No Sound Kde Plasma After Relogging
After randomly relogging sound stopped working, my Headset mic (which was not working before) is now working but it is not detecting the headset as output, i did not update/install manually anything audio related,
inxi -Fazy
  Kernel: 6.0.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    root=UUID=88628962-81d1-4eea-925d-10b686faa467 rw quiet
    cryptdevice=UUID=d2304a60-e7b7-4057-a38f-5a4d0c5f87f0:luks-d2304a60-e7b7-4057-a38f-5a4d0c5f87f0
    root=/dev/mapper/luks-d2304a60-e7b7-4057-a38f-5a4d0c5f87f0
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: ROG Strix G513IE_G513IE v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G513IE v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: G513IE.314 date: 03/30/2022
  ID-1: BAT0 charge: 48.1 Wh (100.0%) condition: 48.1/56.0 Wh (86.0%)
    volts: 17.3 min: 15.9 model: AS3GWZC3KC G513-36 type: Li-ion
    serial: <filter> status: full
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 level: v3 built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1460 high: 1821 min/max: 1400/4299 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1787 2: 1431
    3: 1397 4: 1400 5: 1545 6: 1397 7: 1821 8: 1400 9: 1397 10: 1397 11: 1398
    12: 1397 13: 1400 14: 1400 15: 1397 16: 1397 bogomips: 92666
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
    driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
    (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0300
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
    arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1636
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x004d built: 2019
    res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.48 6.0.0-1-MANJARO) v: 4.6
    Mesa 22.1.7 direct render: Yes
  Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k6.0.0-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.58 running: no
    vendor: ASUSTeK driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
  Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 3-4:2 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Local Storage: total: 942.7 GiB used: 142.37 GiB (15.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
    lanes: 4 type: SSD serial: <filter> rev: 002C temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Samsung model: SSD 980 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 43.9 C scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 142.36 GiB
    (31.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-d2304a60-e7b7-4057-a38f-5a4d0c5f87f0
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 472 KiB
    (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8
  System Temperatures: cpu: 69.1 C mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 340 Uptime: 31m wakeups: 4 Memory: 15.05 GiB used: 4.63 GiB
  (30.8%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: pm: pacman pkgs: 1286 libs: 345
  tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.21
pacmd list
Memory blocks currently allocated: 37, size: 173.0 KiB.
Memory blocks allocated during the whole lifetime: 845793, size: 962.6 MiB.
Memory blocks imported from other processes: 20, size: 56.7 KiB.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 11.5 KiB.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: audiorelay-virtual-mic-sink
Default source name: alsa_input.hw_2_0
Memory blocks of type POOL: 13 allocated/444838 accumulated.
Memory blocks of type POOL_EXTERNAL: 4 allocated/147516 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/147521 accumulated.
Memory blocks of type IMPORTED: 20 allocated/253434 accumulated.
28 module(s) loaded.
    index: 0
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "Lennart Poettering"
                module.description = "Automatically restore the volume/mute state of devices"
                module.version = "16.1"
    index: 1
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Automatically restore the volume/mute/device state of streams"
    index: 2
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Automatically restore profile of cards"
    index: 3
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Augment the property sets of streams with additional static information"
    index: 4
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "David Henningsson"
                module.description = "Switches ports and profiles when devices are plugged/unplugged"
    index: 5
        argument: <device=hw:2,0>
        used: 2
        load once: no
        properties:
                module.description = "ALSA Source"
    index: 6
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Detect available audio hardware and load matching drivers"
    index: 7
        argument: <device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
        used: 0
        load once: no
        properties:
                module.description = "ALSA Card"
    index: 8
        argument: <device_id="1" name="pci-0000_06_00.1" card_name="alsa_card.pci-0000_06_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1">
        used: 0
        load once: no
        properties:
    index: 9
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "Frédéric Dalleau, Pali Rohár"
                module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
    index: 10
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "João Paulo Rechi Vita"
                module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
    index: 11
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
    index: 12
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "Tanu Kaskinen"
                module.description = "D-Bus interface"
    index: 13
        argument: <>
        used: -1
        load once: no
        properties:
                module.description = "Native protocol (UNIX sockets)"
    index: 14
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "Sylvain Baubeau"
                module.description = "GSettings Adapter"
    index: 15
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Automatically restore the default sink and source"
    index: 16
        argument: <>
        used: -1
        load once: yes
        properties:
                module.author = "Colin Guthrie"
                module.description = "Always keeps at least one sink loaded even if it's a null one"
    index: 18
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Automatically set device of streams based on intended roles of devices"
    index: 19
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "When a sink/source is idle for too long, suspend it"
    index: 20
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Create a client for each ConsoleKit session of this user"
    index: 21
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Create a client for each login session of this user"
    index: 22
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
    index: 23
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Mute & cork streams with certain roles while others exist"
    index: 24
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Detect when various filters are desirable"
    index: 25
        argument: <>
        used: -1
        load once: yes
        properties:
                module.description = "Load filter sinks automatically when needed"
    index: 26
        argument: <sink_name=audiorelay-virtual-mic-sink sink_properties=device.description=Virtual-Mic-Sink>
        used: 3
        load once: no
        properties:
                module.description = "Clocked NULL sink"
    index: 27
        argument: <master=audiorelay-virtual-mic-sink.monitor source_name=audiorelay-virtual-mic-sink source_properties=device.description=Virtual-Mic>
        used: 2
        load once: no
        properties:
                module.author = "Stefan Huber"
                module.description = "Virtual channel remapping source"
    index: 28
        argument: <>
        used: -1
        load once: no
        properties:
                module.description = "Command line interface protocol (UNIX sockets)"
1 sink(s) available.
