No sound notification at LogIn
Ciao a tutti,
starting from the last update for Plasma, the sound notification at LogIn is missed, while the sound notification for LogOut still works; into the configuration’s panel for audio notification for Plasmashell, the test for sound works !!
I have also just tried to clean the KDE cache and also rebuild with kbuildsycoca5 --noincremental without success :worried:
Any advice how to solve the problem ?
System sounds in Plasma regardless of that subsetting under notifications have been a joke for a long while. Not Manjaro but Plasma itself on any distro. I went the other day for the first time in a long time to reenable the startup sounds after a KDE dev said that the system has been working again for awhile but the sounds still don’t work.
Thank you Locutus for your advice: also me I believe that the problem is KDE Plasma 5.24.4 because the previous release was OK.
https://bugs.kde.org/show_bug.cgi?id=422948
2022-02-16 00:14:03 UTC
This bug has resurfaced in 5.24.
