Hi, so I am having some problem with my sound on my Legion 7. I tried to update my kernel to 5.15 but that did not help. The sound will work on my BT headphones. and I can see that my PC picks up sound from firefox as I can see the soundbar moving in the settings window.
~ inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.15.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=333f6e70-9683-450e-ac01-16ab6d323b1f rw quiet
cryptdevice=UUID=394675e1-92c4-48c6-901d-592f7f77b906:luks-394675e1-92c4-48c6-901d-592f7f77b906
root=/dev/mapper/luks-394675e1-92c4-48c6-901d-592f7f77b906 splash apparmor=1
security=apparmor
resume=/dev/mapper/luks-a3aaad29-5fb0-4f44-858b-85d1cb28646a
udev.log_priority=3
Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 82N6 v: Legion 7 16ACHg6
serial: <filter> Chassis: type: 10 v: Legion 7 16ACHg6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: GKCN44WW date: 08/30/2021
ID-1: BAT0 charge: 82.2 Wh (100.0%) condition: 82.2/80.0 Wh (102.7%)
volts: 17.4 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: Full cycles: 6
RAM: total: 15.55 GiB used: 1.69 GiB (10.9%)
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB bogomips: 102241
Speed: 1197 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
1: 1197 2: 1197 3: 1197 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197 9: 1197
10: 1197 11: 1198 12: 1197 13: 1397 14: 1397 15: 1198 16: 1197
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Lenovo driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:24dc class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
chip-ID: 04f2:b67d class-ID: 0e02
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
vendor: Lenovo driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Device-1: luks-394675e1-92c4-48c6-901d-592f7f77b906 maj-min: 254:0
type: LUKS dm: dm-0 size: 215.55 GiB
Components:
p-1: nvme1n1p2 maj-min: 259:2 size: 215.56 GiB
Device-2: luks-a3aaad29-5fb0-4f44-858b-85d1cb28646a maj-min: 254:1
type: LUKS dm: dm-1 size: 17.03 GiB
Components:
p-1: nvme1n1p3 maj-min: 259:3 size: 17.03 GiB
Local Storage: total: 1.16 TiB used: 27.24 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: MZVLB1T0HBLR-000L2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3L1QEXF7 temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211210WD temp: 32.9 C scheme: GPT
ID-1: / raw-size: 215.55 GiB size: 211.11 GiB (97.94%)
used: 27.24 GiB (12.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-394675e1-92c4-48c6-901d-592f7f77b906 label: N/A
uuid: 333f6e70-9683-450e-ac01-16ab6d323b1f
used: 444 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
label: NO_LABEL uuid: D6A5-0689
ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-a3aaad29-5fb0-4f44-858b-85d1cb28646a label: swap
uuid: 994f0f94-75b4-4dd3-9f61-dc273cf1a938
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: EE4F-63E4
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 952.62 GiB fs: ntfs
label: Windows-SSD uuid: EC045016044FE266
ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 729C50999C5059A5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
Device-1: 1-3:3 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b67d
class-ID: 0e02
Device-2: 1-4:4 info: Integrated Express ITE Device(8258) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c968 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic USB3.2 Hub ports: 3 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 335 Uptime: 7m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1253 lib: 406 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.08
What do I need to do to fix this?