  * index: 1
        driver: <module-null-sink.c>
        flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: RUNNING
        suspend cause: (none)
        priority: 1000
        volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        base volume: 65536 / 100% / 0.00 dB
        volume steps: 65537
        muted: no
        current latency: 7.48 ms
        max request: 1 KiB
        max rewind: 1 KiB
        monitor source: 2
                     Stereo
        used by: 1
        linked by: 3
        configured latency: 7.52 ms; range is 0.50 .. 2000.00 ms
        module: 26
        properties:
                device.description = "Virtual-Mic-Sink"
                device.class = "abstract"
                device.icon_name = "audio-card"
3 source(s) available.
  * index: 0
        driver: <module-alsa-source.c>
        flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: RUNNING
        priority: 9030
                balance 0.00
        volume steps: 65537
        muted: no
        current latency: 0.80 ms
        max rewind: 0 KiB
                     Stereo
        used by: 2
        linked by: 2
        configured latency: 30.00 ms; range is 0.50 .. 1999.82 ms
        module: 5
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "ALC294 Analog"
                alsa.id = "ALC294 Analog"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "2"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xfc5c0000 irq 93"
                device.bus_path = "pci-0000:06:00.6"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card2"
                device.bus = "pci"
                device.vendor.id = "1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                device.product.id = "15e3"
                device.product.name = "Family 17h/19h HD Audio Controller"
                device.string = "hw:2,0"
                device.buffering.buffer_size = "352768"
                device.buffering.fragment_size = "176384"
                device.access_mode = "mmap+timer"
                device.description = "Family 17h/19h HD Audio Controller"
                device.icon_name = "audio-input-microphone-pci"
    index: 2
        state: RUNNING
        priority: 1000
                balance 0.00
        volume steps: 65537
        muted: no
        current latency: 0.00 ms
        max rewind: 1 KiB
                     Stereo
        used by: 1
        linked by: 1
        configured latency: 40.00 ms; range is 0.50 .. 2000.00 ms
        monitor_of: 1
        module: 26
        properties:
                device.description = "Monitor of Virtual-Mic-Sink"
                device.class = "monitor"
    index: 3
        driver: <module-remap-source.c>
        state: RUNNING
        priority: 1000
        volume: front-left: 65537 / 100% / 0.00 dB,   front-right: 65537 / 100% / 0.00 dB
                balance 0.00
        volume steps: 65537
        muted: no
        current latency: 0.98 ms
        max rewind: 0 KiB
                     Stereo
        used by: 2
        linked by: 2
        module: 27
        properties:
                device.master_device = "audiorelay-virtual-mic-sink.monitor"
                device.class = "filter"
                device.description = "Virtual-Mic"
11 client(s) logged in.
    index: 0
        driver: <module-systemd-login.c>
        owner module: 21
        properties:
                application.name = "Login Session 2"
                systemd-login.session = "2"
    index: 1
        driver: <protocol-native.c>
        owner module: 13
        properties:
                application.name = "Firefox"
                native-protocol.peer = "UNIX socket client"
                native-protocol.version = "35"
                window.x11.screen = "0"
                window.x11.display = ":0"
                application.process.id = "1192"
                application.process.user = "chris"
                application.process.host = "Uriel"
                application.process.binary = "firefox"
                application.language = "en_US.UTF-8"
                application.process.machine_id = "a38030f5dde045668733573602ee3da6"
                application.process.session_id = "2"
                application.icon_name = "firefox"
    index: 2
        owner module: 13
        properties:
                application.version = "105.0.2"
    index: 3
        owner module: 13
        properties:
                application.name = "Plasma PA"
                application.id = "org.kde.plasma-pa"
                application.icon_name = "audio-card"
                application.process.id = "894"
                application.process.binary = "plasmashell"
    index: 6
        owner module: 13
        properties:
                application.process.id = "1219"
                application.process.binary = "systemsettings"
    index: 7
        owner module: 13
        properties:
                application.name = "libcanberra"
                application.version = "0.30"
                application.id = "org.freedesktop.libcanberra"
                application.icon_name = "preferences-system"
    index: 8
        owner module: 13
        properties:
                application.name = "WEBRTC VoiceEngine"
                application.process.id = "3541"
                application.process.binary = "Discord"
    index: 9
        owner module: 13
        properties:
                application.name = "Chromium input"
                application.process.id = "3580"
    index: 13
        owner module: 13
        properties:
    index: 14
        owner module: 13
        properties:
    index: 26
        driver: <cli.c>
        owner module: 28
        properties:
                application.name = "UNIX socket client"
2 card(s) available.
