hello everyone.
i’m new to manjaro and i have some issue with audio.
i have no sound on speakers and plugged headphone via jack but i have sound with my wireless headphone.
i apply some of tips but they failed.
my inxi output:
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b6ecf08e-b147-45f5-8e40-481c6dc1a25b rw quiet apparmor=1
security=apparmor resume=UUID=41065a63-06ec-4758-b39d-c05d8cc73177
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook 15_ASUS Laptop X542UF v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X542UF v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X542UF.306 date: 05/22/2019
ID-1: BAT0 charge: 18.2 Wh (100.0%) condition: 18.2/38.0 Wh (48.0%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 921
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1398 high: 1791 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1285 2: 1578 3: 1791
4: 1221 5: 1352 6: 1290 7: 1234 8: 1433 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: ASUSTeK driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:174d class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d5 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.0 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:4
chip-ID: 13d3:3496 class-ID: e001
Local Storage: total: 931.51 GiB used: 98.23 GiB (10.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: SDM4 scheme: GPT
ID-1: / raw-size: 150 GiB size: 146.59 GiB (97.72%) used: 19.07 GiB (13.0%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
used: 27.3 MiB (28.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 43.0 C pch: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 289 Uptime: 45m wakeups: 1 Memory: 11.57 GiB
used: 4.02 GiB (34.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1253
pacman: 1246 lib: 338 flatpak: 0 snap: 7 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
my ALSA settings for audio device:
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Headset Mic',0
Capabilities: cswitch cswitch-joined cswitch-exclusive
Capture exclusive group: 0
Capture channels: Mono
Mono: Capture [off]
Simple mixer control 'Headset Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Internal Mic',0
Mono: Capture [on]
Simple mixer control 'Internal Mic 1',0
Mono: Capture [off]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Internal Mic Boost',1
Limits: 0 - 3
Any help would be appreciated.
