name : 'Realtek ALC298'
Components : 'HDA:10ec0298,17aa383a,00100103'
Controls : 23
Simple ctrls : 11
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 127
Mono: Playback 95 [75%] [-16.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 127 [100%] [0.00dB] [on]
Front Right: Playback 127 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 0 [0%] [-63.50dB] [off]
Front Right: Playback 0 [0%] [-63.50dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 127
Front Left: Capture 91 [72%] [12.00dB] [on]
Front Right: Capture 91 [72%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
!!-------Mixer controls for card NVidia
Card hw:1 'NVidia'/'HDA NVidia at 0x64000000 irq 17'
Mixer name : 'Nvidia GPU 93 HDMI/DP'
Components : 'HDA:10de0093,17aa3fee,00100100'
Controls : 42
Simple ctrls : 6
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Headphone Playback Volume'
value.0 127
value.1 127
comment {
access 'read write'
type INTEGER
count 2
range '0 - 127'
dbmin -6350
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name 'Headphone Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Speaker Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 127'
dbmin -6350
dbmax 0
dbvalue.0 -6350
dbvalue.1 -6350
control.4 {
iface MIXER
name 'Speaker Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.6 {
iface MIXER
name 'Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.7 {
iface MIXER
name 'Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.8 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.9 {
iface MIXER
name 'Capture Volume'
value.0 91
value.1 91
comment {
access 'read write'
type INTEGER
count 2
range '0 - 127'
dbmin -3350
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.10 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.12 {
iface MIXER
name 'Internal Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.13 {
iface MIXER
name 'Beep Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.14 {
iface MIXER
name 'Beep Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.15 {
iface MIXER
name 'Master Playback Volume'
value 95
comment {
access 'read write'
type INTEGER
count 1
range '0 - 127'
dbmin -6350
dbmax 0
dbvalue.0 -1600
control.16 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.17 {
iface CARD
name 'Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.18 {
iface CARD
name 'Internal Mic Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.19 {
iface CARD
name 'Headphone Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.20 {
iface CARD
name 'Speaker Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.21 {
iface PCM
name 'Playback Channel Map'
value.0 3
value.1 4
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.22 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.23 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write locked'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.38 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.39 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.40 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.41 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.42 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
8250_dw
ac
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
atkbd
battery
bluetooth
bnep
br_netfilter
bridge
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
cmdlinepart
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
evdev
ext4
fb_sys_fops
fixed_phy
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_multitouch
i2c_hid
i2c_i801
i2c_nvidia_gpu
i2c_smbus
i8042
iTCO_vendor_support
iTCO_wdt
ideapad_laptop
idma64
input_leds
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_lpss
intel_lpss_pci
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
ip_tables
iptable_filter
iptable_nat
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libcrc32c
libphy
libps2
llc
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mousedev
msr
mtd
mxm_wmi
nf_conntrack
nf_conntrack_netlink
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nfnetlink
nvidia
nvidia_drm
nvidia_modeset
of_mdio
ofpart
overlay
pcspkr
processor_thermal_device
r8169
rapl
rc_core
realtek
rfcomm
rfkill
rng_core
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
sparse_keymap
spi_nor
squashfs
stp
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
typec
typec_ucsi
ucsi_acpi
ucsi_ccg
usbhid
uvcvideo
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xfrm_algo
xfrm_user
xhci_hcd
xhci_pci
xt_MASQUERADE
xt_addrtype
xt_conntrack
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0xb7a60130
0x13 0x40000000
0x14 0x411111f0
0x17 0x90170110
0x18 0x04a11040
0x19 0x411111f0
0x1a 0x411111f0
0x1d 0x4075822d
0x1e 0x411111f0
0x1f 0x411111f0
0x21 0x04211020
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x585600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[ 0.191410] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.191410] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.191410] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 2.506008] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 2.514905] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.514910] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 2.518352] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ 2.751081] usb 1-14: new full-speed USB device number 5 using xhci_hcd
[ 2.751709] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7
[ 2.751762] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[ 2.751807] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[ 2.751860] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 2.751912] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 2.751954] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
[ 2.766431] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[ 2.805660] 0x000000000000-0x000001000000 : "BIOS"
[ 2.805868] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC298: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 2.805870] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.805872] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.805873] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 2.805874] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 2.805875] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 2.805876] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 2.806642] r8169 0000:3f:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.827952] r8169 0000:3f:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.875195] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[ 2.875245] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ 2.875283] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ 2.892368] usb 1-14: New USB device found, idVendor=8087, idProduct=0aaa, bcdDevice= 0.02
Note I’m able to hear sound through my headphones but I’m not getting any sound from my speakers and I’m not able to use the microphone.
I installed pavucontrol and I noticed that every output appears as unavailable, like
Salida digital Surround HDMI (unplugged) (unavailable)
Any help will be very appreciated ![]()