    index: 0
        driver: <module-alsa-card.c>
        owner module: 7
        properties:
                alsa.card = "0"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 90"
                device.bus_path = "pci-0000:01:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0"
                device.bus = "pci"
                device.vendor.id = "10de"
                device.vendor.name = "NVIDIA Corporation"
                device.product.id = "2291"
                device.string = "0"
                device.description = "HDA NVidia"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        profiles:
                output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
                output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
                output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
                output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
                output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
                output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
                output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
                output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
                output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
                output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
                output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
                output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
                off: Off (priority 0, available: unknown)
        active profile: <off>
        ports:
                hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
                        properties:
                hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
                        properties:
    index: 1
        owner module: 8
        properties:
                alsa.card = "1"
                alsa.long_card_name = "HD-Audio Generic at 0xfc5c8000 irq 92"
                device.bus_path = "pci-0000:06:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.1/sound/card1"
                device.bus = "pci"
                device.vendor.id = "1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "1637"
                device.product.name = "Renoir Radeon High Definition Audio Controller"
                device.string = "1"
                device.description = "Renoir Radeon High Definition Audio Controller"
        profiles:
        ports:
                        properties:
2 sink input(s) available.
    index: 3
        flags:
        state: RUNNING
        sink: 1 <audiorelay-virtual-mic-sink>
                balance 0.00
        muted: no
        current latency: 13.63 ms
        requested latency: 7.52 ms
                     Stereo
        resample method: (null)
        module: 13
        client: 8 <WEBRTC VoiceEngine>
        properties:
                media.name = "playStream"
                module-stream-restore.id = "sink-input-by-application-name:WEBRTC VoiceEngine"
    index: 6
        flags: START_CORKED
        state: CORKED
                balance 0.00
        muted: no
        current latency: 112.19 ms
        requested latency: 75.00 ms
        sample spec: float32le 2ch 48000Hz
                     Stereo
        resample method: speex-float-1
        module: 13
        client: 13 <Firefox>
        properties:
                media.name = "AudioStream"
                module-stream-restore.id = "sink-input-by-application-name:Firefox"
5 source output(s) available.
    index: 0
        flags: START_CORKED
        state: RUNNING
        source: 0 <alsa_input.hw_2_0>
                balance 0.00
        muted: no
        requested latency: 30.00 ms
                     Stereo
        owner module: 27
        properties:
                media.name = "Remapped Stream"
                media.role = "filter"
                module-stream-restore.id = "source-output-by-media-role:filter"
    index: 1
        flags: DONT_MOVE
        state: RUNNING
        volume: mono: 65536 / 100% / 0.00 dB
                balance 0.00
        muted: no
        current latency: 5.62 ms
        requested latency: 40.00 ms
        sample spec: float32le 1ch 25Hz
        channel map: mono
                     Mono
        resample method: peaks
        owner module: 13
        client: 3 <Plasma PA>
        properties:
                media.name = "PlasmaPA-VolumeMeter"
                module-stream-restore.id = "source-output-by-application-id:org.kde.plasma-pa"
    index: 2
        flags: DONT_MOVE
        state: RUNNING
        source: 3 <audiorelay-virtual-mic-sink.2>
                balance 0.00
        muted: no
        current latency: 5.65 ms
        channel map: mono
                     Mono
        owner module: 13
        properties:
    index: 3
        flags: DONT_MOVE
        state: RUNNING
        source: 2 <audiorelay-virtual-mic-sink.monitor>
                balance 0.00
        muted: no
        current latency: 32.15 ms
        channel map: mono
                     Mono
        owner module: 13
        properties:
    index: 4
        flags:
        state: RUNNING
                balance 0.00
        muted: no
                     Stereo
        owner module: 13
        properties:
                media.name = "recStream"
                module-stream-restore.id = "source-output-by-application-name:WEBRTC VoiceEngine"
1 cache entrie(s) available.
        index: 0
                     Stereo
        length: 11776
        duration: 0.1 s
        volume: n/a
                balance 0.00
        lazy: no
        filename: <n/a>
        properties:
                media.role = "event"
                event.id = "audio-volume-change"
                event.description = "Volume Control Feedback Sound"
                media.name = "audio-volume-change"
                media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
PulseAudio data shows 2 modules that are not usually loaded by default
 index: 26
index: 27
Data shows only one audio output (sink) available for audio playback:
  * index: 1
Audio playing to a null sink would be silently dropped
Data also shows 2 card(s) available. Both set to Active Profile: Off
I would expect to see output:analog-stereo profiles for headphones and speakers
and output:analog-stereo for microphones on 2nd card HD-Audio Generic,
But profiles shown are for digital HDMI outputs only
Please post more information about ALSA detection of hardware devices
sudo alsa-info.sh --upload
