Hello, I’ve been working on this issue for one week. I’m a newbie…I managed to get the sound to work on my HP Spectre X360 with this command lines :
sudo hda-verb /dev/snd/hwC0D0 0x01 SET_GPIO_DIR 0x01
sudo hda-verb /dev/snd/hwC0D0 0x01 SET_GPIO_MASK 0x01
sudo hda-verb /dev/snd/hwC0D0 0x01 SET_GPIO_DATA 0x01
sudo hda-verb /dev/snd/hwC0D0 0x01 SET_GPIO_DATA 0x00
But I have to reintroduce it each time I open another source (browser, program …). I tried to modify the pins with HDA Jack Retask but without success … even after totally killing pulseaudio … Does anyone have a trick that would at least allow me not to have to enter these lines every 2 minutes …
Hello, yes I did. Yesterday I managed to have the script run once only on start up. Unfortunately I had to reinstall my system and today I have the same problem again = I have to run the script whenever I open a new app (example : if I watch a video with Firefox and I close it, then I have to run the script again if I reopen it…)
PS : do you have a file in etc/modprobe.d ? If so, what’s its name and what does it contain ?
