Hello Everyone!
I bought a used laptop Asus c436 (i5, Comet lake) and have maneged to install Manjaro 36.
So far its working like charm! Only two issues are touchscreen and sound. I had read the posts in the forum, but couldnt get the sound working. I did install sof-firmware (I think so).
I have ALSA Information Script, but somehow cant post it ;(
Any help will be apropriate.
Thanx!
A link to the ALSA information can be posted using preformatted text button</>
Or Ctrl+ E
http://someurl.com
Forum permissions do not allow new users to post active links to prevent spam
but an inactive link is ok
Thanx nikgnomic! Let me try to post it:
(http://alsa-project.org/db/?f=7fa78b6c1495b9db7cfb2cf53185fcd5ae582090)
So, no one have any suggestions?
post system info:
inxi -Faz
Hello brahma, hier is the info from inxi - Faz
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=411e6129-dcfc-4a32-891d-0f20e5570598 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Google product: Helios v: rev3
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Google model: Helios v: rev3 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 30.8 Wh (100.0%) condition: 30.8/42.0 Wh (73.3%)
volts: 12.9 min: 11.9 model: AS2GVUb C436-35 type: Li-ion serial: <filter>
status: charging cycles: 84
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 866 high: 900 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 900 3: 900 4: 900
5: 900 6: 900 7: 832 8: 800 bogomips: 33615
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:2 chip-ID: 13d3:56d4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x623d built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
bus-ID: 1-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.14 TiB used: 8.72 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-256G-1202 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 20200000 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: ASUS model: ROG ESD-S1C
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 8.72 GiB
(3.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 43.0 C pch: 39.0 C mobo: N/A
Processes: 241 Uptime: 11m wakeups: 44418 Memory: 15.5 GiB used: 2.03 GiB
(13.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1171 lib: 316
flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
edit your post and use formatting - click this icon in editor: </>
and copy the output there
Done. Thanx brahma, so looks less paintfull for the eyes
try switching to pipewire:
pamac install manjaro-pipewire wireplumber sof-firmware
it will give you pulse dependency issues, so remove them first, then run the command again;
then install another kernel: go to system settings/kernel and install the 5.19 kernel (dont install the ‘rt’ one);
reboot and check audio
Excuses for the late answer, but after following your advice the system whent to upgrade about 1.3GB, so it took some time. I think the dependencies were removed automaticly. I did install the new kernel 5.19.1 (not the rt one), rebooted, and after running again pamac install manjaro-pipewire wireplumber sof-firmware
it gave me this:
~ pamac install manjaro-pipewire wireplumber sof-firmware ✔
Preparing...
Warning: sof-firmware-2.2.1-1 is up to date -- skipping
Warning: wireplumber-0.4.11-4 is up to date -- skipping
Warning: manjaro-pipewire-20220217-2 is up to date -- skipping
Nothing to do.
But still no sound
I forgot to mention that I do have sound from the audio jack and from the bluetooth. But not from the speakers
youre not the only one with this issue …
post output from:
inxi -A
pacman -Qs pulse
ls /etc/modprobe.d
inxi -A
gave this:
Sound Server-1: ALSA v: k5.19.7-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.57 running: yes
pacman -Qs pulse
gave this:
local/lib32-libcanberra 1:0.30+r2+gc0620e4-1
A small and lightweight implementation of the XDG Sound Theme Specification (32-bit)
local/lib32-libpulse 16.1-1
A featureful, general-purpose sound server (32-bit client libraries)
local/libcanberra 1:0.30+r2+gc0620e4-1
local/libpulse 16.1-1
A featureful, general-purpose sound server (client library)
local/pipewire-alsa 1:0.3.57-1.0
Low-latency audio/video router and processor - ALSA configuration
local/pipewire-pulse 1:0.3.57-1.0
Low-latency audio/video router and processor - PulseAudio replacement
local/plasma-pa 5.25.5-1 (plasma)
Plasma applet for audio volume management using PulseAudio
local/pulseaudio-alsa 1:1.2.7.1-1
ALSA Configuration for PulseAudio
local/pulseaudio-ctl 1.70-1
Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
local/pulseaudio-qt 1.3-1
Qt bindings for libpulse
And ls /etc/modprobe.d
gave nothing at all
remove the pulse leftovers:
pamac remove pulseaudio-alsa pulseaudio-ctl pulseaudio-qt
then create this file:
kate /etc/modprobe.d/audio.conf
and put there this line:
options snd-intel-dspcfg.dsp_driver=1
save the file, reboot and test
Your first command gave this:
~ pamac remove pulseaudio-alsa pulseaudio-ctl pulseaudio-qt ✔
Preparing...
Checking dependencies...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing pulseaudio-qt breaks dependency 'pulseaudio-qt' required by kdeconnect
Should I continue with next commands or I need to uninstall KDE connect (I dont need it)?
if you dont use/need kdeconnect, you can uninstall it … if you use it, keep pulseaudio-qt and remove the 2 other leftovers, then create the file as outlined above, reboot and see if that helped
Done. kdeconnect is gone, followed the 2 commands, rebooted and still no audio.
ls /etc/modprobe.d
~ ls /etc/modprobe.d ✔
audio.conf
Something to mention (if is not important I will delete this post): after rebooting, on the desktop pops that Comet Lake PCH-LP CAVS Stereo is muted (with icon), and after 2-3 sec. is gone and in the systray audio is unmuted (75% volume in my case). Maybe conflict in the boot proces itself? Or the problem is with the BIOS/motherboard and the sound is disabled from the beginning?
as mentioned, you are not the only one that has issues with this hardware…
run this: alsamixer
, press f6, select your card and check if the speakers are not muted…
then try running this:
sudo alsa force-reload
test speakers, if it doesnt work, try this:
amixer -c0 set 'Master',0 100% unmute
amixer -c0 set 'Speaker',0 100% unmute
amixer -c0 set 'Headphone',0 100% unmute
test speakers
I will try with graphics. alsamixer gives:
When pressing F6:
And after choosing default:0 sof-cml… it gives:
Still no audio. But what I see on the 3rd pic - Chip: Intel Kabylake, while I have Cometlake…strange.
And amixer -c0 set ‘Master’,0 100% unmute gives me:
~ amixer -c0 set 'Master',0 100% unmute 1 ✘
amixer: Unable to find simple control 'Master',0
