Hi,
Since now five months, i have no sound on my CLEVO laptop. I’ve search on Google, try many solutions from Ubuntu, Linux Mint forums.
This is the result of alsa-info.sh :
!!ALSA Information Script v 0.5.0
!!Script ran on: Tue Aug 10 12:30:45 UTC 2021
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Notebook
Product Name: NJ5x_NJ7xLU
Product Version: Not Applicable
Firmware Version: 1.07.06
System SKU: Not Applicable
Board Vendor: Notebook
Board Name: NJ5x_NJ7xLU
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ANX7411:01/status 15
/sys/bus/acpi/devices/CLV0001:00/status 15
/sys/bus/acpi/devices/CLV0002:00/status 15
/sys/bus/acpi/devices/ELAN0412:00/status 15
/sys/bus/acpi/devices/ELAN0412:01/status 15
/sys/bus/acpi/devices/INT0E0C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT33D5:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3455:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/INTC5000:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0A05:00/status 11
/sys/bus/acpi/devices/PNP0B00:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 3
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/device:48/status 15
/sys/bus/acpi/devices/device:8d/status 15
!!Kernel Information
Kernel release: 5.13.8-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.13.8-1-MANJARO
Library version: 1.2.5.1
Utilities version: 1.2.5.1
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - No
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x6001110000 irq 137
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Ice Lake-LP Smart Sound Technology Audio Controller [8086:34c8] (rev 30)
Subsystem: CLEVO/KAPOK Computer Device [1558:8680]
!!Modprobe options (Sound related)
snd_had_intel: model=generic
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Icelake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280f
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled KAE
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x0]:
bits [0x0]:
formats [0x5]: PCM AC3
Power states:
Node 0x04 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
rates [0x0]:
bits [0x0]:
Power states:
Node 0x06 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
rates [0x0]:
bits [0x0]:
Power states:
Node 0x08 [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
rates [0x0]:
bits [0x0]:
Power states:
Node 0x0a [UNKNOWN Widget] wcaps 0x0: Mono
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: N/A
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x00000000: [Jack] Line Out at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Power states: D0 D3 EPSS
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 10 Aug 10 14:25 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 9 Aug 10 14:25 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 6 Aug 10 14:25 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 7 Aug 10 14:25 /dev/snd/pcmC0D11p
crw-rw---- 1 root audio 116, 8 Aug 10 14:25 /dev/snd/pcmC0D12p
crw-rw---- 1 root audio 116, 2 Aug 10 14:25 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 3 Aug 10 14:25 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 4 Aug 10 14:25 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 5 Aug 10 14:25 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 1 Aug 10 14:25 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Aug 10 14:25 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Aug 10 14:25 .
drwxr-xr-x 3 root root 280 Aug 10 14:25 ..
lrwxrwxrwx 1 root root 12 Aug 10 14:25 pci-0000:00:1f.3 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x6001110000 irq 137'
Mixer name : 'Intel Icelake HDMI'
Components : 'HDA:8086280f,80860101,00100000'
Controls : 49
Simple ctrls : 7
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
Simple mixer control 'IEC958',6
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0482000200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=12 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
asn1_encoder
atkbd
blake2s_x86_64
bluetooth
bnep
btbcm
btintel
btrtl
btusb
cbc
ccm
cdrom
cec
cfg80211
chacha_x86_64
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
curve25519_x86_64
dm_crypt
dm_mod
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
encrypted_keys
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
hid_multitouch
i2c_algo_bit
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
intel_cstate
intel_gtt
intel_hid
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_spi
intel_spi_pci
intel_tcc_cooling
intel_uncore
intel_wmi_thunderbolt
ip6_tables
ip6_udp_tunnel
ip6t_REJECT
ip6t_rt
ip6table_filter
ip_tables
ipt_REJECT
iptable_filter
iptable_nat
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
libblake2s
libblake2s_generic
libchacha
libchacha20poly1305
libcrc32c
libcurve25519_generic
libphy
libps2
loop
mac80211
mac_hid
mbcache
mc
mdio_devres
mei
mei_hdcp
mei_me
mmc_core
mousedev
mtd
nf_conntrack
nf_conntrack_broadcast
nf_conntrack_ftp
nf_conntrack_netbios_ns
nf_defrag_ipv4
nf_defrag_ipv6
nf_log_syslog
nf_nat
nf_nat_ftp
nf_reject_ipv4
nf_reject_ipv6
pcspkr
poly1305_x86_64
psmouse
r8169
rapl
realtek
rfcomm
rfkill
rng_core
rtsx_pci
rtsx_pci_sdmmc
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_icl
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
squashfs
sr_mod
syscopyarea
sysfillrect
sysimgblt
tee
tpm
tpm_crb
tpm_tis
tpm_tis_core
trusted
udp_tunnel
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wireguard
wmi
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
xt_LOG
xt_addrtype
xt_conntrack
xt_hl
xt_limit
xt_tcpudp
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[ 0.297763] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.297763] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.297763] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 9.149600] loop: module loaded
[ 9.151337] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 9.151570] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 9.151804] iTCO_vendor_support: vendor-support=0
[ 9.161872] loop1: detected capacity change from 0 to 113544
[ 9.165215] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165220] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165222] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165223] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165224] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165225] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165226] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165227] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165228] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165229] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x000000
[ 9.165409] hdaudio hdaudioC0D0: no AFG or MFG node found
[ 9.166255] loop2: detected capacity change from 0 to 6736
[ 9.242368] hid-multitouch 0018:04F3:3162.0004: input,hidraw3: I2C HID v1.00 Mouse [ELAN0412:01 04F3:3162] on i2c-ELAN0412:01
[ 9.252399] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 9.252437] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 9.252469] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 9.252532] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 9.252592] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 9.252636] input: HDA Intel PCH HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 9.252674] input: HDA Intel PCH HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 9.325950] r8169 0000:01:00.1 enp1s0f1: renamed from eth0
[ 15.794553] Bluetooth: hci0: MSFT filter_enable is already on
[ 16.576304] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to polling mode: last cmd=0x202f8100
[ 16.576317] snd_hdac_bus_update_rirb: 33420 callbacks suppressed
[ 16.576320] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576324] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576326] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576328] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576330] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576332] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576334] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576336] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576338] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 16.576340] snd_hda_intel 0000:00:1f.3: spurious response 0x0:0x0, last cmd=0x0f0004
[ 17.586418] snd_hda_intel 0000:00:1f.3: No response from codec, disabling MSI: last cmd=0x202f8100
[ 17.767815] wlp0s20f3: authenticate with e0:a1:d7:09:04:7c
[ 17.981565] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[ 18.596277] snd_hda_intel 0000:00:1f.3: azx_get_response timeout, switching to single_cmd mode: last cmd=0x202f8100
[ 21.008024] kauditd_printk_skb: 11 callbacks suppressed
Jack is unvailable and when i googled “spurious response 0x0:0x0, last cmd=0x0f0004”, there is few no relevant results in my case.
I’ve tried the kernel 5.13.8-1.
Regards,
Antoine
