No sound on headphones KDE
Laptop is Asus N551
There are some outputs
[fixxxer@Work ~]$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC668 Analog [ALC668 Analog]
Subdevices: 1/1
and :
System: Host: Work Kernel: 4.13.3-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.10.5 Distro: Manjaro Linux
Machine: Device: laptop System: ASUSTeK product: N551JM v: 1.0 serial: N/A
Mobo: ASUSTeK model: N551JM v: 1.0 serial: N/A
UEFI: American Megatrends v: N551JM.205 date: 02/13/2015
Battery BAT0: charge: 49.6 Wh 97.2% condition: 51.0/56.2 Wh (91%)
CPU: Quad core Intel Core i7-4710HQ (-HT-MCP-) cache: 6144 KB
clock speeds: max: 3500 MHz 1: 2493 MHz 2: 2493 MHz 3: 2493 MHz 4: 2493 MHz 5: 2493 MHz 6: 2493 MHz
7: 2493 MHz 8: 2493 MHz
Graphics: Card-1: Intel 4th Gen Core Processor Integrated Graphics Controller
Card-2: NVIDIA GM107M [GeForce GTX 860M]
Display Server: N/A driver: intel tty size: 131x32
Audio: Card-1 Intel 8 Series/C220 Series High Definition Audio Controller driver: snd_hda_intel
Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.13.3-2-MANJARO
Network: Card-1: Intel Wireless 7260 driver: iwlwifi
IF: wlp4s0 state: up mac: 48:51:b7:2c:84:77
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8168
IF: enp5s0f1 state: down mac: 78:24:af:ca:ba:60
Drives: HDD Total Size: 1144.3GB (1.6% used)
ID-1: /dev/sda model: HGST_HTS541010A9 size: 1000.2GB
ID-2: /dev/sdb model: Samsung_SSD_650 size: 120.0GB
ID-3: /dev/sdc model: KINGSTON_SMSM150 size: 24.0GB
Partition: ID-1: / size: 45G used: 11G (26%) fs: ext4 dev: /dev/sdb6
ID-2: swap-1 size: 6.80GB used: 0.00GB (0%) fs: swap dev: /dev/sdb7
Sensors: System Temperatures: cpu: 52.0C mobo: N/A
Fan Speeds (in rpm): cpu: 1900
Info: Processes: 219 Uptime: 17 min Memory: 2019.1/7870.5MB Init: systemd Client: Shell (bash) inxi: 2.3.39
So the system is dual boot with windows 10. Sound from headphones work only in Win. Speaker sound is ok. Issue is still here after a clean reinstall few minutes ago.
This is my alsamixer:
Any ideas?
do you have additional package installed from AUR - asus-n551-hda-fix?
According to Arch Wiki - Asus N551 only appears to be fix for getting subwoofer working, but may affect other audio settings
Check Pulseaudio Mixer [pavucontrol]
pavucontrol will show audio activity level meter (greyed out if muted)
If pavucontrol shows HDMI set as default playback device, should be drop-down menu to change playback device. can also turn HDMI '“Off” in pavucontrol Configuration tab to force use of only onboard analog
Does pavucontrol show headphones detected as “plugged in” or “unplugged”?
